#71 |
Drives: 2013 Subaru BRZ
Get a set of Blizzak WS70's on 16 inch steel wheels. Carry a plastic shovel, and a bag of cat litter in the trunk. Stay away from snow deeper than a foot (to avoid plowing) and you will be good. Going on my second Chicago winter and the first went smooth with these tires. Never lost control. getting out of parking spots on city streets required me to TURN OFF TC or you just won't move at all. Don't drive like an a-hole and you will be fine.
#72 |
Drives: 2015 FR-S
#73 |
Drives: BMW 120d
#74 |
Drives: Scion FR-S Raven
Drove all winter in New England with 2 50lbs sand bags from Home Depot over the rear wheels and never had a problem.
#75 | |
Drives: RAVEN
Word of advice to those with extra weight in the back: The Miata guys discovered this 25 years ago and it bears mentioning: The car will want to turn around if it has more weight in the back. Try throwing a dart backwards if you need a practical demonstration. With snowtires, this car seems perfectly capable unless the weather has reached "nobody should be out here in the first place" conditions. At that point it is a common sense flaw, not a design flaw. |
#76 | |
Drives: 2014 Scion FRS
#77 | ||
Drives: 2015 FR-S
#78 |
AIM4APX
Drives: 2013 WRB BRZ Limited
All of the farmers where I grew up always put two bags of sand in their old rwd pickups in the winter. I don't have any experience with it personally but most of the time if a group of farmers all do something its usually because they have results.
But...as I noted before LOTS of us drive this car in the winter with no issues.
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#79 | |
#80 | |
...ok, except for the spinning skater analogy. Not sure where you were going with the whole conservation-of-momentum thing.
#81 | |
AIM4APX
Obviously there are two winter driving experts in this thread. One says the 86 is useless in the snow. We should all take his advice and just garage our cars through the winter and buy trucks...But ffs don't put any sand in the bed.
#82 | |
Drives: 2015 FR-S
If you put those sandbags as far forward as you can (e.g. against the back of the raised rear seat), you reduce the car's polar moment of inertia. This makes it more sensitive to steering input, more prone to spin, more likely to keep spinning, and more likely to spin faster. It's the skater with her arms tucked in at her sides. Shorter wheelbases make PMI a more critical factor in handling. So shorter lighter cars like ours can be affected by even 50 pounds of sand put in the wrong place during winter driving. Weight at ends of car + loose rear end = slower spin to 180 or less. Weight toward center of car + loose rear end = fast 360s. |
#83 |
This will be my 3rd winter with the 86, and I'm coming from several FWD cars, half a dozen Subarus- from base Imprezas, a WRX, two STIs, and an Evo. The 86 is obviously not an ideal snow car, but it does just fine with snow tires if you don't drive like an a-hole as mentioned above. Avoid deep snow and keep your inputs smooth and progressive. GOes without saying dedicated snow tires are a must.
I also believe that snow drifting at low speed is a GREAT way to learn better car control, and how throttle can be used to steer the rear end. Even if you never EVER drift in the dry, it's a key skill to maintaining control *just incase* the car starts to slide you'll find yourself reacting correctly on reflex. Turn TC off and go have fun. Just don't practice in traffic, please... |
#84 | |
| quick question about this car in snow | andrewmay9 | CANADA | 32 | 01-03-2015 04:11 PM |
| Buying FR-S. Quick Questions. | maverpl | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-28-2014 11:25 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
| Few quick BeSpoke questions | NOMNOM | Electronics | Audio | NAV | Infotainment | 0 | 04-17-2013 01:39 AM |
| Few quick set up questions | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 14 | 08-23-2012 03:28 PM |
