#85 |
Drives: 86
#86 |
Drives: 86
Just installed mine as well. Everything works great! Huge thanks to everyone on here, for all the tips and instructions.
My seat bolt was a piece of cake to remove. I'm not sure if mine was just looser than yours, or if it was due to my 4' breaker bar used for leverage. Hardest part was routing it under the carpet. Thanks again everyone!! |
#87 |
Drives: 86
/begin_rant
By the way... What a complete rip-off for their so-called "fit kit". My other vehicles have Pioneer Avics installed. You buy the receiver for less than $100 and it comes with the antenna. I can't believe they get $170 for the receiver and $100 for an antenna. Absolutely nuts, but I can't live with my XM! /end_of_rant Now that I'm done ranting, I can enjoy XM radio in my new ride
#88 | |
Drives: Raven FR-S 6-speed manual, 4Runner
Glad to see everyone is having success, even if it is at an admittedly high price.Shocked to see someone having good success with the antenna mounted under glass though. I'm happy it works for you, but I had a dash-mounted antenna in an old Nissan pickup, and one port-installed with the antenna on the dash in my Tundra, both of which dropped signal like it was hot. Had to have the antenna moved from the dash to above the passenger side A-pillar on the Tundra, and that solved all signal problems. The dealer did it under warranty, and said it was a common issue with the Tundras. Again, glad it works for you. Maybe different thickness of glass, or maybe the steeper rake of the FR-S windshield? Don't know, don't care - it works for you, and that's all that matters!
#89 | |
Drives: 86
So, this weekend I plan to relocate my antenna...onto the roof. |
#90 | |
The only thing I would add is that XM seems to pick up best when the antenna is as horizontally oriented as possible. I had issues with my 4Runner dropping signal some, but the antenna was mounted over the front passenger door which cocked it to the side quite a bit. Got it moved to over the tailgate exactly centered, and much more horizontal, and the reception is rock solid - I don't remember it dropping at all any more, now that I think about it. Hope your antenna relocation goes smoothly.
#91 |
Boosted
Drives: Sideways
Dammit I do NOT want to mount this on my roof
#92 |
#93 |
That's a possibility too - just have to manage the cable flex so it is not too sharp a bend, and not so loose it hangs and gets snagged every time you put something in the trunk.
Thought about on a rear fender too, but that just looked weird, and I think putting it on a fender would put it in the way so it would get hit by accident and end up scratching up the paint. |
#94 | |
#95 |
Drives: 2013 Scion FR-S Raven
Yes the metal does, hence why I placed a thin metal piece under the magnet on the dash, I too struggled with reception and chose the metal. Why roof, just attach to decklid?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#96 |
I went to Bestbuy today to look at options. I have a Sirius unit i took out of my Toyota Tacoma that also has the home dock. For a new car kit and install on the dash with the antenna inside, i was looking at $200. My head unit was about $250 3 years ago and it a nice unit but i was not happy to have it attached to my dash.
The tech said that Pioneer might make a XM kit for the HU but i have not gotten a call back as of yet. If i do, i will post my findings here. Just wanted to intorduce myself to the group!! I ahve had my FR-S for about 2 weeks!!! Love it!! |
#97 |
Drives: asphalt fr-s
Does the sharkbeats antenna work with sirius?. .maybe not needing the sat antenna?
#98 |
Drives: 2013 Whiteout FR-S
by any chance would the BRZ stock sat antenna work for siruis radio, as to avoid the sticky mounts.?
'13 6MT Whiteout FR-S
http://www.ft86club.com/forums/showthread.php?t=117970 |
| NAV Radio suggestions | Dadhawk | Electronics | Audio | NAV | Infotainment | 20 | 07-31-2013 02:25 PM |
| USB on the stock radio | Dadhawk | Electronics | Audio | NAV | Infotainment | 70 | 02-25-2013 05:48 PM |
| Aha radio app | sieeegel | Electronics | Audio | NAV | Infotainment | 23 | 06-04-2012 10:09 AM |
| Anyone keeping their siriusXM subs when it runs out? | mechaghost | Electronics | Audio | NAV | Infotainment | 9 | 06-01-2012 03:38 PM |
| No AC/Radio option? | blur | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 04-10-2010 06:54 AM |
