Old 08-03-2023, 08:06 PM   #85
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by LRNAD90 View Post
BLAST FROM THE PAST!
Okay, so several years later, to those of your who installed the Classic Design Concepts High Mount Third Brake Light, how is it holding up? LEDs still going strong, any problems with it falling down, rattling, getting condensation build-up behind it, or anything else?
I'm sure it was a cost consideration, but this is where Toyota/Subaru should have put the 3rd brake light to begin with..
mine is still working fine. no complaints about it at all. though it's mostly covered now by the corolla third brake light in my louvers.
In the US the 3rd brake light has to be higher than the side lights.
Not sure you can get it much higher than the top of the back window, not sure I understand your comment?
his point is that it meets regulations, therefore, it's as far as they needed to go with it. probably saved some on wire instead.
What's the official solution to bypassing the VSS + e-brake sensor for videos? [Cyanide] Electronics | Audio | NAV | Infotainment 37 05-05-2015 02:51 AM
3rd brake light rattle easy fix xITSxTHExPOPEx Electronics | Audio | NAV | Infotainment 2 12-14-2014 07:14 PM
Solution for easy changes to rear camber and toe (street and track use) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-11-2014 06:28 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 02:33 PM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 08:39 PM
