Old 03-26-2014, 02:03 PM   #85
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Originally Posted by wparsons View Post
Just open it in excel and set the first value you want to change to 100, highlight all the values in that column you want to change and press ctrl + D to set all highlighted values to 100.
Oh, I didn't realize that excel could open .csv files.
Luckrider is offline   Reply With Quote
Old 03-26-2014, 02:07 PM   #86
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
csv is comma separated value, a pretty common general log type file. Excel will bring up and importer that you choose where to make the breaks. Just an FYI
bee_are_zee is offline   Reply With Quote
Old 03-26-2014, 02:10 PM   #87
Luckrider
Luckrider's Avatar
Oh, I knew about the format, I just didn't realize excel had an importer.
Old 03-26-2014, 02:11 PM   #88
wparsons
wparsons's Avatar
You shouldn't even need the importer, you should just be able to open it with excel straight away.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
solidONE (03-26-2014)
Old 03-26-2014, 02:19 PM   #89
bee_are_zee
Drives: GBS BRZ
Oh cool, I haven't tried opening a log yet. I was just speaking from previous experience using csv's and excel
Old 03-26-2014, 11:40 PM   #90
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Did not know that... I've been doing it line by line using notepad...
Also, I want to add that you should really warm up the tires before you take the log so it will not spike or read falsely high. I'm running some fairly decent 245 tires and if I don't heat the tires up it will spike every time.
Old 03-28-2014, 10:12 AM   #91
shif7i7down
Erected Member
Drives: frs
From my logs I've notice that 3rd gear pulls gives overrated whp. 4th gear pulls seems to be inline with other dynojet right around 178whp for all stock with tune.
Anywho, it's been covered in the OP but all you need is time, rpm, tps. And the first 3lines deleted when using excel.
shif7i7down is offline   Reply With Quote
Old 03-28-2014, 05:28 PM   #92
solidONE
solidONE's Avatar
Got to enter those SAE corrections for temp and barro pressure.
Old 03-30-2014, 01:23 PM   #93
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
Having read this entire thread, I noticed that no one has mentioned which transmission their vehicle is equipped with. I'm assuming that everyone is equipped the MT. As my vehicle is equipped with the AT, I'm wondering what I need to do in order to get the appropriate log file for VD. Is a manual mode pull sufficient enough to emulate a MT pull?
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 03-30-2014, 02:19 PM   #94
DriftHappens
Drives: '14 FRS White
it has an option for AT in virtual dyno.
DriftHappens is offline   Reply With Quote
The Following User Says Thank You to DriftHappens For This Useful Post:
Blu-by-U (04-03-2014)
Old 04-03-2014, 08:49 PM   #95
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Also noticed that in the options dialog (ver. 1.2.6) on the Columns and Profiles tab, you can rename certain headers in accordance to your data log file (time, rpm, afr & throttle position). Recognizes an OFT data log without issues, except for the first three lines of the file.
But I'm still getting unreal results. The closest I have come to real so far is 300 HP on a stock vehicle after isolating a 3rd gear pull. I know that I'm still doing something wrong. I'm guessing that it's my data log.
Old 04-03-2014, 11:27 PM   #96
phrosty
Get the car moving in manual mode, go up to 3rd gear, and slow down to ~1500rpm. Then go WOT. Done.
phrosty is offline   Reply With Quote
The Following User Says Thank You to phrosty For This Useful Post:
Blu-by-U (04-04-2014)
Old 04-03-2014, 11:30 PM   #97
Luckrider
Luckrider's Avatar
I wonder if it has something to do with it being an AT. The thing is, the transmission has the torque converter unlocked (I would assume, I am not sure how the lock up works on the twins, but my Jeep's 4-speed does unlocked third to locked 3rd to unlocked 4th to locked 4th so you get 6 "gears"). I think that might be what is messing with the results since you now have a lower overall gear ratio.
Old 04-04-2014, 10:50 PM   #98
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
I'll give this a try. I would really enjoy having this work for me, as some changes are being budgeted for. Don't want much more, but I'm after the best bang for my buck. If this tool can help me get there without the cost of actual time on a dyno, I can't help but to recommend it.
Data Logs! Post them here. feldy Software Tuning 2163 02-26-2026 07:15 PM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 06:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
