#71 |
Drives: Toyota Gt86
![]() Various Pulls STG1 OTS after 400kms 100RON (EU) Mods: Blitz Drop-In Filter |
#72 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#73 | |
Drives: Toyota Gt86
Thanks Anyway! |
#74 |
Drives: Pavement MT GR86
Very surprised you guys are getting wheel spin at over 60mph....
Are these logs taken on stock tires on a cold day? As far as if it's tc or clutch I'd try the run with tc in sport or all off and see if it changes.
GR86 MT premium
#75 | |
Edit: Forgot to say that this is with the TC totally off. |
#76 |
Drives: Raven FR-S 6M
Here is my VD stuff. This is a comparison of the average of several logs from last summer with perrin header back and Ecutek stg 1 vs. OFH, Perrin header back and OFT stg 2 logs I have taken over the last week. Both are using 94oct gas and have been corrected for atmospheric pressure, tire diameter and air temp. Same car, same road.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following 2 Users Say Thank You to Apoc For This Useful Post: | Shiv@Openflash (03-22-2014), Wepeel (05-16-2014) |
#77 |
Does anyone know why I am having this problem? You can clearly see the RPM range of the logs by looking at the left where it shows the information used to generate the graphs.
#78 |
Drives: '14 FRS White
double check to make sure the throttle position reads >92% (i think someone stated that was the cutoff), I always set it to 100% anyway to be sure.
| The Following User Says Thank You to DriftHappens For This Useful Post: | solidONE (03-26-2014) |
#79 |
Drives: FR-S Whiteout
I'm pretty sure this is what causing the problem. I just put the entire log to 99% throttle position, since usually it reads 9x.xx%. I just go over the second digit down the entire log and change to 9 on all of them.
#80 |
Yeah, that one took me a bit to figure out. haha. "Why the F*** is it stopping at 4k!?!?!" Good times.
#82 |
I was talking to the guy that wrote VirtualDyno, and it's not actually a fixed value. It just takes everything within ~5% of the max value as WOT. In our case max seems to be around 97-98%, so the 92% is the value that cuts us off, I just take any value that should be WOT and make it 100% before importing the log and it works fine every time.
| The Following User Says Thank You to wparsons For This Useful Post: | DriftHappens (03-26-2014) |
#84 |
Just open it in excel and set the first value you want to change to 100, highlight all the values in that column you want to change and press ctrl + D to set all highlighted values to 100.
| Data Logs! Post them here. | feldy | Software Tuning | 2161 | 12-24-2025 01:17 AM |
| Anyone help interpreting data logs? | cuddefred | Engine, Exhaust, Transmission | 8 | 10-11-2013 07:30 PM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
