#85 |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#86 |
Drives: GBS BRZ
#87 |
#88 |
You shouldn't even need the importer, you should just be able to open it with excel straight away.
| The Following User Says Thank You to wparsons For This Useful Post: | solidONE (03-27-2014) |
#89 |
Drives: GBS BRZ
Oh cool, I haven't tried opening a log yet. I was just speaking from previous experience using csv's and excel
#90 | |
Drives: FR-S Whiteout
Also, I want to add that you should really warm up the tires before you take the log so it will not spike or read falsely high. I'm running some fairly decent 245 tires and if I don't heat the tires up it will spike every time. |
#91 |
Erected Member
Drives: frs
From my logs I've notice that 3rd gear pulls gives overrated whp. 4th gear pulls seems to be inline with other dynojet right around 178whp for all stock with tune.
Anywho, it's been covered in the OP but all you need is time, rpm, tps. And the first 3lines deleted when using excel. |
#92 |
Got to enter those SAE corrections for temp and barro pressure.
#93 |
Some Dumb Guy
Drives: wanting an Acabian
Having read this entire thread, I noticed that no one has mentioned which transmission their vehicle is equipped with. I'm assuming that everyone is equipped the MT. As my vehicle is equipped with the AT, I'm wondering what I need to do in order to get the appropriate log file for VD. Is a manual mode pull sufficient enough to emulate a MT pull?
She said it was her or the car. Longest
she had ever seen. |
#94 |
Drives: '14 FRS White
it has an option for AT in virtual dyno.
| The Following User Says Thank You to DriftHappens For This Useful Post: | Blu-by-U (04-03-2014) |
#95 |
Some Dumb Guy
Also noticed that in the options dialog (ver. 1.2.6) on the Columns and Profiles tab, you can rename certain headers in accordance to your data log file (time, rpm, afr & throttle position). Recognizes an OFT data log without issues, except for the first three lines of the file.
But I'm still getting unreal results. The closest I have come to real so far is 300 HP on a stock vehicle after isolating a 3rd gear pull. I know that I'm still doing something wrong. I'm guessing that it's my data log.
#96 | |
| The Following User Says Thank You to phrosty For This Useful Post: | Blu-by-U (04-04-2014) |
#97 | |
#98 |
Some Dumb Guy
I'll give this a try. I would really enjoy having this work for me, as some changes are being budgeted for. Don't want much more, but I'm after the best bang for my buck. If this tool can help me get there without the cost of actual time on a dyno, I can't help but to recommend it.
| Data Logs! Post them here. | feldy | Software Tuning | 2161 | 12-24-2025 01:17 AM |
| Anyone help interpreting data logs? | cuddefred | Engine, Exhaust, Transmission | 8 | 10-11-2013 07:30 PM |
| Interpreting Ecutek Data Logs? | cuddefred | Software Tuning | 3 | 09-02-2013 01:55 PM |
| VIR - Impressions/Pics/Logs/Video (Track Daze) | swift996 | Tracking / Autocross / HPDE / Drifting | 39 | 08-30-2013 10:21 AM |
| Noise tube delete air/fuel logs? | jm1681 | Engine, Exhaust, Transmission | 13 | 10-17-2012 05:57 PM |
