Old 03-03-2014, 02:09 PM   #1
wparsons
wparsons's Avatar
OFT logs and VirtualDyno
Has anyone tried converting the OFT logs to something VirtualDyno can read from? I tried opening one directly and it doesn't work, but I don't have any other logs that do work to compare the formatting to.
If anyone has a log that will work in VirtualDyno I would love a copy of the raw file to compare it to an OFT log and see what needs to changed to make it work.
*edit* - here's the working information for easier sourcing!
Open the log file in notepad, textpad, etc and remove the top three lines (above the column headers), then rename the following column headers:
"Time(s)" to "Time"
"Engine Speed" to "RPM"
"Throttle" to "Throttle Position"
"AFR" to "Lambda (Bank1) (AFR)"
Virtual Dyno will open it thinking it's a "Cobb Access Port" log, but it seems to work fine and give believable numbers.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Pooverdam (03-06-2014)
Old 03-03-2014, 03:35 PM   #2
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
Ecutek logs work for me in Virtual Dyno. Here is a log I did last summer.
http://datazap.me/u/dmmccrea/vt-c
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following User Says Thank You to Apoc For This Useful Post:
wparsons (03-03-2014)
Old 03-03-2014, 04:44 PM   #3
Victor Draken
Drives: Toyota Gt86
interested.
Victor Draken is offline   Reply With Quote
Old 03-03-2014, 06:39 PM   #4
wparsons
wparsons's Avatar
Awesome, thanks! EcuTek is officially supported by VirtualDyno, but OpenFlash isn't yet.
Just taking a quick look, it might be REALLY easy to make an OFT log work though. The only glaring difference is that there are a couple extra rows of useless info at the top of the OFT csv file that aren't there in the EcuTek file. I'm going to strip them out and try again in a bit (gotta go down to my desktop).
flickr
Victor Draken (03-03-2014)
Old 03-03-2014, 07:21 PM   #5
Apoc
Apoc's Avatar
I took a look at this too. Remove the empty rows so only the column headers are left. Now loading the files looks to have a problem with the column names so do the following. Rename "Time(s)" to "Time", rename "Engine Speed" to "RPM" and "Throttle" to "Throttle Position". It appears that it recognizes all column names and loads now.
“The World is Flat”
[||•]=(86)=[•||]
The Following 2 Users Say Thank You to Apoc For This Useful Post:
TIE Pilot (03-04-2014), Victor Draken (03-04-2014)
Old 03-04-2014, 06:18 AM   #6
Victor Draken
Drives: Toyota Gt86
So it works Now?
Old 03-04-2014, 06:26 AM   #7
yoruck
Drives: ford fiesta st 150
i am interrested too,
i have try to modify the log but didn't work anymore
yoruck is offline   Reply With Quote
Old 03-04-2014, 06:30 AM   #8
DriftHappens
Drives: '14 FRS White
I did this exact thing and it works like a charm. Highlight both the top rows and delete them, change the names as posted, save it and bingo. (now i have to go do more 3rd gear pulls).
Don't try to load up a full log, it'll be....interesting (685whp anyone? lol). I would recommend either editing a log or just doing a new one (i'd remove the rows before you go WOT in 3rd and after you let off, throttle position <9x%). It'll make everything cleaner.
DriftHappens is offline   Reply With Quote
The Following User Says Thank You to DriftHappens For This Useful Post:
wparsons (03-04-2014)
Old 03-04-2014, 06:57 AM   #9
wparsons
wparsons's Avatar
100% agreed!
I was able to get it to load as well. My log was from an uphill on ramp so the dyno won't be accurate but it does load the log now.
flickr
Old 03-04-2014, 07:01 AM   #10
DriftHappens
and don't forget you have to choose the car (upper left side) and set the values (like weight).
Old 03-04-2014, 07:19 AM   #11
Victor Draken
Drives: Toyota Gt86
GREAT STUFF!
I still need to understand how to fix if slightly uphill and how to understand if the pull is done properly or not, will make few test soon.
For ppl like me where for ONE launch on the dyno they want around 100euro this program is a life saver
Old 03-04-2014, 07:42 AM   #12
DriftHappens
I don't think there's really any fix for uphill, but if you do one pull uphill, then one downhill, just average the results. Still not 100%, but neither is Virtual Dyno 100% anyway. Properly is ~2k rpm to redline. WOT.
Blu-by-U (03-30-2014)
Old 03-04-2014, 08:04 AM   #13
Victor Draken
Drives: Toyota Gt86
Is not properly working for me, Can't display past 5krpm
My dyno stop at 5,2k rpm. any suggestion?
Anyone can upload his csv file that works so I can compare with mine?
I think openoffice is fucking up the size of the column or somethingelse.
Any suggestion?
Old 03-04-2014, 09:28 AM   #14
wparsons
wparsons's Avatar
Open the CSV in a proper text editor, not in excel/open office/etc.
flickr
Data Logs! Post them here. feldy Software Tuning 2163 02-26-2026 07:15 PM
Anyone help interpreting data logs? cuddefred Engine, Exhaust, Transmission 8 10-11-2013 06:30 PM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
