#85 |
Equinsu Ocha
Drives: SWP BRZ Limited
Still getting the hang of data logging...This is a 3rd gear 2500-6000 rpm pull, stage 1, 91 Oct. I realize I probably should have gone up to 7k but traffic was heavy. Only mods are drop-in filter and perrin inlet tube. Any gurus care to chime in?
http://www.datazap.me/u/rbutler33/of...log=0&data=1-9 |
#86 |
Drives: 2013 Scion FR-S Raven
Find an empty road in the middle of the evening
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#87 | |
Drives: 2015 Mustang GT (on order)
#88 |
Drives: UK GT86
Plus ideally you want to repeat the same runs a few times. I personally find a flat road and do a pull back and forth twice. Then you have 4 runs to compare and see how the car reacts.
.: Stealth 86 :.
#89 |
Codename: Stitch
yeah, in order to provide meaningful info on the log you should be flooring it from 2000-7500rpm the whole way. Which means you should not be doing this in traffic. Find an empty road to do this, not on a busy street or freeway.
#90 |
Equinsu Ocha
I was in traffic and found an opening in another lane, then while in 3rd gear accelerated up to 6k. I realize conditions werent optimal and will do some more logging tonight when the roads are less congested.
#91 |
are you Jeff Vader?
Drives: Black BRZ Limited
my first datalog
http://datazap.me/u/vr46/e8520140204
First tank of E85, this is 70 miles after flashing the E85 tune. BRZ 6AT, Borla UEL, Tsudo catted front pipe, OpenFlash Stage 2 UEL E85 A01D 1.54b map. 2nd gear. |
#92 | |
Drives: 2013 FRS
#93 | |
are you Jeff Vader?
Third gear this time - decided I was in the wrong spot to do more than one
#94 | |
Drives: 2013 FRS
#95 |
86 owner
Drives: Toyota 86 GT
Hi, this is a 3rd gear pull with 1.55b, my 86 is using K&N air box, catless frontpipe and HKS exhaust, do you know if those readings are normal?
Thanks ![]() http://datazap.me/u/dom/3rd-gear-pull |
#96 | |
Drives: 2013 FRS
#97 |
Slack Bum
Hi @shiv@vishnu
I managed to do a 3rd gear WOT as follows http://datazap.me/u/burn/155b-oft-3r...7-8-9-10-11-12 Is it normal ? Last edited by Burn; 02-07-2014 at 10:52 AM. |
#98 | |
RWD addicted
Drives: BRZ 6MT OFT OFH
![]() But afr seems a bit rich on WOT - mine became about 0.5 higher on 1.55 Stage 1. Probably it could learn for better afr later. But your max engine speed - i don't think i could ever reach the same numbers as your 7591 - was it a kind of downhill drive?
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
| FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
| new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
