Old 03-10-2014, 12:48 PM   #85
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Ok, I've added to all roms on my Github repository:
https://github.com/TD-D/SubaruDefs/t.../RomRaider/ecu
Remember, if you are downloading from here, make sure that you click on "raw" to get the actual XML (otherwise you will download an html page!)
Td-d is offline   Reply With Quote
The Following 4 Users Say Thank You to Td-d For This Useful Post:
Malt (03-10-2014), RavioliG (06-14-2014), s2d4 (03-14-2014), Sportsguy83 (03-11-2014)
Old 03-10-2014, 02:03 PM   #86
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by troek View Post
What values have u tried?
EDIT: I cant seem to find that table in RomRaider.
I've made all rows the same using the lower ones as a template.
.: Stealth 86 :.
Kodename 47 DJ:
The Following User Says Thank You to Kodename47 For This Useful Post:
troek (03-10-2014)
Old 03-10-2014, 04:37 PM   #87
troek
troek's Avatar
Drives: 2012 Toyota 86
so you have all rows reading 8, 7, 7, 5, 5, etc?
Originally Posted by Td-d View Post
@troek - what's your CAL id?
Nevermind, I've added to ZA1JA01A, here:
https://raw.github.com/TD-D/SubaruDe...R_ZA1JA01A.xml
awesome, thanks man. very helpful! did you add any other tables?
Old 03-10-2014, 04:53 PM   #88
Td-d
Not at this stage - but if there's anything specific you want, let me know.
Old 03-11-2014, 05:10 AM   #89
troek
troek's Avatar
yes this definitely made a difference, now im not afraid to start my car at 5 am lol. thanks. im runing all tables the same in the maf correction after start, 1400 rpm target idle, and reduced to -8 timing in the post start table. its a pretty significant change.
The Following 2 Users Say Thank You to troek For This Useful Post:
86-tundra (03-24-2014), acj47 (12-10-2014)
Old 03-11-2014, 07:29 AM   #90
Td-d
Old 03-11-2014, 08:46 AM   #91
mad_sb
Drives: 2013 Asphalt FR-S
Any idea on the table logic for the post start maf correction? As in what the table actually does? Initially I thought it was just a post start reference or target value for maf g/s.
If this is a reference (initial estimated maf reading used for fueling right after it catches) then it would not make sense for this table to affect the cold start beyond the first second or so of the cold start.
If, on the other hand, it is a maf target table used during cold start then it makes perfect sense and I would assume the ecu adjusts throttle plate angle to get the desired air flow. On 21*C cold start i see 18 - 19 g/s during the high idle cold start.
Old 03-11-2014, 09:28 AM   #92
Td-d
I'll dig into the logic but I don't believe it's a reference - that was already available as the post start airflow reference and the load reference tables.
Old 03-11-2014, 01:02 PM   #93
Td-d
It's definitely an adder to MAF.
The Following User Says Thank You to Td-d For This Useful Post:
mad_sb (03-12-2014)
Old 03-12-2014, 08:23 AM   #94
regal
My car never idles over 900 rpm even if under 10F overnight. I'm hopefully about to buy BRZ edit, perhaps I could send my bin for those more familiar with these cars to compar (mine is a fall 2012 dealer flash.)
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 03-12-2014, 08:26 AM   #95
Td-d
You won't have these tables in BRZedit (yet, I'm sure they'll get copied soon enough )
Old 03-12-2014, 08:31 AM   #96
regal
Thanks what about romraider?
Mods:
Old 03-12-2014, 08:38 AM   #97
Td-d
Yup, I've implemented across all roms. Yours is probably ZA1JA00C.
Old 03-12-2014, 09:02 AM   #98
troek
troek's Avatar
are you invovled with romraider or are you just some random helpful dude?
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold weather knocking during start ups. JDMenrique Issues | Warranty | Recalls / TSB 38 01-13-2015 12:53 AM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 02:35 PM
