Old 11-18-2014, 01:45 PM   #85
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by rh9 View Post
I just swapped a 2jz and the car is running n driving with chase bays wiring..nothing works though n im very disappointed honesty. .no gauges..no electric steering..no abs
With the Chase Bays "FRS/BRZ" Harness ? It's supposed to retain stock functions. So you have no guages at all? I would expect ABS and powersteering not to work because they require a crank signal. But the others would work if the harness works correctly.
Pure Automotive is offline   Reply With Quote
Old 11-18-2014, 02:11 PM   #86
rh9
Drives: red brz
The chase bays I thought would run like stock thats why i bought it...no tach..no h2o..fuel works and speed work as its not ecu related...i give up the gauges n install a race pak but i have to run the power steering n dont know what to do now !
rh9 is offline   Reply With Quote
Old 11-18-2014, 02:12 PM   #87
rh9
Drives: red brz
So if i ran the 2jz 2 wire crank sensor wires to the big plug of the brz going to the stock ecu..would ps n abs work ?
Old 11-18-2014, 02:18 PM   #88
Pure Automotive
It's worth a shot, it depends on whether or not the signal is the same so that the ECU can understand it. If it works you can send me some thank you gifts haha!
Old 11-18-2014, 03:02 PM   #89
rh9
Drives: red brz
I sure will..but cant find a proper brz or frs ecu pinout or atleast the big plug in the engine bay that goes to the ecu..got any ?
Old 11-18-2014, 04:09 PM   #90
Ross
Drives: 85 corolla gts
They are 2 different signals. The 2j if memory servers me correct is based off of a 12 tooth crank trigger pick up, were as the fa20 is based off a 36 tooth again if memory is correct. It is actually a simple fix but machine work and some minor fab work and wiring would be required. Do to the missing tooth design of the crank triger wheel on the fa20 the ecu should be able to get engine speed with out the need of cam sensors (this is a theory I have not tested and basing it of sheer speculation). You will need to disable all other codes for cams and such. As for coolant temp, ect that is relativly easy as well. it is a basic thermo sensor, all you need to worry about is setting the management up to deal with the factory sensor (pretty easy with most management systems) or you will need to run dual coolant temp sensors (again still easy). The lack of a proper engine speed signal is what is making your abs / and eps / and other can based items not work. hope the helps point you in the right direction. The factory service manual has the ecu pin out voltage chart, use that to figure out your needed wiring.
Ross is offline   Reply With Quote
Old 11-18-2014, 04:15 PM   #91
rh9
Drives: red brz
Im also running a vvti 2jz which is a 36-2 crank sensor..but to many variables n the wiring is already too complicated..dont know really..im guessing ill switch to a mechanical steering rack from an s13 silvia
Old 11-18-2014, 04:21 PM   #92
Ross
I just noticed your in bahrain, why not contact ekanoo to get you sorted. Also if you are using that crank trigger wheel some minor modification of it and rework of your ems settings may get you were you need to be. just a thought.
Old 11-18-2014, 05:11 PM   #93
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
@rh9 it maybe possible that your wiring pin out is slightly different than the usdm harness chase bases their harness off of
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 11-18-2014, 11:39 PM   #94
rh9
Drives: red brz
i doubt that it is different, possible though...trying to source out a similar steering rack to swap and custom fit it ..no other choice
Old 11-19-2014, 10:01 AM   #95
Pure Automotive
I never ran power steering in the v8 setup because the front end gets so light under acceleration it actually feels safer without it lol
Old 11-20-2014, 07:46 PM   #96
M23
Drives: 86
9.1sec sleeper. Looks almost stock and could easily pass for a street car:
[ame="https://www.youtube.com/watch?v=_juJ7z9zNyI"]EKanoo Racing 2013 Toyota 86 2JZ Walk-around - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=8T9io5gpp20"]World Fastest Toyota GT 86-2JZ Runs 9.1 @ 256 KM/H Built By EKanooRacing - YouTube[/ame]
Not so sleeper:
[ame="https://www.youtube.com/watch?v=phguxGj6fRc&list=UUzATULZgzL0wzLAk0N4sfNA"]EKANOORACING Super Street GT86 Runs 6.85@ 325 KM/H - YouTube[/ame]
M23 is offline   Reply With Quote
Old 11-20-2014, 11:13 PM   #97
Drift&Drag
TURBOLICIOUS
Drift&Drag's Avatar
Drives: a machine :]
... will install a Race Pak
This is the route I am going.
Or you can go with a S14 rack.
Drift&Drag is offline   Reply With Quote
Old 11-21-2014, 05:44 AM   #98
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Not so sleeper:
That's the same car. I'm shooting for deeps 9s as well. Guaranteed Ekanoo will be running sub 6.5 with that setup soon, if he hasn't already.
slicktop is offline   Reply With Quote
Build Happening soon.....2jz Swap JK21 Engine Swaps 85 04-16-2019 07:21 PM
3 Way Active without a Subwoofer stea1thbear Electronics | Audio | NAV | Infotainment 42 10-14-2013 02:03 AM
Need advice...removing active sub Fizz Electronics | Audio | NAV | Infotainment 5 10-07-2013 10:26 AM
Active Knock sensor Fat Spider Engine, Exhaust, Transmission 13 07-14-2013 08:37 PM
A more active mid alantic _F-R-S_ Mid-Atlantic 37 11-12-2012 07:19 AM
