Old 10-07-2013, 08:01 AM   #1
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Need advice...removing active sub
I'm planning to remove an aftermarter under-seat active/powered subwoofer from one car to install into another car.
Question is...if I unplugged just the active sub only (leaving the cables and wires in the car) will the rest of the vehicles speakers etc still function as normal?
Fizz is offline   Reply With Quote
Old 10-07-2013, 08:09 AM   #2
ft_sjo
Drives: GT86
Who knows.
A bit more detail would help? Which active sub? Which car? What kind of connections? Etc...
Old 10-07-2013, 08:25 AM   #3
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
It's a pioneer 8" slim sub which is fitted to a 2013 CRV. I don't know what connections bcoz it was installed by an audio shop.
I was thinking of testing by disconnecting the power from battery source, if everything else works fine that means I should be able to remove it safely. Thoughts?
Old 10-07-2013, 08:44 AM   #4
ft_sjo
Drives: GT86
Maybe, test, don't guess. Just ensure you don't leave any live wires floating around which could short out.
Old 10-07-2013, 09:05 AM   #5
Shankenstein
Frosty Carrot
Shankenstein's Avatar
Drives: The Atomic Carrot
@Fizz
If you're talking about this guy, it's not an active subwoofer. It's a pre-loaded box. There is an external amplifier. We'd need to know which amp.
If it's this one, it's brand spankin' new, expensive, and I thought it was exclusive to Europe. You can safely remove the connectors, but I'd wrap some electrical tape over the power connector.
If it's this one, you're in a similar European boat. Connector should pull out and wrap it with electrical tape.
Alternatively, you could find the fuse and pull that. Most of the active slim subs use very little power, so yanking it won't do anything.
If you think you're nerd enough, join in the discussions about Suspension and Aerodynamic modelling!
Wall of Fame - JDL Auto Design, Raceseng, Vishnu Tuning, Penske Shocks, Nameless, Perrin, RaceComp Engineering, Essex/AP Racing, Verus, RacerX
Wall of Shame - aFe Takeda, Wilwood, FA20Club
Shankenstein is offline   Reply With Quote
Old 10-07-2013, 10:26 AM   #6
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Thanks guys. Yes it's the same as last picture shown above. I'll make sure all wires get wrapped up nicely.
Update: I managed to remove the sub successfully...with the rest of the stock system all still working perfectly. Thanks guys!
Full Active With Widebands? Skippman Electronics | Audio | NAV | Infotainment 47 04-22-2020 09:42 PM
Tein Active EDFC?? Yes please :) RallySport Direct Suspension | Chassis | Brakes -- Sponsored by 949 Racing 91 04-14-2014 09:44 AM
3 Way Active without a Subwoofer stea1thbear Electronics | Audio | NAV | Infotainment 42 10-14-2013 02:03 AM
A more active mid alantic _F-R-S_ Mid-Atlantic 37 11-12-2012 07:19 AM
