Old 11-22-2013, 03:38 AM   #85
imom
Drives: BRZ sold
Originally Posted by Sellout View Post
I did redline MTL at about 1600 miles. Better than stock, still not great. The transmission stopped locking me out of 2nd gear when cold but it would just grind instead.
Put in Motul Gear300 at 5k. I won't be going back to Redline. The Motul is smoother. I'm back to being locked out of 2nd occasionally for the first mile or so, but I'll take that over the grinding. After the first mile when the car is cold, it almost acts like a manual transmission should...
Have you tried the Mitec springs and shifter bushings and tranny insert with redline? The MTL is thinner so it's easier for cold weather.. the springs and such is to help with the shifting... I'm having my car serviced next week I hope.
imom is offline   Reply With Quote
Old 11-22-2013, 09:18 AM   #86
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
No I haven't. I should look into that
Sellout is offline   Reply With Quote
Old 12-11-2013, 11:13 PM   #87
husker741
My car is currently getting it's transmission replaced and I asked about using a different fluid. They said that it would void warranty… I want to do what they say because I've finally found a good dealer to work with, but I wish I could use the better transmission fluid.
husker741 is offline   Reply With Quote
Old 12-11-2013, 11:18 PM   #88
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
You do know that is a 100% lie right?
You must use a fluid that meets GL4 for the trans and GL5 for the rear Diffy. They cannot deny warranty claims if you use fluids that meet those specifications.
Motul Gear 300 is both GL4 and GL5 compliant.
Mike
AZP Installs is offline   Reply With Quote
Old 12-11-2013, 11:19 PM   #89
husker741
Mike
And see, that's what I thought too. Hmmmm…
Old 12-11-2013, 11:31 PM   #90
AZP Installs
Yeah we are good friends with one of the gurus at SOA who determines warranty stuff so I am fairly sure we are right on it.
Mike
Old 12-11-2013, 11:36 PM   #91
husker741
Mike
Well I need to call SOA once I get my car back to check in with them so I will ask then.
Old 12-12-2013, 05:45 PM   #92
Darkazn58
Drives: 2014 Subaru BRZ
I'm trying to figure out what kind of fluids I should use before I actually get my BRZ. But I don't understand how can a fluid be both GL-4 and GL-5 rated. I thought that the ratings did not supersede one another. As in something that requires GL-3 cannot be replaced with GL-5 instead. Plus, aren't the compositions of GL-4 vs GL-5 different? So how exactly does Motul achieve both ratings?
Based off of my reading so far, I'm looking at Mobil1 0w20 for oil, amsoil 75w90 for tranny, and Motul Gear 300 LS for the diff.
Darkazn58 is offline   Reply With Quote
Old 12-12-2013, 09:21 PM   #93
Sellout
Mr. Cranky Pants
Sellout's Avatar
Usually the compositions of GL-4 and GL-5 are different, but you can have a fluid that meets the requirements for both. That's the case with the Gear300, apparently.
The transmission is spec'd for a 75W-90 GL3, you can't find a GL3 anymore, GL4 is the new GL3. The rear end is also spec'd for a 75W-90, but in a GL5. Since the Motul meets both GL4 and GL5 specs and is friendly to yellow metals, it's applicable in both the transmission and the rear end.
You don't need Gear300 LS in the rear end, that's for clutch type limited slips, and we have a torsen type, no need for the LS. Buy the regular Gear300 and you can use the exact same fluid for both.
Old 12-16-2013, 02:16 PM   #94
86KEEBS
DRIFT
Drives: Raven FRS 6mt
LSD doesnt need additive? Also 75/90 amsoil good for colder areas? Its below freezing for most of the year here...
86KEEBS is offline   Reply With Quote
Old 12-16-2013, 10:01 PM   #95
roddy
roddy's Avatar
Drives: '13 Ultramarine
The Torsen type LSD doesn't require an additive (friction modifier) like a clutch type does. I'm not sure if it is the same for all variants of the 86, but my Canadian spec FR-S owner's manual calls for 75W85 in the differential. 75W90 is listed as an acceptable alternative. I'm using Redline 75W85 GL-5 in mine. http://www.redlineoil.com/product.aspx?pid=40&pcid=4
Amsoil Severe Gear 75W90 would fit the bill as well.
Old 12-16-2013, 10:20 PM   #96
AZP Installs
LSD does not need additive like a clutch style would.
At operating temps the 75/90 should be find even in cold climates, although a thinner would not hurt, whatever the lowest spec you can run according to the manual is what I would run. Just remember GL3/4 for the Trans and GL5 for the rear diffy.
-Mike Paisan
Maintaining, Modifying and Educating TriState Enthusiasts since 2001.
Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs
"Race Tested, Enthusiast Approved!"
Old 12-17-2013, 03:51 PM   #97
ap5512
ap5512's Avatar
Drives: 2013 SWP BRZ
I changed out my tranny fluid towards the end of summer and noticed it being a bit smoother. I used Motul. My only problem now is that getting into first and second are pain due to the cold. It really needs to get warmed up before it becomes smooth again.
ap5512 is offline   Reply With Quote
Old 12-18-2013, 06:24 AM   #98
Victor Draken
Drives: Toyota Gt86
Am I the only one that with still the stock oil from the factory after 4.000km has no problem with shifting gear?
At first it was not smooth at all especially with cold car and first-second gear but now even at cold it's just the first shifting from first to second that sometime is just not very smooth. 1 mins later it's all good and very very smooth. I was going to change the transmission oil but right now I'm quite happy with it.
Temperatures: from 0c to 10c
Victor Draken is offline   Reply With Quote
DIY - Transmission / Diff Fluid Change Reference Guide F1point4 DIY (Do-It-Yourself) Guides 295 05-13-2023 02:34 AM
Automatic Transmission Fluid Change jmaryt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 169 08-26-2018 07:55 PM
What transmission fluid are you using? Chillz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 25 04-06-2013 10:45 PM
Transmission and Differential Fluid Change LINK Amadeus DIY (Do-It-Yourself) Guides 1 12-23-2012 06:01 PM
topspeed difference between manual transmission and automatic transmission torquemada BRZ First-Gen (2012+) — General Topics 51 05-04-2012 07:54 PM
