Old 02-19-2013, 10:27 AM   #85
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by mwemy View Post
i had fixed an 86 yesterday with this exact problem, it seems that all the engines were made on the assembly line as a base engine, then later on the plate was added if it was manual and a pump added it if was auto, inbetween the plate being added, the sealant would of bin "semi" dried, and once putting the plate on (with more than sufficient amount of sealant i might add) it has ripped a bit of the sealant away from the 2 surfaced of the top and bottom rocker cover plates,...
after re-sealing the plate (30 min job) with toyota black sealant, and doing a fair few high temp runs, it was not leaking, but only time will tell.... this particular car was july build, but only had 1500km on it
Sounds reasonable to me. I forgot about resealing mine this weekend. I would tell most people to just take it to the dealership. It is easy to have them stick their hand down there and feel the oil and it is easy to get to and unbolt, so I think even a dealership should be able to handle resealing it.
The Following User Says Thank You to King Tut For This Useful Post:
Marrk (02-19-2013)
Old 02-23-2013, 11:36 AM   #86
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Just got back from the dealership for oil change and I had they check the plate. They did not see a leak but they did check the bolts and now the service manager is aware of the issue. As I go to a low volume Scion dealership, they don't see too many of the FRSs come through and it was still a first time seeing the car for many of the guys so it drew a crowd.
5hairpins is offline   Reply With Quote
Old 02-23-2013, 07:03 PM   #87
mact
Drives: 13 GTI
I have the leak too. I'll repair mine when I change my oil.
mact is offline   Reply With Quote
Old 02-24-2013, 10:05 AM   #88
Chimpo
Chimpo's Avatar
Drives: '15 STi Ltd
I finally was able to check mine yesterday and i found it fairly oily on the bottom. I tried prying the plate off after taking out the bolts, but wasn't comfortable with the amount of force it was gonna take (didn't want to bend it) so i reinstalled the bolts and cleaned up what i could. Hopefully the"new snug" is enough.
Chimpo is offline   Reply With Quote
Old 02-25-2013, 10:25 PM   #89
Ltngbrz
Drives: 2013 #2073 SSM BRZ Limited MT
I have a leak too. Been stinky and to dealer once about it. They blew it off as coating placed on it for open container shipping over the ocean. 10k now. Going to contact dealer tomorrow.
Ltngbrz is offline   Reply With Quote
Old 02-25-2013, 11:01 PM   #90
mact
Drives: 13 GTI
People that have performed this fix themselves, do you have pictures?
Old 02-26-2013, 03:51 AM   #91
sw20kosh
Drives: 2013 Black FR-S
Haven't noticed a smell, but did find this tonight after parking my car for 3 hrs.
Oil level looks good though so it must be a slow leak, maybe at the top of the engine somewhere. Maybe from that plate? I'll check in the day time.
A nickel for refrence
Old 02-26-2013, 12:47 PM   #92
jeebus
Drives: 2015 Mustang GT (on order)
wow, AFAIK nobody else has had enough leak to see on the ground.
jeebus is offline   Reply With Quote
Old 02-26-2013, 01:07 PM   #93
Foobar
SLO NO MO
Foobar's Avatar
Definitely get that checked out. If that's from one 3-hr sitting, I'd worry about a significant leak.
Old 02-26-2013, 01:12 PM   #94
Ltngbrz
Never have seem any oil on the ground. All burns off on the exhaust.
Old 02-26-2013, 08:05 PM   #95
sw20kosh
Had it checked. It was a leak from the oil drain plug. Fixed.
Old 02-26-2013, 09:19 PM   #96
roddy
roddy's Avatar
Drives: '13 Ultramarine
I checked on mine this weekend while changing the oil...no leak yet. FR-S #02955.
Old 02-27-2013, 08:37 AM   #97
SloS13
Drives: 2013 FR-S whiteout
I have this leak too
SloS13 is offline   Reply With Quote
Old 03-02-2013, 07:15 PM   #98
Ltngbrz
Fixed at dealer. Took them 1 hour 45 minutes-ridiculous. They took off the plate, cleaned and resealed. Looks like a good fix. I took a little WD-40 and a rag and cleaned all the burnt up oil off the exhaust. Haven't driven to test smell yet. Keeping my hopes up. Now onto the rear deck popping issue!
The Following User Says Thank You to Ltngbrz For This Useful Post:
Marrk (03-03-2013)
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 04:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 05:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 05:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 04:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 05:43 PM
