Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 09-03-2021, 11:54 AM   #85
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Dyno Numbers
Originally Posted by Jianlun View Post
Wonder what kind of rod stroke ratio the MonsterSport FA24 has, with its long 93mm stroke.
Monster Sport Bore & Stroke is 90x93
& honestly, using same short block as FA20, won’t be able to do 2.6. I think both Monster Sport & Subaru knew that block can handle up to 0.4liter bore.
Old 09-03-2021, 12:27 PM   #86
Jianlun
Drives: GR86 RC
I meant the rod length to stroke ratio. Because MonsterSport stroked it up to 93mm, its rod stroke ratio would be worse (more side force, friction, less revvy etc) than the already poor 1.5 ratio of FA20.
And that got me thinking, if MonsterSport could stroke an FA20 up to 93mm, they would be able to stroke the new FA24 (very similiar block) up to FA26 muahahah.
Also, on the basis that it is easier for one to bore out (change liners and pistons) than stroke up (change crank, potentially need machining out reliefs to prevent rod interfering with block due to longer crank throws etc), why didn't (or couldn't) MonsterSport go with 94mm x86mm bore stroke, and instead the much harder 90mm x 93mm. And why toyobaru manage to do that. Wonder how thin the liners are in a toyobaru FA24...
Jianlun is offline   Reply With Quote
The Following User Says Thank You to Jianlun For This Useful Post:
ichitaka05 (09-03-2021)
Old 09-05-2021, 06:06 AM   #87
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I'm not stating gen2 FA sucks, just I prayed they learn their lesson from EZ engine... but that's different topic in general.
Putting my opinion on the side, there's another 2.4 Liter FA engine we can compare em to see what's the difference. We can see it has same kind of power output. If tq dip is gone, we can guess other mods that made the difference (example: Header). , Other than the dip, we can "assume" it has same kind of power curve. If not, it'll be interesting discussion what causes the curve difference. From there, we can somewhat expect from aftermarket mods on FA24.
It looks to me that gen2 FA has a similar tq dip like gen1 FA. Maybe the drivers don't feel the dip that much, because the overall tq is higher.
Let's hope as you said gen2 FA to not have any serious engine issues. Reliability will be a serious hit for the platform if they didn't learn the lessons of the past.
Old 09-05-2021, 09:16 AM   #88
new2subaru
Weight Weenie
Drives: 15 FR-S
Are you talking about the valve spring recall?
Old 09-05-2021, 09:19 AM   #89
Baldeagle
Drives: VW GLI 6MT
Been said already. The 2.4’s torque curve has nearly the exact same shape as the 2.0’s, just shifted higher because of the greater displacement. I find the marketing hype to be disingenuous. All this talk about 2.4’s peak torque occurring at 3,700 rpm versus 6,000 rpm for 2.0’s, and therefore implying the 2.4 has a different personality is nearly a lie. If the 2.0’s torque curve were just a few lbs-ft lower at its second peak (6,000 rpm), it too would have claimed it’s peak torque occurred around 3,000 rpm. In many ways, Subaru is pissing on our boots and telling us it’s raining.
We can all reserve final judgement until we test drive the car and access the degree to which the torque dip is irritating or not. I am still very optimistic this twin will be a winner and will most likely be the next car in my garage. However with the new Z realistically priced about $10,000 higher, with its flaws too, I wonder which car is the better value. If discriminant drivers want/need a set of headers and a tune on the Twin to make it acceptable for their needs, that price gap will narrow rapidly. Fortunately we have the final say in what we purchase. Can’t wait to test drive both cars.
Baldeagle is offline   Reply With Quote
The Following 4 Users Say Thank You to Baldeagle For This Useful Post:
DriveDriftDogfight86 (10-03-2021), nikitopo (09-05-2021), Sport-Tech (09-05-2021), timurrrr (09-05-2021)
Old 09-05-2021, 09:20 AM   #90
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Valve Springs.
Shoddy sealant work.
Chirpy HP Fuel Pumps. (not a problem, more annoyance)
Fule Pumps from some o the newer cars.
Old 09-05-2021, 09:24 AM   #91
new2subaru
Weight Weenie
Drives: 15 FR-S
Originally Posted by x808drifter View Post
Valve Springs.
Valve spring and goop early on. Meh to the noisy pumps.
Old 09-05-2021, 09:39 AM   #92
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Oh no. Ichi was mentioning about the older family of Subaru engines.
The Following User Says Thank You to nikitopo For This Useful Post:
new2subaru (09-05-2021)
Old 09-05-2021, 01:16 PM   #93
FrickingReallySlow
Drives: 2015 FR-S
They didn't use any sealant for any mating surfaces! timing cover just bolts right on~ +1 HP +20 Longevity
Just remember Monster Sport made FA24 kit making almost same kinda spec of TQ/HP. Wonder if same TQ curve as this stock FA24
For a reference, here’s a vid
FrickingReallySlow is offline   Reply With Quote
The Following User Says Thank You to FrickingReallySlow For This Useful Post:
Blighty (09-07-2021)
Old 09-05-2021, 02:02 PM   #94
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
I just hope the new FA motor can handle FI better without worry of rods snapping.
MS, CSCS, TSAC-F, CPT
The Following 2 Users Say Thank You to weederr33 For This Useful Post:
nikitopo (09-06-2021), stilesg57 (09-06-2021)
Old 09-05-2021, 05:38 PM   #95
PulsarBeeerz
Drives: JRSC BRZ SOLD
Originally Posted by slimfit View Post
^^Dumb question, but do both catted and catless headers produce the same results? Or is it only catless?
Catless only. You can run a lot more timing and there is a weird back pressure resonance generated by the catalytic converters location which causes the dip.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
slimfit (09-05-2021)
Old 09-05-2021, 08:35 PM   #96
RippedManiac
Jedi
Drives: Pikachu BRZ
New one has like 5 lbs of tq loss at dip compared to mines' 28 lbs stock.
After header and tune my dip was reduced to 17lbs, with the lowest point of of the dip being 5 lbs away from stock peak.
I think this car's NA max w/o corn gonna be around 215-220 whp.
Im glad my 17 isnt that far behind xD
RippedManiac is offline   Reply With Quote
Old 09-07-2021, 01:13 PM   #97
Blighty
Drives: WR Blue Pearl 2022 Subaru BRZ
Its not talk, its what subaru and toyota are purporting as facts.
And if I might add the dyno we saw was WAY WAY off what they said, not like perhaps a little manufacturing variation off, more like some kind of issue off.
I mean nothing can take away from what everyone has said about the car, so there is that storm in a tea cup feel, but you would expect honesty in marketing.
I will say that they are dynoing the car at 13km on the clock. There are potentially a lack of things being seated.
The base model Z is a pony car with those tiny (for its weight) brakes and no LSD - well thats my opinion anyway. Good for the street and drags. Have they confirmed a price more than 'around' 40k? Love the top spec though, that is actually pretty amazing - hope they can stay under 50k.
I struggle with its hard right angle square mouth, matching with the overmakeup'ed eyelash headlights. looks terrible to me - felt it looked worse in motion too. rear is divine.
Blighty is offline   Reply With Quote
Old 09-07-2021, 03:35 PM   #98
Baldeagle
Drives: VW GLI 6MT
Caveat emptor.
The Following User Says Thank You to Baldeagle For This Useful Post:
Typical Mustang Dyno Numbers? Rockz222 Engine, Exhaust, Transmission 6 07-11-2015 08:33 PM
Dyno numbers ogrowup Engine, Exhaust, Transmission 7 12-27-2014 08:04 AM
Average Stock Dyno Numbers? KONVERTER Engine, Exhaust, Transmission 23 10-12-2013 10:13 PM
Dyno numbers list from Evasive Motorsports Meet/Dyno Fish Southern California 29 02-24-2013 03:16 AM
dyno numbers seem low stealth_fighter Scion FR-S / Toyota 86 GT86 General Forum 9 02-02-2013 09:01 PM
