#71 |
Drives: 22 BRZ
https://www.ft86club.com/forums/showthread.php?t=88696
Check out the dyno graph of these ACE headers on a gen 1 car. The most torque in the whole range is right where the dip used to be. If we can get a high quality set of pipes like these for the new engine it will be a big torque hill in the middle. Exciting to speculate about! Red line is otherwise stock car with ACE headers and overpipe on California 91 octane.
2013 FRS -> 2011 CTS-V -> 2006 Cayman S -> 2015 GTI -> 2022 BRZ
| The Following User Says Thank You to Pete For This Useful Post: | SockMonkey (09-02-2021) |
#72 |
Drives: BRZ 2nd gen
The 2nd gen graph suggests the power is flat for approximately 500rpm - from 3800rpm to 4300rpm.
Compare this to the kouki 1st gen which had a relatively flat power range of 1000rpm - from 3300rpm to 4300rpm. https://performancedrive.com.au/wp-c...no-results.jpg |
| The Following User Says Thank You to Grif For This Useful Post: | Pete (09-02-2021) |
#73 |
Drives: 18 Brz (Sold) / 22 BRZ / 13 BRZ
Concerns me more the 6250rpm on loss of torque. Seems like it looses breath there.
| The Following User Says Thank You to Stonehorsw For This Useful Post: | Ohio Enthusiast (09-02-2021) |
#74 |
Drives: 2018 BRZ
#75 |
Site Moderator
Drives: ichi 86 Project
Just remember Monster Sport made FA24 kit making almost same kinda spec of TQ/HP. Wonder if same TQ curve as this stock FA24
For a reference, heres a vid
| The Following User Says Thank You to ichitaka05 For This Useful Post: | Pete (09-02-2021) |
#76 |
Drives: 2018 BRZ
But this one is bored and stroked, vs. just bored in the gen 2 FA24. Plus I doubt the Monster Sport build needs to meet the same emissions and fuel economy standards as Subaru did.
#77 | |
Site Moderator
Putting my opinion on the side, there's another 2.4 Liter FA engine we can compare em to see what's the difference. We can see it has same kind of power output. If tq dip is gone, we can guess other mods that made the difference (example: Header). , Other than the dip, we can "assume" it has same kind of power curve. If not, it'll be interesting discussion what causes the curve difference. From there, we can somewhat expect from aftermarket mods on FA24. |
#78 | |
Drives: '13 BRZ Limited
Check out this one too. Blue is stock, red is intake and header (intakes don't really gain hp), and green is with a tune. Just the header gets significant gains and almost eliminates the dip. I think we can expect similar results on the gen2. |
#79 |
Drives: ‘22 BRZ
^^Dumb question, but do both catted and catless headers produce the same results? Or is it only catless?
#80 |
Drives: VW GLI 6MT
What does a higher quality header (with cat), plus labor plus a quality tune cost?
#81 |
Drives: 2018 Subaru BRZ Limited with PP
I actually made my own comparison early on before this thread really blasted off. Since everyone is throwing around dyno graphs now, I guess I'll throw it on to show people the difference.
The only thing to keep in mind here is that they are NOT scaled properly, so don't compare them in terms of how much more power or torque one has over the other. The way I scaled them was shifted all the torque values based on their peaks (184 for gen2 and 156 for gen1). This is the 2013 vs 2022 and both values were pretty accurately chosen from the same type of dyno (Dynapack). The red lines I drew are just kind of random for showing where the average torque mostly lies. Last edited by Dzmitry; 09-03-2021 at 09:54 AM. |
#82 | |
Drives: 22 BRZ
#83 | |
![]() EDIT: Now that I think about it, I remembered I used the gen1 peak torque RPM as the reference, so It's at 156 up in the high revs. Either way, as I stated, the scales are not correct, so don't use them as a reference. I really made it for the shape of the curve to see the differences. |
| The Following User Says Thank You to Dzmitry For This Useful Post: | Pete (09-03-2021) |
#84 | |
Drives: GR86 RC
I assume the new toyobaru FA24 has the same rod stroke (a miserable 1.5 ratio) as the fa20 since its merely "bored out". With Japan videos saying its same weight as the FA20 etc, I assume the block height is the same (else it will not fit within the wheels!). Would have been interesting if they reduced the compression height (and thus longer rod) by moving the wrist pin up but the side by side photos of the FA20 and FA24 piston/rod weeks ago seem to show the compression height is similiar if not same. And now I am going to dream about a MonsterSport FA26 with a 94mm x 93mm bore stroke. Hahahah. |
| Typical Mustang Dyno Numbers? | Rockz222 | Engine, Exhaust, Transmission | 6 | 07-11-2015 08:33 PM |
| Dyno numbers | ogrowup | Engine, Exhaust, Transmission | 7 | 12-27-2014 08:04 AM |
| Average Stock Dyno Numbers? | KONVERTER | Engine, Exhaust, Transmission | 23 | 10-12-2013 10:13 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 03:16 AM |
| dyno numbers seem low | stealth_fighter | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 02-02-2013 09:01 PM |
