Old 01-04-2019, 06:34 AM   #85
Varelco
Drives: '15 GT86 & '22 GR86
Originally Posted by Borchert97 View Post
Are we really still bitching about this? No offense, but surely you all have figured out after 6 years that it's the fuel injection system, right?
Hell yeah we are, it's still just annoying as it was 6 years ago.
Say NO to crickets!
Varelco is offline   Reply With Quote
Old 01-04-2019, 09:48 AM   #86
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Are we really still bitching about this? No offense, but surely you all have figured out after 6 years that it's the fuel injection system, right? I laugh on Mustang forums because they complain about a "ticking" noise in 18+ MY's and I'm like "welcome to the direct injection club boys, now you know how us back at ft86 feel". But seriously, the crickets are here to stay, it's a byproduct of the direct fuel injection, not a whole lot you can do about it. My advice? Make your car's idle as deep and loud as possible. Drowns out the crickets when your exhaust is highly illegal
There's a difference between "bitching" about and "discussing" a known problem. Being a flat-bill with a loud-ass exhaust is not a real solution.
PetrolioBenzina is offline   Reply With Quote
Old 01-04-2019, 09:54 AM   #87
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
'17 BRZ with occasional crickets.. Nothing like my '16, though. I just ignore it.
DaBoBo21 is offline   Reply With Quote
Old 01-04-2019, 12:06 PM   #88
Face_Plant
Face_Plant's Avatar
Drives: 2015 Scion FR-S
What's a 'squeaking accessory belt' when it's at home?
I'm not sure what you're asking?
Face_Plant is offline   Reply With Quote
Old 01-04-2019, 01:05 PM   #89
extrashaky
Drives: 2014 BRZ Limited
Originally Posted by BierMeister View Post
Mostly from costco.
Originally Posted by COLETRICKLE View Post
Costco 93 Octane
Try changing brands. Certain brands are almost guaranteed to wake my crickets. For me, the gas at Sam's Club does it every time.
Additionally, you can't go by what brands other people on this board use unless they live in your area. Gas blends are different around the country, and seasonal blends get switched out at different times depending on your local climate. I have good luck with Shell where I am now, but someone halfway across the country may get crickets from it because it's not the same gas I'm buying.
Originally Posted by DarkPira7e View Post
Running non-ethanol gas silences mine.
It didn't help mine. Three different stations. If anything, it made the crickets worse.
Old 01-04-2019, 02:33 PM   #90
Guest
Drives: 2017 BRZ PP
I get crickets from time to time. Only run E85 and always fill up at the same Shell station. I think perhaps around the time they switch the seasonal blend is when I get them (August-October)
Guest is offline   Reply With Quote
Old 01-04-2019, 02:48 PM   #91
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh well, no worries.. I failed!!
Old 01-04-2019, 03:08 PM   #92
Face_Plant
Face_Plant's Avatar
I understood "what's a squeaking accessory" belt, but you post me with the "at home" part.
By "squeaking accessory belt" I mean the serpentine belt (or accessory belt or whatever you want to call it) that spins the water pump, alternator, etc. Usually it'll squeak if oil gets on it, the bearings for the tensioner/idler puleys are going bad, etc.
Old 01-04-2019, 04:01 PM   #93
JD001
JD001's Avatar
Drives: Subaru BRZ
This phrase is an intensifier used to communicate the fact that one knows nothing about a particular person or subject, (Haemoglobin? What in blazes is that when it's at home?), effecting a self-conscious cutesy ignorance that sometimes also carries a humorous irony, depending on context.
when it's at home - Wiktionary
https://en.m.wiktionary.org › wiki › whe...
And thanks for clearing up the 'belt' descriptor.
Old 01-04-2019, 04:45 PM   #94
rkaywhodat
Drives: 2017 Toyota 86 Halo
17 automatic, in Canada use UltraMar 91 no ethanol almost exclusively. No crickets at 44,000 km
Sent from my SM-G960W using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 01-05-2019, 06:15 AM   #95
Borchert97
Borchert97's Avatar
Yes, but you see, there's little use in discussing a problem we already know everything about.
We know it's the fuel injection system, and we know there's not a whole lot you can do to fix it, although new fuel pumps and higher quality fuel tend to mediate the problem, temporarily.
In the end, it's just a quirk of direct injection, there's nothing bad about it, it does no harm, end of discussion. It's just an inconvenient noise, as some people see exhaust noise.
Borchert97 is offline   Reply With Quote
Old 01-05-2019, 12:08 PM   #96
BierMeister
Drives: 2017 BRZ PP CWP
Mine come and go entirely at random.
Same here. They were gone the next day. They might have caused by the small amount of fuel that was in my tank while it sat for a few days. Once I went through it the noise went away.
BierMeister is offline   Reply With Quote
Old 01-05-2019, 02:25 PM   #97
PetrolioBenzina
Drives: 17 86
Crickets, as you say, and as we all know, are a known feature of the pump that nobody really cares about and bothers nobody else. Your proudly illegal exhuast, however...
Old 01-05-2019, 02:45 PM   #98
Borchert97
Borchert97's Avatar
Oh please it was a sarcastic suggestion, a solution if you will, for people who are dead set on drowning out the crickets one way or another.
My exhaust is 100% legal, even in California, all I have is the factory option TRD catback sooo yeah
Here we go again! BRZ vs FR-S Crickets! PNW-BRZ Issues | Warranty | Recalls / TSB 47 07-20-2019 06:31 PM
FRS / BRZ Crickets Fix Urmyson Engine, Exhaust, Transmission 11 07-12-2016 06:08 PM
Crickets Wilfred86 Southern California 4 06-16-2016 04:05 PM
The crickets... RojerLockless Issues | Warranty | Recalls / TSB 67 02-10-2014 03:20 AM
Crickets After TSB... boredom.is.me Issues | Warranty | Recalls / TSB 9 01-06-2013 12:29 AM
