Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
11-10-2012, 01:53 AM | #85 | |
Drives: 13 Firestorm FR-S
-Rich H.
Current: 16 Porsche Cayman, 09 Tacoma 4WD, 13 Highlander 4WD, 12 Yamaha WR250R
Past: 13 10-Series FR-S, 13 FR-S, 11 S4, 07 Corolla, 98 Tacoma 4WD, 03 Corolla, 89 Camry, 90 Celica GT-S, 87 Celica GT-S |
The Following User Says Thank You to NetMagi For This Useful Post: | DAEMANO (03-30-2014) |
11-12-2012, 07:15 AM | #86 | |
Drives: BRZ and NA
I drained my Miata with the drain pain hole, put the plug back in, and tried my oil extractor. It got oil out that didn't come out of the drain hole. Also, you can tip the BRZ forward slightly or park it on a hill (since the dipstick is in the front of the engine) to get all of the oil under the dipstick tube. How much sludge are yo expecting in a brand new engine? I can't see how the oil extractor would be worse than a Fumoto valve since their output diameters are roughly the same size. |
The Following User Says Thank You to Grimlock For This Useful Post: | DAEMANO (03-30-2014) |
11-13-2012, 12:41 PM | #87 |
Drives: Ultramarine FR-S MT
Did my first oil change last weekend.
Filter was a pig to unscrew. I did manage it by hand but it was close. Drain bolt was tighter than I would prefer it but not too bad. Oil was a bit murky and had some lovely shiny dust at the bottom. |
02-13-2014, 02:55 PM | #88 |
Drives: 2014 Monogram FR-S White MT
bump.
how often do you need to change out the fiber gasket on the fumuto drain valve? |
02-14-2014, 10:14 AM | #89 |
The Following 3 Users Say Thank You to bluesubie For This Useful Post: |
02-14-2014, 11:40 AM | #90 |
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
02-14-2014, 12:42 PM | #91 | |
-Dennis |
08-15-2014, 03:01 AM | #92 |
Drives: 14 FR-S Monogram Series M/T
To everyone doing their first oil change still or about to do one for first time
Heres best hints Jack it up I used a 1/2 ratchet with a 6pt 14mm and broke it lose with one try Hold oil bowl up against it and let out bolt Go do somethig for a hour or however long Come back undo the filter and cap and stick and clean everything Go eat Come back again and put everything back on drain bolt 28.9 lbs tq Oil filter lube it and turn hand right till it stops turning Fill 5.5-5.8 Drop car Go drive Its simple as that if not easier Now if u have only a 3/8 ratchet or a box ended wrench only without a damn hammer or etc etc etc basically not having the exact tools i mentioned It could turn it to be way more headache then what original plan would be If u dont have jack or stands or etc same theory applies So my suggestion is Go buy all the damn tools Learn how to do it Yes itll cost A LOT of $$$ But its a one time deal And also tools are one of THE BEST INVESTMENTS EVER!!! Plus IMHO this is a drivers car Ild imagine the driver would want to interact with their cars as much as possible What better way then to maintain it yourself You change your own oil on your own car with care and love and no profit turn around Dealer does it for oppisite reasons with no love no care and for profit as they live and care for profit $$$ So what if its free oil changes Its garbage work Think about it |
10-04-2014, 04:31 PM | #93 | |
Drives: 2013 frs
Checking the oil when the engine is cold might give a false reading |
10-30-2014, 08:52 PM | #94 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Going to be doing a first diy oil change after the free ones from the dealer, so gave this thread a thorough eyeballing.
For those with the Fumoto valve, but no spring clamp safety, a piece of 12 guage copper wire once or twice around with the ends twisted together would keep the dump trigger closed. Racing safety wire would do if you have it around already. Don't raid abandoned (or on vacation) houses for copper wire though.
"I gotta rock." -- Charley Brown |
03-12-2015, 11:25 PM | #95 |
Drives: S
Did my 30k oil change (Eneos Sustina) very much like the OPs account. Jacked up front end, changed oil, and installed Fumoto valve. I read a high oil level and had to drain some of it - I HIGHLY recommend this thing - i imagine my next oil change will be super painless and clean. I bought the tubing and connector so I could just point the tube into an empty oil bottle.
I am having trouble reading my dipstick tho - no matter how carefully i take it out, i can never get a clean reading. Also, perhaps we had high oil levels because we drained the oil pan while the front end was elevated? |
03-13-2015, 12:07 AM | #96 |
Drives: Whiteout Scion FR-S
I think there is something to this based on a recent experience. I will see if I can do some investigating at my next oil change, which should be soon. I think I can come up with a detailed procedure to read the actual oil level after an oil change. Owners are even coming from the dealer with what appears to be an overfill, so some investigating is in order. I'll let you know what I find.
03-13-2015, 12:12 AM | #97 | |
http://www.ft86club.com/forums/showthread.php?t=7587 I have found that I can usually read the back side better, but it is still a bit of a struggle. Look for an oil line across the dipstick, even if the edges are covered with oil.
09-13-2015, 05:07 PM | #98 |
Slow Learner
Drives: 15 Halo FRS
When draining to oil, are you guys lowering the car to level prior to reinstalling the drain plug to get all the old oil out?
Similar Threads | ||||
Subaru Dealer Blacklist (Surprise markups and other shady dealings) | Longhorn248 | BRZ First-Gen (2012+) -- General Topics | 542 | 04-08-2021 07:25 AM |
Extra wiring (and a Usb surprise) | twincamRob | Electronics | Audio | NAV | Infotainment | 34 | 01-08-2014 09:25 PM |
First Payment sent, Observations after 6 weeks. | Scooby South | BRZ First-Gen (2012+) -- General Topics | 27 | 08-01-2012 02:02 PM |
My 24 experience owning an FR-S | Doji Style | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 06-06-2012 09:16 PM |
Surprise from the dealer in the mail! | Pat1usmc | BRZ First-Gen (2012+) -- General Topics | 102 | 03-11-2012 02:35 PM |
