Old 12-04-2015, 02:35 PM   #9717
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
Originally Posted by Sojhinn View Post
How'd it go @Dallen?
Appears to be running. I flashed the OTSV2 ESC tunes for OFT.
I'm only getting about 3lbs boost at the highest.
Also, how do I test that drag reduction is working correctly? I have about -11 psi of vacuum showing at idle, is that normal?
RocketBunny FRS // Phantom ESC // OFT x E85
Dallen is offline   Reply With Quote
Old 12-04-2015, 02:54 PM   #9718
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
it should be closer to 4, try a higher gear/higher speed at lower rpm's; 5th gear at around 3000 rpms. That should give everything more time to stabilize and measure it before you get to a higher rpm where the boost drops.
to test drag reduction, turn the car to on, but don't start it. pull the rubber hose off of the intake nipple, put it in your mouth and suck on it. If the compressor starts spinning, it's working.
The 11psi vacuum you are seeing is not being measured between the phantom compressor and throttle plate, which is where the phantom is measuring via the vacuum hose. I think it is being measured in the intake manifold. According to my OFT, mine sits at about 11 while at idle.
Old 12-04-2015, 03:01 PM   #9719
DAEMANO
Time Traveller
Is the ~3lbs number coming from the OFT digital guage or from a log file. The reason why I ask is that the 4-5 lbs of boost usually comes on at very low RPMS, so low and so fast you might not see it on the guage. However it will show up in your logs.
Old 12-04-2015, 03:02 PM   #9720
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
I haven't logged yet. I know just watching the oft isn't the most accurate way. I need a quick rundown on how to log.
Old 12-04-2015, 03:39 PM   #9721
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
Here is a 3rd gear pull. I started at 2400rpm & just pegged the throttle.
http://datazap.me/u/dallen/3rd-gear-...2-4-11&mark=45
Old 12-04-2015, 03:41 PM   #9722
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
@Dallen new batteries?
Installed Mods:
Old 12-04-2015, 03:42 PM   #9723
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
They came with the kit. Which ones should I be replacing if I am replacing some? My voltmeter shows 28.x in cabin when I'm not boosting
Old 12-04-2015, 03:42 PM   #9724
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
No issues then. New batteries don't show full boost until they've been used for a while.
Check your alignment of your compressor.
Installed Mods:
Old 12-04-2015, 03:47 PM   #9725
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
How far off is it? Should it be centered with the throttle body?
Old 12-04-2015, 03:48 PM   #9726
Sojhinn
Sojhinn's Avatar
Attachment 126471
Attachment 126472
That looks good. Maybe a slight adjustment right if you can.Picture of the batteries then?
Installed Mods:
Old 12-04-2015, 03:49 PM   #9727
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
That looks good. Picture of the batteries then?
1.5 dump pack
Old 12-04-2015, 03:52 PM   #9728
Sojhinn
Sojhinn's Avatar
1.5 dump pack
Attachment 126473
You should be hitting four easily. Double check your connections, and try realigning the compressor. Take your time with the alignment.
Installed Mods:
Old 12-04-2015, 04:25 PM   #9729
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
cant wait to get mine! and hopefully i have a time to install if cold weather doesnt hit me lol
Old 12-05-2015, 12:55 AM   #9730
Dallen
Boooooosted
Dallen's Avatar
Drives: Turbo FRS
Edit: KIT IS SOLD
So after compressed realignment etc, car was pushing over 4psi at 3500 rpm. This kit really is great. Few of you know, but I just switched out my turbo setup last week & installed this the other day. I think I'm going to go the direction of building my motor & doing a high HP build. I thought I would offer my kit here in this thread first to anyone that's been waiting a while etc.
The tq250, with the 1.5 dump pack. Upgraded relay, everything works. No issues
I have an OFT loaded with the ESC maps for 91/E85, as well as an FA20 4-1 header for sale too if you want to further boost you're power gains. PM for details.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
