#827 |
I just Drive.
Drives: in the womb still
So we can assume in association with or by itself the ABS system is activating your rear brakes for "traction" or lack there of.
"auto" 4wd units I think work that way if they don't have a electronic diff...wheel is spinning...locks brake on that wheel...to divert the power to the wheel that is "stuck" in the mud.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project |
#828 | |
Drives: 2013 Ultramarine FR-S
#829 | |
I Love custom Turbo kits
Drives: Limited BRZ
#830 |
Yes.
| The Following User Says Thank You to DustinS For This Useful Post: | Sportsguy83 (10-23-2017) |
#831 |
Twice now I have ran into an issue with my car falling on its face with 50% or more throttle in 3rd/4th gear. Drive fine until you pass ~ half throttle and pegs lean on the wideband. Going to check the codes, and remove both fuel pump assembly and the assembly on the passenger side and make sure nothing is clogged or fallen off.
#832 |
Drives: 2014 FRS LS Swap
Trying to wire up fans doing what you did with the relays. The two wires from my ecm are grounds for fan 1 and fan 2. I know you said to connect the main wires on relay 2 to constantly ground fan 2. Relay 1 will be primary fan and relay 3 will be secondary fan. Which wires get connected in relay 2: 3+5?
Trying to figure out where I would connect the wires from the ecu into the relay? |
#833 | |
#834 |
#835 | |
Also because I haven't had any meaningful updates: [ame="http://youtu.be/FHWVVAakd9o"]http://youtu.be/FHWVVAakd9o[/ame]
#836 |
Drives: 2017 WR BLUE BRZ
#837 |
CAN Bus Sniffer
Any update on your engine regarding the metal in the filter, or it falling on its face, from TSP or otherwise?
#838 | |
It's been too cold to really get on it lately. Seems to be happening at lower fuel levels as well, so I am assuming it has something to do with my fuel set-up. I keep meaning to jump into it and check everything but other stuff comes up. I don't have a garage so I am at the mercy of weather. I did find the local junk yard has a good aluminum case Ford 8.8 that I am going to pick up and work on a swap kit for.
#839 |
You are a godsend! Completed the first real test drive. Only issues are clutch master cylinder needs to be adjusted and the MRS device keeps dropping out. Probably loose wire. Wife went along. Also should have listened to you about the coolant hoses. Now everything is working perfect on the cooling side.
#840 | |
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 11:54 PM |
| Ls or 2jz swap? | sgoldberg01 | BRZ First-Gen (2012+) General Topics | 13 | 03-22-2016 04:07 PM |
| Rod Swap | protpibe | Engine, Exhaust, Transmission | 6 | 10-22-2015 12:38 AM |
| AT-->MT swap | AlwaysSideways | Want-To-Buy Requests | 3 | 12-15-2014 12:14 PM |
| Should I swap? | michaelahess | BRZ First-Gen (2012+) General Topics | 8 | 06-12-2012 08:32 PM |
