Old 10-16-2017, 07:54 PM   #827
Swift
I just Drive.
Swift's Avatar
Drives: in the womb still
So we can assume in association with or by itself the ABS system is activating your rear brakes for "traction" or lack there of.
"auto" 4wd units I think work that way if they don't have a electronic diff...wheel is spinning...locks brake on that wheel...to divert the power to the wheel that is "stuck" in the mud.
-Waiting patiently for the right FT-86...
-92' Acura Legend 5spd coupe twin turbo project
Swift is offline   Reply With Quote
Old 10-22-2017, 02:52 PM   #828
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Pretty much. So the system must recognize that it isn't seeing a change in the throttle position and uses the ABS to slow the wheel speed down to control traction. Surprised that it works as well as it does. Unfortunately it would seem I will be replacing my brake components sooner if I don't get some more traction.
Old 10-22-2017, 04:48 PM   #829
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
If you long press to turn off traction control like you did before the swap, there's no traction control actuation, meaning you can turn off traction control and not have it interfere with acceleration?
Old 10-23-2017, 08:32 AM   #830
DustinS
DustinS's Avatar
Yes.
The Following User Says Thank You to DustinS For This Useful Post:
Sportsguy83 (10-23-2017)
Old 10-24-2017, 01:51 PM   #831
DustinS
DustinS's Avatar
Twice now I have ran into an issue with my car falling on its face with 50% or more throttle in 3rd/4th gear. Drive fine until you pass ~ half throttle and pegs lean on the wideband. Going to check the codes, and remove both fuel pump assembly and the assembly on the passenger side and make sure nothing is clogged or fallen off.
Old 11-08-2017, 05:33 AM   #832
kurty85
Drives: 2014 FRS LS Swap
Trying to wire up fans doing what you did with the relays. The two wires from my ecm are grounds for fan 1 and fan 2. I know you said to connect the main wires on relay 2 to constantly ground fan 2. Relay 1 will be primary fan and relay 3 will be secondary fan. Which wires get connected in relay 2: 3+5?
Trying to figure out where I would connect the wires from the ecu into the relay?
kurty85 is offline   Reply With Quote
Old 11-08-2017, 09:43 AM   #833
DustinS
DustinS's Avatar
Oh man. I've slept since then haha. Yes 3 and 5 get attached together. Then just attach the ECM Ground points to the factory ground trigger wires.
Old 11-08-2017, 07:44 PM   #834
kurty85
Think I got it now. The factory ground trigger wire should be on #3 on relay 1 and #3 on relay 3?
Old 11-09-2017, 01:01 PM   #835
DustinS
DustinS's Avatar
#1 on both.
Also because I haven't had any meaningful updates:
[ame="http://youtu.be/FHWVVAakd9o"]http://youtu.be/FHWVVAakd9o[/ame]
Old 11-09-2017, 01:08 PM   #836
ILLSMOQ
Drives: 2017 WR BLUE BRZ
#1 on both.
FIRE!!!
ILLSMOQ is offline   Reply With Quote
Old 11-09-2017, 01:09 PM   #837
servemebeer
CAN Bus Sniffer
Any update on your engine regarding the metal in the filter, or it falling on its face, from TSP or otherwise?
servemebeer is offline   Reply With Quote
Old 11-09-2017, 01:31 PM   #838
DustinS
DustinS's Avatar
Nope. Going to do an oil change next week and check on it. TSP never did get back to me. I didn't try contacting again though. I will make sure to call multiple times if I find more metal.
It's been too cold to really get on it lately. Seems to be happening at lower fuel levels as well, so I am assuming it has something to do with my fuel set-up. I keep meaning to jump into it and check everything but other stuff comes up. I don't have a garage so I am at the mercy of weather.
I did find the local junk yard has a good aluminum case Ford 8.8 that I am going to pick up and work on a swap kit for.
Old 11-09-2017, 06:42 PM   #839
kurty85
#1 on both.
You are a godsend! Completed the first real test drive. Only issues are clutch master cylinder needs to be adjusted and the MRS device keeps dropping out. Probably loose wire. Wife went along. Also should have listened to you about the coolant hoses. Now everything is working perfect on the cooling side.
The Following 3 Users Say Thank You to kurty85 For This Useful Post:
DustinS (11-09-2017), ILLSMOQ (11-09-2017), wooly35 (11-09-2017)
Old 11-09-2017, 06:47 PM   #840
DustinS
DustinS's Avatar
Awesome! And my MRS device drops out randomly as well. Dash lights up like a Christmas tree, power steering turns off, speedo turns off but tach/coolant/gas gauge all work. Turn the car off and back on and everything works perfect. It’s not repeatable either.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 10:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 03:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-21-2015 11:38 PM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 11:14 AM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 07:32 PM
