Old 07-02-2012, 12:50 PM   #71
schtebie
Drives: CBS BRZ Limited
I called Swift and they're looking for a car (possibly cars) to test springs on.
I posted in the California forum - hopefully a FT86er can get out to the Swift office and the prototypes installed.
schtebie is offline   Reply With Quote
Old 07-02-2012, 01:28 PM   #72
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Updated stock spring rates to FR-S: 2.3k/3.8k and BRZ: 2.7k/3.5k
http://www.ft86club.com/forums/showthread.php?t=10416
Originally Posted by Motopythons View Post
I found this bit of information regarding the spring rate differences between the twins. The majority of the FRS owners will stick with what they have I assume. But for those BRZ owners who wish to induce a bit more oversteer (while maintaining close to the factory feel):
Car: Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
Source and credit from BRZ Club and Eibach Springs
Old 07-02-2012, 01:53 PM   #73
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
So for the RS*R iSports the spring rates are chosen at the time of purchase. You can get 6k to 9k.
denkigrve is offline   Reply With Quote
Old 07-02-2012, 02:05 PM   #74
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Originally Posted by uspspro View Post
Did you end up swapping the strings, as mentioned earlier, or did you go with the OTB setup?
swapped..
Scooby South is offline   Reply With Quote
Old 07-02-2012, 02:19 PM   #75
jeebus
Drives: 2015 Mustang GT (on order)
Originally Posted by Scooby South View Post
swapped..
why did you swap them? Seems the car was designed to run higher rates out back....aren't you promoting understeer?
jeebus is offline   Reply With Quote
Old 07-02-2012, 07:45 PM   #76
DarrenDriven
NW Region Moderator
Anyone know the choices available? Seems hard to believe that every package will be completely custom.
Old 07-02-2012, 07:55 PM   #77
denkigrve
Random Internet dad
denkigrve's Avatar
So you choose the spring-rates when you order from them. I got to pick the rates I wanted. I choose 6k F and 7k rear. Sorry, could have been clearer on that earlier.
Old 07-02-2012, 08:11 PM   #78
DarrenDriven
NW Region Moderator
OK, I get it. I need to know the spring rates that are standard in the box that gets shipped out to resellers. Thanks for the info, though.
Old 07-02-2012, 09:40 PM   #79
Scooby South
Conedancer
Nope...just suites my driving style better. thats all.
Bill
Old 07-03-2012, 12:57 PM   #80
harajukukei
Drives: MB c230k
Add Blitz to the list.
Damper ZZ-R rates are F6 / R4
max drop is 55-60cm (~2")
msrp 165,900yen but autobacs sells them for 99,500
http://www.blitz.co.jp/new-product/damper-zzr.pdf
http://www.autobacs.com/shop/g/g4959094924678/
harajukukei is offline   Reply With Quote
Old 07-03-2012, 12:59 PM   #81
harajukukei
Drives: MB c230k
HKS hipermax IV rates are also 6/4
http://www.hks-power.co.jp/product/s...tion_chart.pdf
Old 07-03-2012, 01:15 PM   #82
Opie
Opie's Avatar
Drives: 2023 Toyota GR 86 Cup
I'll be happy when I see that a Koni FSD/Eibach Kit is available for the car!
2023 GR Cup Car
Opie is offline   Reply With Quote
Old 07-03-2012, 01:43 PM   #83
DarrenDriven
NW Region Moderator
HKS and Blitz specs have been updated.
Old 07-03-2012, 01:46 PM   #84
harajukukei
Drives: MB c230k
I found one more. Apexi N1 Evolution Damper
much stiffer spring rates at 10/8
http://www.apexi.co.jp/pdf/products/n1_list.pdf
these definitely won't be comfy for daily use.
brz aftermarket coilovers, brz aftermarket springs, brz coilover, brz coilovers, brz lowering springs, brz springs, brz suspension, fr-s coilover, fr-s coilovers, fr-s lowering springs, fr-s springs, fr-s suspension, frs coilover, frs coilovers, frs lowering springs, frs springs, frs suspension, scion fr-s coilover, scion fr-s coilovers, scion fr-s springs, subaru brz coilovers, subaru brz foru, subaru brz forums, subaru brz springs
Adjustable shocks+ springs vs Coilovers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 44 06-08-2013 03:59 PM
Canadian FR-S options VS U.S.A's options? Tino Scion FR-S / Toyota 86 GT86 General Forum 15 11-06-2012 10:07 PM
coilovers or springs? koyv90 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 45 04-01-2012 08:49 PM
Gearing Options and Diff options airboy808 Engine, Exhaust, Transmission 26 12-25-2011 01:11 PM
Subaru BRZ different suspension / springs tuning ahausheer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-06-2011 12:52 PM
