Go Back   Scion FR-S Forum | Subaru BRZ Forum | Toyota 86 GT 86 Forum | AS1 Forum - FT86CLUB > Technical Topics > Suspension | Chassis | Brakes -- Sponsored by 949 Racing
Old 07-01-2012, 10:17 PM   #1
Motopythons
Let it rain!
Motopythons's Avatar
Drives: 2012 Subaru Imprezza
Actual Spring difference BRZ vs FRS
I found this bit of information regarding the spring rate differences between the twins. The majority of the FRS owners will stick with what they have I assume. But for those BRZ owners who wish to induce a bit more oversteer (while maintaining close to the factory feel):
Car: Front OE Spring Rate:
Subaru BRZ 27 N/mm (153 lbs/in)
Scion FR-S 23 N/mm (131 lbs/in)
Rear OE Spring Rate:
Subaru BRZ 34 N/mm (195 lbs/in)
Scion FR-S 37 N/mm (211 lbs/in)
Source and credit from BRZ Club and Eibach Springs
"If you no longer go for a gap that exists, you're no longer a racing driver." - Ayrton Senna
Motopythons is offline   Reply With Quote
The Following 7 Users Say Thank You to Motopythons For This Useful Post:
autobrz (05-21-2013), ayau (07-01-2012), Bristecom (09-30-2012), Drift-Office (07-02-2012), ill86 (07-05-2012), Sigh-on-Rice (08-28-2012), xwd (07-01-2012)
Old 07-01-2012, 10:20 PM   #2
ayau
Drives: Some rust bucket
are the dampers also different?
Old 07-02-2012, 01:10 AM   #3
atledreier
Drives: GT86 DGM
That's a big difference! Surprising.
Good info, thanks!
atledreier is offline   Reply With Quote
Old 07-02-2012, 02:03 AM   #4
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Cool, thanks for the info.
Can anyone find the OEM part numbers and retail pricing for the stock spring set?
Old 07-02-2012, 02:48 AM   #5
uspspro
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
RCE said 185 for both front and rear on the BRZ....
uspspro is offline   Reply With Quote
Old 07-02-2012, 10:01 AM   #6
Racecomp Engineering
Yeah we tested the BRZ springs on a spring tester and saw 185 lbs/in front and rear. Not sure where these numbers are coming from. Also I saw at least 1 other data point agreeing with our measurement.
- Andrew
Suspension and brake specialists
www.racecompengineering.com
+1 (410) 846-5407
instagram:@racecompengineering @theapexfiles
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Cope52 (05-13-2015)
Old 07-02-2012, 10:16 AM   #7
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I'm sending this link to Tony @ Eibach for his input since the OP seems to have implied Eibach measured them.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback || Oh yeah and a 2013 Scion FR-S too..
Too many cars.. never.
Old 07-02-2012, 11:08 AM   #8
ZDan
ZDan's Avatar
Drives: '17 BRZ PP, '11 Cayman
Might be wheel rates?
(er, scratch that, not likely to get 195 or 211 lb/in wheel rates with 185 lb/in springs...)
Old 07-02-2012, 11:46 AM   #9
uspspro
- Andrew
Were those springs from a pre-production car? Not sure if that matters, just thinking.
Old 07-02-2012, 12:04 PM   #10
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
EDIT:
Original spring rates that were measured were based off of the Toyota 86 in Japan.
denkigrve is offline   Reply With Quote
Old 07-02-2012, 12:06 PM   #11
DarrenDriven
NW Region Moderator
I thought that the Subaru was supposed to be more softly sprung and the FR-S a bit stiffer?
Old 07-02-2012, 12:47 PM   #12
vividracing
vividracing's Avatar
Probably not. Those rates are close enough that the OEM dampers could be engineered to handle both fairly well.
vividracing is offline   Reply With Quote
Old 07-02-2012, 12:49 PM   #13
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I think the thinking was the Subaru has stiffer front springs to promote more understeer at the limit which is more in keeping with what is typical of a Subaru car. Scion wanted the car more free, hence the softer front springs. But to counter that the Scion has front struts that are valved differently (stiffer). I suspect they are stiffer on compression a bit, not sure how much more, if any more, rebound they possess.
Sam Strano is offline   Reply With Quote
Old 07-02-2012, 12:52 PM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Eibach has another set of springs they are going to test to confirm today. I'm sure either Tony will post in here or I'll get an email from him at some point.
-Dave
Search this Thread:
Advanced Search
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
actual release date. WHEN? Ad8707 CANADA 12 05-02-2012 01:11 AM
Actual Weight For FRS??? DanPO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 03-22-2012 05:07 PM
What are the Actual Curb Weights? DanPO Subaru BRZ General Forum 9 12-22-2011 01:01 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
