#71 | |
Drives: Asphalt 2015 FRS
2. I installed another light, not only for fear of being pulled over, but for my own safety - and the car's. These cars are already pretty low to the ground; if you are on coils, you are that much lower. The moment an agressive truck/SUV starts riding your ass, there is no way they will see your tail lights. Some would say that's fine because their insurance would cover it, but to me the hassle and knowing that my car has been damaged isn't worth it.
Build Thread: http://www.ft86club.com/forums/showthread.php?t=101096
| The Following User Says Thank You to Brayden_23 For This Useful Post: | HomerTaco (03-03-2017) |
#72 |
Drives: 2015 Scion FRS Auto
updated product link: https://www.classicdesignconcepts.co...ight-2005-2009
Im doing this very soon. |
#73 |
Drives: 2014 FR-S
Thanks for the link update. I did this 5 months ago, but filled the gaps from the child seat brackets and the spaceship. Then upholstered the entire deck with black felt from Michael's. Afterward I found that someone actual has a 3D printing file posted in the DIY section so you can print your own fillers.
https://www.ft86club.com/forums/show...68#post3221168 |
#74 |
Weight Weenie
Drives: 15 FR-S
Third brake lights reduce rear end collisions by 4.3% Mines coming off in the name of weight reduction! I'll risk it...
Weight Weenie |
#75 | |
Drives: 2014 Subaru Forester
Do you have the link to the 3D printer files? I did a search but didn't find them. |
#76 |
ProCrastinationConsultant
just hope your insurance company never finds out.
#77 | |
Drives: Q5 + BRZ + M796
I like mine: ![]()
#78 | |
Weight Weenie
Drives: 15 FR-S
Looks good! I have the Valenti 4th flashing brake light. While not technically legal because it's not above the tailights, I'm confident I'll be seen. It's different and that's what gets a humans attention. |
| The Following User Says Thank You to new2subaru For This Useful Post: | Irace86.2.0 (10-24-2019) |
#79 |
Weight Weenie
Drives: 15 FR-S
I've always thought there should be one where the Toyota badge sits Instead of the rear window. If I come up with something I'll post it.
#80 |
Drives: 2014 FR-S
3rd Brake Light Delete Fillers
| The Following User Says Thank You to tarzan_nojane For This Useful Post: | tehShirt (10-28-2019) |
#81 |
Drives: X5 35d, D90, CX-5 Turbo
BLAST FROM THE PAST!
Okay, so several years later, to those of your who installed the Classic Design Concepts High Mount Third Brake Light, how is it holding up? LEDs still going strong, any problems with it falling down, rattling, getting condensation build-up behind it, or anything else? I'm sure it was a cost consideration, but this is where Toyota/Subaru should have put the 3rd brake light to begin with..
~Scott T.
'95 NAS D-90 ST '13 BMW X5 35d '22 CX-5 Turbo '?? 86 one day soon? |
#82 |
Famous Potatoes
Drives: '15 ultramarine
#83 |
Not sure you can get it much higher than the top of the back window, not sure I understand your comment?
~Scott T.
#84 |
Drives: 2014 FR-S
4+ years and still going strong for me... Only complaint is that I couldn't get the adhesive/3M tape to make a uniform even bond to the glass. Hasn't changed a bit in 4 years, but looks a bit amateurish and more like RTV than tape in direct light.
| What's the official solution to bypassing the VSS + e-brake sensor for videos? | [Cyanide] | Electronics | Audio | NAV | Infotainment | 37 | 05-05-2015 01:51 AM |
| 3rd brake light rattle easy fix | xITSxTHExPOPEx | Electronics | Audio | NAV | Infotainment | 2 | 12-14-2014 06:14 PM |
| Solution for easy changes to rear camber and toe (street and track use) | dp1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 07-11-2014 05:28 PM |
| APR Performance brake cooling solution | whataboutbob | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 02-18-2013 01:33 PM |
| Cheap, easy brake mod! | CBR600RR | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 09-19-2012 07:39 PM |
