Old 03-17-2014, 09:19 PM   #71
pixel67
pixel67's Avatar
Drives: 13 Asphalt FRS AT
Originally Posted by Sportsguy83 View Post
SOL.... Those a only two inputs available
😀 thought about putting both on an a/b switch and having one of my maps with both disabled. Or I can just move over one county where emissions aren't a factor and property taxes are a fraction of what they are here.
Sent from my Nexus 7 using Tapatalk
pixel67 is offline   Reply With Quote
Old 03-17-2014, 09:22 PM   #72
nelsmar
Has anyone tried using the ground wire from the OEM rear AF sensor? There is a 12v power which you can use for wideband / flex fuel already, using the ground would make wiring wonderfully easy.
My flickr - Canibeat
Local magazine scout
Old 03-17-2014, 10:01 PM   #73
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Interesting idea. The input could be switched between two different signals and then you would switch from one map to the other via cruise control for the correlating custom map. Suppose if you just set the min and max both to 0.1-4.9v (or whatever you want) you could still maintain the DTC associated with that one input just to have some diag if something goes wrong with that particular input (That's the way I like to set em up anyway). I would be curious to see how this worked in practice. I am also in need of an additional input so perhaps I will give this a go and see how it reacts to a switched input while running and switching maps.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 03-17-2014, 10:26 PM   #74
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
The visconti v2 flex fuel kit uses power/ground/ecu input from the rear o2 plug for the flex sensor. Works fine on my car. Made for a real easy install. Just one connection to plug in on the car itself
Old 03-17-2014, 10:32 PM   #75
utekineir
blowhard
Drives: frs, project forester
Now, assuming this was set up with plugs it could be reversible in a few minutes going back to the stock o2 sensor at inspection/emissions time right?
utekineir is offline   Reply With Quote
Old 03-17-2014, 10:36 PM   #76
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Correct.
Old 03-17-2014, 10:47 PM   #77
pixel67
pixel67's Avatar
Yep, now I can only hope that my hi flow header cat is worth a shit.
Old 03-19-2014, 11:46 PM   #78
Sportsguy83
Drives: Limited BRZ
Originally Posted by welllam View Post
Take a look at my attached log. If you look at max my voltage read is 4.19, while the target of the liftoff cruising should be 4.5 @ AFR 18 on gauge display. So it is 0.31V off. What about yours?
Took log tonight. Mine was at 4.49 V, so really on point.
Old 04-06-2014, 05:51 AM   #79
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Are you guys leaving the stock rear o2 sensor in place, or did you remove it so that you can hook up the wideband to that secondary o2 bung?
HRTROB is offline   Reply With Quote
Old 04-06-2014, 07:59 AM   #80
Sportsguy83
Drives: Limited BRZ
I have a third bung welded on my Overpipe for the Wideband O2 but you can remove the rear O2 and install your wideband O2 in its place.
Old 04-06-2014, 10:36 AM   #81
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
U said that would give me issues even tho the o2 sniffer is disabled tho
lbroskee is offline   Reply With Quote
Old 04-06-2014, 10:51 AM   #82
Sportsguy83
Drives: Limited BRZ
Not that it will give you issues, just that you need to disable a few more CELs but they will come up regardless as soon as you use the harness to connect your wideband.
Sent from my SM-N900A using Tapatalk
Old 04-06-2014, 11:13 AM   #83
xjohnx
Grip>Slip
xjohnx's Avatar
anyone know where one could find the male end of the secondary o2 harness to make for a plug and play install? Would like to tidy up some wiring and that would be a big help.
Old 04-06-2014, 11:33 AM   #84
Sportsguy83
Drives: Limited BRZ
It's a long shot, but Visconti and Moto Mike get them so they now where from... Now getting that info from them.....
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
Aftermarket Rear Diffuser Realm Cosmetic Modification (Interior/Exterior/Lighting) 8 05-08-2013 11:23 PM
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay xxscaxx Exterior Parts (Aero, Lighting, Etc.) 10 03-27-2013 10:17 AM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
