#71 | |
Señor Member
#72 |
Drives: White
Anyone have pictures of where the OEM ballast mounts?
#73 |
Señor Member
#74 |
Señor Member
Anyone mess with getting the LED's to dim when you turn the headlights on? I know the 10 series guys found a way with a resistor but I believe their wiring is different.
#75 |
Drives: Whiteout FRS
#76 |
Drives: FRS Full Blown Custom
Hey guys, no matter which lights you have you can put the resistors on the led power wire to dim them down if you want. You can also put an adjustable resistor on it and wire it into the cabin to control the brightness of the leds.
The Trypticon Transformation in Progress! |
#77 |
Señor Member
Ok so I can basically just do this and be good to go? While full brightness looks awesome I must say just standing in front of my car at night they are blinding lol
#78 |
Yes you can. If you have the conversion harness I make, they are wired on the high led side. You can move that pin from the high to the low. If this is the case, it will keep you from having to add the resistors and making the OEM harnesses looked rigged.
#79 | |
Señor Member
#80 | |
Drift Specialist
Drives: 180SX,GT86
#81 |
STV3 that is why I decided to wire the high in. You cant have both no matter how you wire them. Even if you ran that extra wire that others have done. You can only have high or low unless you want to add an adjustable resistor, which isn't OEM anymore. @GT86drifter the pinout is different from the JDM and 10series. They are on the forum. If you got a harness from me, email me and If you want them on low I will tell you which pin to move. The low isnt bright at all and is why I wire them on high. High is the default Daytime setting and low is the night setting.
| The Following User Says Thank You to DeOppressorLiber For This Useful Post: | GT86drifter (02-19-2014) |
#82 |
Drives: FRS 10 Series #534 - MT
Do you know if the Ballast is mounted outside of the headlight housing? I have a 10 series and I'm considering switching to D2S ballasts from The Retrofit Source so that I can run Osram CBI bulbs. Any insight anyone can give would be greatly appreciated!
#83 |
Señor Member
Yeah its on the outside. I don't remember what it looks like exactly but from what I do remember it looked like it would come off pretty easy.
#84 |
Thanks... Once it gets warmer out I may pull the bumper off and see how easy it would be to swap. The factory RX350 projectors on our cars are great but the stock d4s osram bulbs are only 4150K so they are a bit yellow for my liking. The Osram CBI bulbs maintain the same 3200 lumens but are closer to 5000K.
| Monogram Series FR-S is official! | Rio | Scion FR-S / Toyota 86 GT86 General Forum | 428 | 02-18-2016 06:06 AM |
| Monogram Series FR-S Orders | Rakshaa | Scion FR-S / Toyota 86 GT86 General Forum | 1241 | 06-10-2014 12:56 PM |
| Monogram series proof please | Harmsy | Scion FR-S / Toyota 86 GT86 General Forum | 72 | 01-19-2014 12:43 AM |
| Monogram Series or 2.5L FR-S | Chad86 | Scion FR-S / Toyota 86 GT86 General Forum | 42 | 11-14-2013 08:16 PM |
| 2014 Fr-s or wait until monogram series.. | NamedRyan | Scion FR-S / Toyota 86 GT86 General Forum | 27 | 10-28-2013 11:11 AM |
