Old 02-09-2014, 03:46 AM   #71
STV3
Señor Member
STV3's Avatar
Originally Posted by Gixxersixxerman View Post
I've honestly seen them exactly like that, and I've seen them with just the one step.. I'd assume you could either bring the left up or the right down..
Here is a stock 10 series I'm doing a clear lens on
You can see a flare/step on the right side after the main one
After the clear lens.. I need a bit more tuning I think..
Still has that upwards flare on the right
Hmmm I may raise the left then to make it one step. The clear lens really neatens up the cut off and looks much nicer.
STV3 is offline   Reply With Quote
Old 02-09-2014, 09:23 AM   #72
speedrye
Drives: White
Anyone have pictures of where the OEM ballast mounts?
speedrye is offline   Reply With Quote
Old 02-09-2014, 09:39 AM   #73
STV3
Señor Member
STV3's Avatar
On the bottom of the headlight
Old 02-19-2014, 12:16 PM   #74
STV3
Señor Member
STV3's Avatar
Anyone mess with getting the LED's to dim when you turn the headlights on? I know the 10 series guys found a way with a resistor but I believe their wiring is different.
Old 02-19-2014, 04:06 PM   #75
Tuan
Tuan's Avatar
Drives: Whiteout FRS
Send a message via AIM to Tuan
I've been wanting to do this too - the LED bars seem almost like high beams at night.
Tuan is offline   Reply With Quote
Old 02-19-2014, 05:31 PM   #76
DeOppressorLiber
DeOppressorLiber's Avatar
Drives: FRS Full Blown Custom
Hey guys, no matter which lights you have you can put the resistors on the led power wire to dim them down if you want. You can also put an adjustable resistor on it and wire it into the cabin to control the brightness of the leds.
The Trypticon Transformation in Progress!
DeOppressorLiber is offline   Reply With Quote
Old 02-19-2014, 05:58 PM   #77
STV3
Señor Member
STV3's Avatar
Ok so I can basically just do this and be good to go? While full brightness looks awesome I must say just standing in front of my car at night they are blinding lol
Old 02-19-2014, 06:56 PM   #78
DeOppressorLiber
Yes you can. If you have the conversion harness I make, they are wired on the high led side. You can move that pin from the high to the low. If this is the case, it will keep you from having to add the resistors and making the OEM harnesses looked rigged.
Old 02-19-2014, 07:16 PM   #79
STV3
Señor Member
STV3's Avatar
Well I'd still want them at full brightness in the day time when I have my switch on the parking light setting.
Old 02-19-2014, 07:23 PM   #80
GT86drifter
Drift Specialist
GT86drifter's Avatar
Drives: 180SX,GT86
can you post the pin out for which one is high and low
GT86drifter is offline   Reply With Quote
Old 02-19-2014, 07:32 PM   #81
DeOppressorLiber
STV3 that is why I decided to wire the high in. You cant have both no matter how you wire them. Even if you ran that extra wire that others have done. You can only have high or low unless you want to add an adjustable resistor, which isn't OEM anymore. @GT86drifter the pinout is different from the JDM and 10series. They are on the forum. If you got a harness from me, email me and If you want them on low I will tell you which pin to move. The low isnt bright at all and is why I wire them on high. High is the default Daytime setting and low is the night setting.
The Following User Says Thank You to DeOppressorLiber For This Useful Post:
GT86drifter (02-19-2014)
Old 02-21-2014, 03:19 PM   #82
StillTK
Drives: FRS 10 Series #534 - MT
Do you know if the Ballast is mounted outside of the headlight housing? I have a 10 series and I'm considering switching to D2S ballasts from The Retrofit Source so that I can run Osram CBI bulbs. Any insight anyone can give would be greatly appreciated!
StillTK is offline   Reply With Quote
Old 02-21-2014, 03:26 PM   #83
STV3
Señor Member
STV3's Avatar
Yeah its on the outside. I don't remember what it looks like exactly but from what I do remember it looked like it would come off pretty easy.
Old 02-21-2014, 03:40 PM   #84
StillTK
Thanks... Once it gets warmer out I may pull the bumper off and see how easy it would be to swap. The factory RX350 projectors on our cars are great but the stock d4s osram bulbs are only 4150K so they are a bit yellow for my liking. The Osram CBI bulbs maintain the same 3200 lumens but are closer to 5000K.
Monogram Series FR-S is official! Rio Scion FR-S / Toyota 86 GT86 General Forum 428 02-18-2016 06:06 AM
Monogram Series FR-S Orders Rakshaa Scion FR-S / Toyota 86 GT86 General Forum 1241 06-10-2014 12:56 PM
Monogram series proof please Harmsy Scion FR-S / Toyota 86 GT86 General Forum 72 01-19-2014 12:43 AM
Monogram Series or 2.5L FR-S Chad86 Scion FR-S / Toyota 86 GT86 General Forum 42 11-14-2013 08:16 PM
2014 Fr-s or wait until monogram series.. NamedRyan Scion FR-S / Toyota 86 GT86 General Forum 27 10-28-2013 11:11 AM
