Old 10-13-2013, 10:30 PM   #71
kanundrum
Drives: 2013 Whiteout FR-S
Buy back would be interesting; spare longblock, full chassis and engine harness, and trans might be worth something. Not if the buyback's >$5K though. Don't see it being that low.
It will most likely be somewhere around the fixing amount based on car estimate value
Old 10-15-2013, 03:16 PM   #72
thejevans
Rugger Extraordinaire
thejevans's Avatar
Drives: 1997 Miata, R.I.P. 2013 Red FR-S
Update:
I received word today that the other driver finally gave a statement and officially admitted fault. I'm going to pick up my full size rental tonight and my car has been towed to the lot for the adjuster. The exhaust was too damaged to be worth removing, but I was able to get my OEMAudio+ System 400+ and Bel STi-R Plus/Blinder M47 out (all will be up for sale later) with a ton of help from @ftc~brz and two other friends of mine. I'm putting together receipts to give to the adjuster now, and there are, like, 10. I forgot how many little things were on here. I will post again when I hear back from the adjuster.
So far, my plan is to get my check and buy a cheap car with any money left over + whatever I can sell stuff for. Then to pay off all my other debt. And finally, buy a Lightning Red BRZ when I am fully financially solvent again. I'm going to go with a Miata, if I can fit in it. Any other cheap car suggestions that will be relatively easy to find unmolested?
1994 Plymouth Acclaim - Engine died and went to cash for clunkers
2001 Dodge Neon R/T- Hydro-locked engine and parted out
2003 Nissan Sentra SE-R Spec-V - Traded for next car
2013 Scion FR-S - Got taken out by a distracted driver while I was sleeping. Total loss.
1997 Mazda Miata - Current
thejevans is offline   Reply With Quote
The Following 3 Users Say Thank You to thejevans For This Useful Post:
Dadhawk (10-16-2013), ftc~brz (10-15-2013), Marcoscrdo (10-16-2013)
Old 10-15-2013, 03:19 PM   #73
kanundrum
If they are at 10k right now Chances are they will fix the car and then you will sell it I assume right?
Old 10-15-2013, 03:21 PM   #74
v1ru5
Drives: BRZ D4S 6MT L Vortech
Originally Posted by thejevans View Post
Update:
rx8, miata, 3 series, *cough* g35
v1ru5 is offline   Reply With Quote
Old 10-15-2013, 03:25 PM   #75
thejevans
thejevans's Avatar
This plan assumes total loss. If anything else happens, I will have to figure something else out.
Old 10-15-2013, 03:27 PM   #76
kanundrum
Roger that, if fixing is involved DO NOT TAKE IT just anywhere. I can give great reccomendations
Basically 2 shops in the area which are far but worth it, keep in mind you will need to file a dminished value claim in addition to getting the car repaired. Lots of things ugh.
Old 10-15-2013, 03:35 PM   #77
ftc~brz
Done
Drives: WRB BRZ
I would be shocked if they didn't total loss. seriously. That is just way too much damage especially to the frame.
ftc~brz is offline   Reply With Quote
Old 10-15-2013, 03:36 PM   #78
kanundrum
>_< thats sad
Old 10-15-2013, 03:40 PM   #79
Areddi
Areddi's Avatar
Drives: Firestorm FR-S
Every true car guy should own a Miata (at some point in his life) so you can understand the standard to which all sports cars should be held, and one would fit in your budget.
Every car you ever look at or drive after owning a Miata you will find you compare to the Miata: "Well, it is more powerful for sure." "Well, it is definitely heavier." "Man, I wish this thing cornered like my Miata did."
Miata engines and drivetrains are rock-solid, and you can buy a high mileage one without fear (assuming it has been kept up with regular oil changes, etc). Make sure to check for lower rocker panel rust.
I came from a Miata to the Twins, and they check many of the same boxes in the good category that the Miata does.
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
Areddi is offline   Reply With Quote
Old 10-15-2013, 04:29 PM   #80
ftc~brz
Done
Drives: WRB BRZ
someone with a miata arrange a play date with jevans….so he can make sure he fits in there
The Following User Says Thank You to ftc~brz For This Useful Post:
thejevans (10-15-2013)
Old 10-15-2013, 06:28 PM   #81
xjohnx
Grip>Slip
xjohnx's Avatar
Out of curiosity, how did he hit your passenger side? were you parked the wrong way on the street?
Old 10-15-2013, 06:50 PM   #82
thejevans
thejevans's Avatar
I was parked on the left, yes, but that changes nothing.
Old 10-15-2013, 06:51 PM   #83
thejevans
thejevans's Avatar
Note: Geico will not buy rental insurance for rental cars if you have collision coverage.
Old 10-15-2013, 07:21 PM   #84
OrbitalEllipses
Drives: Attitude
You don't have comp?
I have comp, but no rental coverage. Opted out. I'lll be bitching when I have to pay for a rental.
media bias
worse about forums fatoni Off-Topic Lounge [WARNING: NO POLITICS] 33 04-05-2016 06:07 PM
Photoshoot Turned Into This.... Vicious LED FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 48 04-01-2013 08:03 AM
What's the worse mod you've seen so far? frosty86 Scion FR-S / Toyota 86 GT86 General Forum 43 10-16-2012 10:27 AM
Turned down BRZ today. Le sad Nat BRZ First-Gen (2012+) — General Topics 29 09-30-2012 12:51 PM
Turned 21 today Exhaust Off-Topic Lounge [WARNING: NO POLITICS] 23 07-22-2012 07:23 PM
