Old 03-28-2012, 10:18 PM   #71
Allch Chcar
Drives: N/A
Originally Posted by Jordo! View Post
How the fuck are they going to get another 50 bhp out of that motor? There's no way that much was left on the table without boost.
If so, then I'm certainly intrigued to learn why they didn't just offer a more powerful model to begin with in both manufacturer flavors.
250 bhp puts that car in about the same power:weight group as the 370Z. I'd seriously consider that for my next car.
Okay -- Subie or Toyota or both, bring it on, because now we're talking.
Just so everybody knows again, the 250 was not an official number.
Don't get your hopes up Jordo.
-Allch Chcar
Daily Driver, occasional weekend drifter.
Allch Chcar is offline   Reply With Quote
Old 03-28-2012, 10:43 PM   #72
serialk11r
Drives: '06 AM V8V Coupe
Perhaps a variable length intake could help, the 1LR-GUE has a similar cam setup, no variable timing other than phasing, and its low end torque is comparable to the FA20 while revving 2000 rpm higher.
I guess it could happen, since this isn't meant to be a poser car I think they could sacrifice a little low end torque, but I'm not sure on the low end combustion stability thing, which is really important for an OEM.
Old 03-28-2012, 10:55 PM   #73
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Who said it had to be 250 out of a 2L?
The block has room for 100mm pistons (same bore pitch as the EJ), and the FB it's based on runs a 90mm crank. That's potentially anything up to 2.8L and ~210 ftlbs with similar BMEP.
old greg is offline   Reply With Quote
Old 03-28-2012, 11:07 PM   #74
mrtodd
Techmology.
mrtodd's Avatar
Drives: Scrapped project EH2
250 hp with a 7500 redline is completely plausible from a 1.6T... Here seagull, here seagull... heh...
Also Serial, I gave a few examples of older motors that made close to 85lb-ft/L without direct injection and with lower compression ratios. Remember I was basing it on the BEAMS which was ~80/L with less CR and no direct injection as well as the 2GRFSE which is 79/L and not a dedicated performance motor (also less CR). And also at the gains the FSE 2GR made over the regular FE.
This motor has 170 lb-ft in it easily so long as they are willing to sacrifice the wide, flat torque curve. Like I said, cams (plus supporting vavletrain), revised intake and exhaust geometry and it will be really close to the GT5 220/170 specs if not even better hp...
Thank you. It seems most people on this forum don't realize how potent an NA motor can be. The fact that this motor has the c/r that it does + direct injection opens it up to substantially greater potential than previous cars/engines mentioned. 250 crank HP out of this motor really isn't as big of a stretch as people think.
Subaru can definitely do it...and if not, the aftermarket scene will take it up.
mrtodd is offline   Reply With Quote
Old 03-28-2012, 11:07 PM   #75
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Correct me if I'm wrong, but if there is to be a higher-strung NA version tuned for even more bHP/liter, wouldn't it make more sense to come from Toyota's engineers rather than Subaru?
Toyota does have some experience in making NA high bhp/liter engines (i.e. 2zz-ge and the LFA engine via Yamaha), but Subaru does not (traditionally more inclined to FI).
That being said, whoever does it, it would still be greatly appreciated.
And out of curiosity, while I wouldn't be surprised if the FA20 has variable valve timing, what about something like VTEC or VVTL-i?
daiheadjai is offline   Reply With Quote
Old 03-28-2012, 11:48 PM   #76
86fanatic
Drives: auto
FA20 already uses AVCS (Subaru's VTEC) on both exhaust and intake cams.
86fanatic is offline   Reply With Quote
Old 03-29-2012, 12:00 AM   #77
dimik252
Drives: I want a FT86
how cant you get close 50hp out with Intake, full exhaust and tune? maybe abit aggressive for a daily car but I would want to get at least 50HP more out if I get one.
New cars have so much emissions crap on them.
but anyways I would assume it would be a bigger bore in the sti version.
dimik252 is offline   Reply With Quote
Old 03-29-2012, 12:15 AM   #78
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Everything's a compromise. Yes, of course Subaru or Toyota could make a highly strung engine but does their business model justify it? That is, would enough people purchase the high-strung model to justify the costs involved in making an engine that is both reliable and will meet the emission regs in 200,000 kilometers time? This is a cheap production motor car. (Yes , know cheap is highly subjective but it's like using the word "affordable". It's only affordable if you can afford it. And that's not meant to be funny.)
Instead of a power increase a better performance route would be to lower the car's mass. This would have wider ranging benefits than a power increase. Though more power and less weight would be ideal.
Inflation has raised the price. It is now my 6 cents.
Old 03-29-2012, 12:22 AM   #79
dimik252
Hence why the motor wouldn't be high-strung.
I think there will be some interesting na numbers coming out.
Ether way a 250hp na would sound awesome!
There bound to release a turbo version - its un-Subaru if they don't lol
Old 03-29-2012, 12:27 AM   #80
86design
Attack By Demons
86design's Avatar
Drives: 2022 BRZ (pre ordered)
kinda happy that there not going to turbo charge this car....it wouldn't make any sense...if you were going to turbo charge this car they should of done it in the beginning...i am happy that they will come out with a STI version...
#attackbydemons #imcomingbackbish
86design is offline   Reply With Quote
Old 03-29-2012, 01:01 AM   #81
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
I can think of a long list of worthy performance cars that disprove such logic.
And just use sentences, this aint no AIM.
chulooz is offline   Reply With Quote
Old 03-29-2012, 01:34 AM   #82
DSR2409
Drives: 05 Nissan Sentra Se-r Spec V
As "un-Subaru" as RWD?
DSR2409 is offline   Reply With Quote
Old 03-29-2012, 01:46 AM   #83
Oriental Life
Oriental Life's Avatar
Drives: Forester 2007, BRZ Limited '13
No turbo in the next version? YES! I'll have current one and in time upgrade to the next one. THANK YOU, Subie!
Oriental Life is offline   Reply With Quote
Old 03-29-2012, 02:11 AM   #84
Soravia
Drives: Miata Club
Power adding can be done easily with aftermarket stuff like Rotrex supercharger. I don't see a point of paying $35K (WRX STi price) for CF roof and a few other suspension bits that can be bought better with same money from aftermarket. This will just be a halo project with sale numbers like S2000 was, the real deal will be with the base model. There's nothing exciting about these news, really.
3x 240SX, RX-8 Sport, Sentra Spec V, A4 1.8T Quattro, Miata NB2, Miata NC 2.5
Soravia is offline   Reply With Quote
Report: 6000 BRZ coupes for 2013 model year! ahausheer BRZ First-Gen (2012+) — General Topics 90 03-18-2012 06:43 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
Report: Subaru Coupe STI Model Possible, But Without Turbo Hachiroku BRZ First-Gen (2012+) — General Topics 168 07-28-2011 10:03 PM
Report: Baby Toyota FT-86 also in the works Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 60 05-17-2010 07:41 PM
