#71 | |
i'm sorry, what?
Drives: Canada
Don’t confuse your gearbox ratios with the “final drive” The gearbox (which is a device that amplifies the engine’s power/torque) has ratios that determine the spacing between each gear While the final drive (along with wheel diameter) determines the wheel speed across all the gearbox gears The final drive is the final gear for each the gearbox gears, the final multiplier. You are partially right though, driving IN 6th gear will FEEL like you’re driving in 5th, but that’s about it. The net result will be lower top speeds for each gear but faster acceleration because your engine’s power is being amplified at a greater rate
#72 | |
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
#73 | |
i'm sorry, what?
Drives: Canada
the transmissions converts engine revs into torque at either a fast rate or a low rate, the gears and final drive dictate these rates.
#74 | |
86 = First New Car
Learn to read, before posting. |
#75 | |
i'm sorry, what?
Drives: Canada
learn to read the whole thread before posting and learn to use a comma
#76 |
Drives: FRS
Please play nice
#77 |
Drives: Pavement MT GR86
The gearing in this car at least for the manual is pretty short and close ratio. lighter wheels if you want to spend money. but the best option for a dd is exhaust a tune.
GR86 MT premium
#78 |
Drives: A Potential Traffic Ticket
How'd you get rid of the CEL when you installed the BORLA header? Did you tune it or did you do the defouler?
#79 |
Drives: Raven FRS/c5 Corvette
| Torque Dip | sierra | Scion FR-S / Toyota 86 GT86 General Forum | 68 | 07-22-2013 03:18 PM |
| What torque dip? | pdreams | Engine, Exhaust, Transmission | 44 | 11-12-2012 06:56 PM |
| What socket size and what torque amount for stock alloy wheels? | Takeshi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-01-2012 10:25 PM |
| where is the safest place to park? | enjoi23 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 09-12-2012 08:27 PM |
| Getting a Stock HP and Torque Spreadsheet? | nquillen | Engine, Exhaust, Transmission | 1 | 09-01-2012 04:00 PM |
