Old 04-30-2013, 09:56 AM   #71
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by reeves View Post
What's the difference between doing this and simply driving with your tranny in a lower gear? Like driving in 5th gear instead of 6th on the highway? I'm asking seriously.. isn't this pretty much what a higher final drive does?
Don’t confuse your gearbox ratios with the “final drive”
The gearbox (which is a device that amplifies the engine’s power/torque) has ratios that determine the spacing between each gear
While the final drive (along with wheel diameter) determines the wheel speed across all the gearbox gears
The final drive is the final gear for each the gearbox gears, the final multiplier.
You are partially right though, driving IN 6th gear will FEEL like you’re driving in 5th, but that’s about it.
The net result will be lower top speeds for each gear but faster acceleration because your engine’s power is being amplified at a greater rate
Old 04-30-2013, 12:17 PM   #72
CSI:86
86 = First New Car
Drives: 2013 Pegasus White Toyota 86 GTS MT
A final drive gives no additional actual power to the engine, it only makes the maximum engine power come earlier, rather than later.
CSI:86 is offline   Reply With Quote
Old 04-30-2013, 01:06 PM   #73
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
and where did i say that it gives additional power? Did the word amplify confuse you?
the transmissions converts engine revs into torque at either a fast rate or a low rate, the gears and final drive dictate these rates.
Old 04-30-2013, 01:51 PM   #74
CSI:86
86 = First New Car
The OP CLEARLY states in the title of the thread: "Safest way to get 15%-20% more NA HP and torque vs. stock". Did that confuse you?
Learn to read, before posting.
Old 04-30-2013, 01:59 PM   #75
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the thread went into a discussion of final drivers and gear changes
learn to read the whole thread before posting
and learn to use a comma
Old 04-30-2013, 02:27 PM   #76
wootwoot
Drives: FRS
Please play nice
Old 05-01-2013, 07:07 AM   #77
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
The gearing in this car at least for the manual is pretty short and close ratio. lighter wheels if you want to spend money. but the best option for a dd is exhaust a tune.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 05-01-2013, 09:24 AM   #78
JackSmiley
JackSmiley's Avatar
Drives: A Potential Traffic Ticket
Originally Posted by post_break View Post
Borla header, stock overpipe, test pipe, ISIS exhaust, visconti tune, stock intake I made just shy of 180whp based on Phastek's dynojet.
I figure with an intake, overpipe, and updated tune I could touch 190 on the same dyno.
How'd you get rid of the CEL when you installed the BORLA header? Did you tune it or did you do the defouler?
JackSmiley is offline   Reply With Quote
Old 05-01-2013, 09:33 AM   #79
Obja
Obja's Avatar
Drives: Raven FRS/c5 Corvette
Originally Posted by troek View Post
no ones hit 200 whp na statside yet? bummer man. plenty of 215ish whp tunes over here in japan.
lucky bastards <3
Obja is offline   Reply With Quote
Torque Dip sierra Scion FR-S / Toyota 86 GT86 General Forum 68 07-22-2013 03:18 PM
What torque dip? pdreams Engine, Exhaust, Transmission 44 11-12-2012 06:56 PM
What socket size and what torque amount for stock alloy wheels? Takeshi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-01-2012 10:25 PM
where is the safest place to park? enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 36 09-12-2012 08:27 PM
Getting a Stock HP and Torque Spreadsheet? nquillen Engine, Exhaust, Transmission 1 09-01-2012 04:00 PM
