Old 08-31-2013, 08:21 PM   #71
Dipstik-sportech
Dipstik-sportech's Avatar
Well he hasn't fully moved into the new one from early summer.
Old 08-31-2013, 11:08 PM   #72
dabocx
dabocx's Avatar
Drives: Scion FRS
Originally Posted by Dipstik-sportech View Post
15psi on the gt28. Our pump gas won't allow more boost or timing. Winter plans for some upgrades though.....
Got a dyno chart? I know on alot of dynos for the gt/gtx 28 the car seems to start losing power past 6500 or 7000
dabocx is offline   Reply With Quote
Old 08-31-2013, 11:35 PM   #73
Dipstik-sportech
I didn't take a pic of it when it was up. Lj might have it still.
Old 08-31-2013, 11:40 PM   #74
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by lexusb3 View Post
ay change your turbo man!!!!!!!! get some e85 too i want to see what i will be dealing soon lol
With E85 you will surpass the ability of the OEM fuel system at high boost....been there done that.
cf6mech is offline   Reply With Quote
Old 08-31-2013, 11:44 PM   #75
lexusb3
Drives: FRS
As far as? Pump & injectors... And what's high boost north of 15psi
lexusb3 is offline   Reply With Quote
Old 08-31-2013, 11:47 PM   #76
cf6mech
Originally Posted by Adeets View Post
Didn't Crawford blow 2 engines?
OEM Rod bearings ! ....that's what everyone who truly have pushed this motor 20 psi and up (Crawford ) have had failed. Including me.....guys at 15 to 20 are on borrowed time , how much time is anyone's guess. There is differences of opinions of why OEM isn't holding though. On my second build I'm not taking any chances and running ACL race rod bearings.
Old 08-31-2013, 11:54 PM   #77
cf6mech
Volume
Old 08-31-2013, 11:59 PM   #78
cf6mech
FullBlown
FT86Club Official Vendor
Drives: Scion FRS
Trader Rating: 0 reviews
We are working on a fuel system. That is the main reason why we stopped. We maxed everything out.
So did I and it gets scary lean wise,......a full fuel system upgrade is needed at this point......Don at Accelerated ran into this early on, I do believe before Full Blown.
Old 11-04-2013, 03:01 PM   #79
BRZ?
Drives: 2014 SWP 6MT BRZ
whats the potential output for a built 2L FA20 staying NA?
BRZ? is offline   Reply With Quote
Old 11-04-2013, 04:32 PM   #80
Dipstik-sportech
Not great until cams are released
Old 11-04-2013, 04:38 PM   #81
mike the snake
Talking with my tuner about built blocks, he had his "stage 3" that included a different crank that had different oiling holes and arrangement. I assumed the BRZ/FRS had similar cranks and oiling, so maybe there's something across the board related to the rod bearings and crank oil passages?
Old 11-04-2013, 06:11 PM   #82
FirestormFRS
Anyone did a root cause analysis to see where and how the bearings are failing? Are they deforming due to pressure? Burning due to oil pump not being able to keep up? Until someone does that no one will know why they're failing.
FirestormFRS is offline   Reply With Quote
Old 11-04-2013, 07:10 PM   #83
Dipstik-sportech
Yes this^^^. I mean what says the acl race bearings will even be any better? If it's an oiling issue then they'll burn up as well.
Old 11-04-2013, 07:43 PM   #84
mike the snake
My tuner was telling me the oil holes were drilled differently and possibly more of them and (can't remember exactly) the size of the oil holes were larger on the aftermarket crank.
He said this was only necessary on the BIG HP engines, but what I gathered from our discussion was the aftermarket crank addressed something that the stock crank had an issue with regarding oiling on big HP engines.
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
Full Blown 521hp Stock Motor @ 20psi FullBlown Forced Induction 276 08-31-2016 02:05 AM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Performance! Pure Automotive Forced Induction 181 03-12-2013 02:11 PM
The Results Are In!! Full Blown Stage 1 Kit @ Pure Automotive Pure Automotive Mid-Atlantic 22 02-12-2013 10:13 AM
Initial Review + First Dyno Run for my Full Blown Turbo FRS on Friday, Feb 1 @ 3pm TyperRspec789 Mid-Atlantic 66 02-02-2013 02:25 PM
