Old 01-25-2013, 08:35 AM   #71
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by schtebie View Post
Any idea how much replacement rotors will run?
I'll let you know as soon as I know! Thanks for your patience.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 01-25-2013, 08:37 AM   #72
JRitt
JRitt's Avatar
Originally Posted by Captain Insano View Post
Thanks for estimate! Do you think the rear kit will drop weight as well?
I honestly don't know. The caliper will definitely be lighter, but it will be using a one-piece disc. I should have a rear kit in my hands next week, so I'll definitely dissect it and post info asap.
www.essexparts.com
Old 01-28-2013, 03:08 PM   #73
Ro_Ja
Drives: TOYOTA
Ro_Ja is offline   Reply With Quote
Old 01-29-2013, 08:30 AM   #74
JRitt
JRitt's Avatar
Thanks for the orders gents! :happy0180:
I only have one black caliper kit available from the initial batch. Who wants it? Bueller?
I still have a couple of red caliper kits available from the first shipment.
Thanks.
www.essexparts.com
Old 01-30-2013, 10:22 AM   #75
JRitt
JRitt's Avatar
Hi Guys,
Update...please see caliper pics below with weights. The CP6628 calipers in these systems weigh in at roughly 5.86 lbs. each. Add in another 2 lbs. for the brackets, and you're looking at about 8 lbs. The OEM calipers & bracket weigh 11.6 lbs. Total weight savings on the caliper are going to be at minimum 3 lbs. per side. Discs should shave a few pounds per side as well. So we may be in the minus 6-7 lbs. range per front corner of the car...
www.essexparts.com
The Following 3 Users Say Thank You to JRitt For This Useful Post:
chanomatik (02-04-2013), Ro_Ja (01-31-2013), Slartibartfast (01-30-2013)
Old 01-30-2013, 12:18 PM   #76
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
Not knocking the kit, looks fantastic. However, why wouldn't a person just upgrade to 05-08 sti brakes? The dimensions seem similar, as I would imagine the performance. I is the ignorant.
TouchMyHonda is offline   Reply With Quote
Old 01-30-2013, 01:51 PM   #77
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I have a question for @JRitt
I've seen you comment that if you take your car to a track day, even if it's only once a year, that the dust boots in the calipers will be damaged from the heat. What happens to the Sprint kit type of brakes that don't have dust boots when driven daily in all the weather I have in the northwest? I'd like to get a better brake system, and can't afford two systems, but don't want it to fail if I can prevent it. I realize that if I purchased the Sprint kit that I could just swap back and forth between oem (or the kit in this thread) and Sprint with some wrench turning, but if I was to only use one or the other all the time with the above info, what are your thoughts?
stockysnail is offline   Reply With Quote
Old 01-30-2013, 02:22 PM   #78
OrbitalEllipses
Drives: Attitude
Improper bias and huge weight gain. The STI caliper will NOT remotely fit under stock wheels either. The STI rotor has more thermal capacity, but unless you're buying the expensive stock replacement rotors your vane count is crap.
You can use 04-CURRENT STI brakes up front actually, as long as rotors are 2004 5x100 PCD.
Old 01-30-2013, 02:50 PM   #79
JRitt
JRitt's Avatar
Dust boots could be damaged from heat, but that depends on how hard they are run, who is driving, the track, modifications to the car, etc...a million factors go into that either happening or not happening. There are no guarantees one way or the other. Some people can probably do a whole season on a road kit without hurting the dust boots.
If you're going to daily drive your car in nasty weather and do a track day once in a while, the Formula Kit is the better choice. It will hold up better in consistent nasty weather. When I say nasty weather, I'm talking about road salt being used. As I mentioned in another thread, road salt eats aluminum parts. It will attack the hats, brackets, and calipers in any kit...road or race. Rain doesn't really matter. Rain really won't hurt one type of kit more than the other. It's a non-issue in my opinion.
It will still offer most of the same advantages of the Competition System (greater heat capacity, lighter weight, better feel, etc.). It just doesn't take those advantages quite to the extreme level as the Competition Systems. You don't save quite as much weight, you won't have quite as many race pad options, you won't have stainless steel pistons, you won't have anti-knockback springs. Those things matter a lot when you're trying to scratch a tenth of a second from your lap time, save the last 3-5 lbs., or if you're going to be constantly cracking discs and burning up pads at the track. They don't matter as much if you're mostly going to be driving to work.
The Formula Kit featured in this thread is going to be a killer track upgrade over stock. It has similar features to just about any of the best big brake kits that have been offered in the aftermarket traditionally. The Competition Systems are something that the aftermarket has never seen before. They are just beefed up a bit for a full out track assault, without much consideration for any other usage.
www.essexparts.com
The Following 5 Users Say Thank You to JRitt For This Useful Post:
ATL BRZ (02-11-2013), chanomatik (02-04-2013), ICantAffordAnLFA (01-30-2013), Slartibartfast (01-30-2013), stockysnail (01-30-2013)
Old 01-30-2013, 03:20 PM   #80
ICantAffordAnLFA
ICantAffordAnLFA's Avatar
Drives: Brz, Legacy
Choices , choices
Trackday ride with built motor
Mods: Going, Stopping, Handling
Parts: CP, Pauter, Sprintex, Ecutek, Milltek, STI, Rays, Defi, Essex AP Racing, Bilstein, Whiteline, Perrin, RacerX
ICantAffordAnLFA is offline   Reply With Quote
Old 01-30-2013, 04:08 PM   #81
JRitt
JRitt's Avatar
Originally Posted by ICantAffordAnLFA View Post
Choices , choices
Fortunately, you really can't lose regardless of which kit you choose from our offerings. You're going to get the highest quality AP Racing calipers and discs, from the company that supplies the top race series' in the world. It's just a matter of how extreme you want to go. That's the beauty of having these choices.
www.essexparts.com
Old 01-30-2013, 04:26 PM   #82
OrbitalEllipses
Drives: Attitude
Only thing you're losing is a fat chunk of change, rofl.
:happy0180:
I'm going to bug you everyday until these are here Jeff.
Old 01-30-2013, 05:34 PM   #83
Captain Insano
Thanks for weighing those and the additional info as usual JRitt!! I would love it if this kit was in the area of 6-8 lbs loss per front corner. I still am sooo torn between competition sprint and this kit. That -10 per front corner in the sprint has me drooling.
Old 01-30-2013, 07:00 PM   #84
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
Hi Guys,
So, the black paint weighs more. I guess I'll have to go with red!
(Still saving my pennies... it may take a while)
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
ap racing, brakes, discs, essex, pads
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Stock wheels, +38 front, +33 rear post_break Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 03-11-2013 09:38 PM
Introducing: AP Racing Six Piston, 14 inch Formula Road Brake Kit JRitt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 34 01-23-2013 04:18 PM
