Old 10-06-2018, 01:40 PM   #71
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
I don’t understand the point of this. Are people breaking driveshafts? This can’t help with reving much if the diameter is larger, even if it is lighter. Considering weight is coming off practically the lowest part of the car, the COG might actually be slightly higher now. Is this just to lose 11 pounds of weight?
Old 10-09-2018, 10:07 PM   #72
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
These are indeed available again! Thank you to those who have waited it out and we appreciate the orders.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
Joveen (11-03-2018), mistople (10-11-2018), mrderp (11-28-2018)
Old 06-01-2020, 03:26 PM   #73
Jeff Gray
VizMark Performance
Jeff Gray's Avatar
Drives: 2014 Scion FR-S Monogram Series 6MT
MY driveshaft shop carbon shaft makes a very noticeable noise first second and sometimes third gear under load like when engine breaking and I want know if this shaft has the same issue.????????
Regards,
Jeff Gray
904-566-5505
VizMark Performance
Jeff Gray is offline   Reply With Quote
Old 06-02-2020, 01:08 AM   #74
86TOYO2k17
Drives: 2017 toyota 86
My DSS carbon DS makes no noise. You try rotating it?
Old 06-02-2020, 09:04 AM   #75
AxisPower
Drives: 23 GT4RS
You sure its not your transmission? Do you a lightweight flywheel? When I had an ORC clutch going to a one piece driveshaft made my gear train rattling more noticeable especially under decel.
AxisPower is offline   Reply With Quote
Old 06-11-2022, 06:08 AM   #76
JOSEC
Drives: 2014 Subaru BRZ WRB
Hey Eric,
I was wondering why you decided to stop production on the manual version of these. And why you guys just have automatic versions. I've been wanting one and have been looking for one in the used market for the past 6 months and haven't had any luck haha.
JOSEC is offline   Reply With Quote
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft F1point4 DIY (Do-It-Yourself) Guides 67 04-17-2021 06:21 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 06:23 AM
New The Driveshaft Shop Carbon Fiber 1-Piece Driveshaft Evasive Motorsports Engine, Exhaust, Transmission 1 09-24-2013 03:27 PM
