#813 |
Drives: 3 series
+35 or +45 in the rear????
Mostly a track / weekend car. Going with 8" wide 17" wheels with 225/45 tires. +45 in the front. Would the rear be best with +35 or +45? In other words, will +35 stick out so much as to look silly. Or will I get interference if I change to larger rubber in the future? The whole rear seems very narrow at stock offsets with 8" wheels. |
#814 | |
VehicleDynamicsSpecialist
Drives: iG FR-S
That way you can rotate tires front to back. No interference. |
#815 | |
Drives: iG FR-S
However, I know what you meant; it does not add significant negative camber up front like you see in the rear. |
#816 | |
Drives: Black GTS
#817 |
Drives: iG FR-S
#818 |
Drives: Black GTS
Im not sure what tyre size to use on the staggered setup. If its easier to go square im happy to do that, just trying to figure out the offsets etc and its melting my brain.
My options are 17x8(+40/+45), 18x8.5(+45), 18x9.5(+45) So whatever is best using whats available, be that square of staggered. And best tyre fitment. Ive spent hours and hours trying to work it out myself and its just one of those things ill never "get". |
#819 | |
Drives: iG FR-S
Recommended tires for OE height: 215/45 f&r or 245/40 f&r The following are slightly shorter or taller: 225/45, 235/40 or 255/40 f&r. 8.5 (45) front and 9.5 (45) rear would work fine for a staggered fitment. Recommended tire size: 215/40-18 front 245/35-18 rear Or 225/40-18 front 255/35-18 rear Keep in mind these are all personal preference and should be left up to the end user/owner to make such decisions. Please do your own research to determine fitment for your vehicle. |
| The Following User Says Thank You to ill86 For This Useful Post: | Suffa (01-15-2013) |
#820 |
Drives: 2013 86 GTS - Pegasus White
Hey Guys,
Can anyone please confirm if 235/40/18 will be an ideal fit for an 18/8.75/+33 offset (square) without fender modding. I plan on lowering between 1"-1.5". Thanks
#821 |
Drives: 2013 FRS Whiteout
My new wheel setup is on the way, 18x8.5 +35 Front 18x9.5 +30 Rear with 245/35/18 front and 255/35/18 rear. Car is lowered 1 inch, I've done a lot of research and asked a lot of people with experience and I think this is going to fit flush with no rubbing issues or camber adjustment, I'll post pics when they're on next week!
#822 |
Drives: '13 BRZ Ltd WRB
Should not be an issue. I have 235s and my wheels are 9" and +28. I'm not lowered, but if it was going to rub, I would have made it rub by now.
#823 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#824 |
Drives: 2013 Ultra Marine Blue FR-S
I'm thinking about some XXR's and want to go staggered. Looks like 18x9.75 +20 is my only option for the 530's (rears) will that clear with no rubbing? Or will rear fenders be required to roll? Also planning on sitting her down on Sportlines, which are about 1.4" drop all around.
#825 | |
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
See for yourself. |
#826 | |
| Tags |
| fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width |
| Determining the proper width size of the tire | CyberFormula | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 49 | 05-23-2014 10:11 AM |
| Correct tire width for each wheel width | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 08-16-2012 03:03 PM |
| TIRE SIZE CALCULATOR | White64Goat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 08-15-2012 03:31 AM |
| Tire Width vs Wheel Width | Synack | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 40 | 08-13-2012 12:21 AM |
