Old 01-14-2013, 12:15 PM   #813
Z-PDX
Z-PDX's Avatar
Drives: 3 series
+35 or +45 in the rear????
Mostly a track / weekend car.
Going with 8" wide 17" wheels with 225/45 tires.
+45 in the front.
Would the rear be best with +35 or +45? In other words, will +35 stick out so much as to look silly. Or will I get interference if I change to larger rubber in the future?
The whole rear seems very narrow at stock offsets with 8" wheels.
Z-PDX is offline   Reply With Quote
Old 01-14-2013, 02:55 PM   #814
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
If it is mostly a weekend/track car as you say, then go +35 front and rear. An 8" +35 is better IMO and still won't stick out too far in the rear or look silly. With a little negative camber up front it will perform well.
That way you can rotate tires front to back.
No interference.
ill86 is offline   Reply With Quote
Old 01-14-2013, 02:58 PM   #815
ill86
ill86's Avatar
Drives: iG FR-S
Originally Posted by digital_assassin View Post
If you are worried about the front I don't think lowering changes the geometry. Only the rear gains negative camber with a drop.
Lowering certainly affects geometry and roll center.
However, I know what you meant; it does not add significant negative camber up front like you see in the rear.
Old 01-14-2013, 09:36 PM   #816
Suffa
Drives: Black GTS
Originally Posted by Suffa View Post
Im waiting on prices but im thinking of a setup of front: 18x8.5(+45), rear: 18x9.5(+45). Saw earlier here someone with same setup and the reply was it would fit nicely. If i go this setup what tyre sizes i need? 235/40 all round ok?
If i decide to go 17"s though my options are 17x8(+40 or +45) and 17x9(+45). If i go the 17's whats the best setup and tyre size selection?
Edit: Will be dropped 1"
Bump for an answer.
Suffa is offline   Reply With Quote
Old 01-15-2013, 01:37 AM   #817
ill86
ill86's Avatar
Drives: iG FR-S
Bump for an answer.
Why do you want to stagger the wheels but not stagger the tires?
Old 01-15-2013, 02:00 AM   #818
Suffa
Drives: Black GTS
Im not sure what tyre size to use on the staggered setup. If its easier to go square im happy to do that, just trying to figure out the offsets etc and its melting my brain.
My options are 17x8(+40/+45), 18x8.5(+45), 18x9.5(+45)
So whatever is best using whats available, be that square of staggered. And best tyre fitment.
Ive spent hours and hours trying to work it out myself and its just one of those things ill never "get".
Old 01-15-2013, 03:26 AM   #819
ill86
ill86's Avatar
Drives: iG FR-S
A square 17x8(40 or 45) will work fine.
Recommended tires for OE height:
215/45 f&r or 245/40 f&r
The following are slightly shorter or taller:
225/45, 235/40 or 255/40 f&r.
8.5 (45) front and 9.5 (45) rear would work fine for a staggered fitment.
Recommended tire size:
215/40-18 front 245/35-18 rear
Or
225/40-18 front 255/35-18 rear
Keep in mind these are all personal preference and should be left up to the end user/owner to make such decisions. Please do your own research to determine fitment for your vehicle.
The Following User Says Thank You to ill86 For This Useful Post:
Suffa (01-15-2013)
Old 01-16-2013, 09:11 AM   #820
white_knight
white_knight's Avatar
Drives: 2013 86 GTS - Pegasus White
Hey Guys,
Can anyone please confirm if 235/40/18 will be an ideal fit for an 18/8.75/+33 offset (square) without fender modding. I plan on lowering between 1"-1.5".
Thanks
white_knight is offline   Reply With Quote
Old 01-16-2013, 12:07 PM   #821
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
My new wheel setup is on the way, 18x8.5 +35 Front 18x9.5 +30 Rear with 245/35/18 front and 255/35/18 rear. Car is lowered 1 inch, I've done a lot of research and asked a lot of people with experience and I think this is going to fit flush with no rubbing issues or camber adjustment, I'll post pics when they're on next week!
Pure Automotive is offline   Reply With Quote
Old 01-16-2013, 12:57 PM   #822
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Originally Posted by white_knight View Post
Hey Guys,
Thanks
Should not be an issue. I have 235s and my wheels are 9" and +28. I'm not lowered, but if it was going to rub, I would have made it rub by now.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-16-2013, 01:07 PM   #823
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Keep me posted as my rears are 9.5" +27. I plan on throwing 235's out back with my fitment but I push 245s if possible. I'll be quite a bit lower though
Sent from my PC36100 using Tapatalk 2
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 01-16-2013, 01:37 PM   #824
dun3
dun3's Avatar
Drives: 2013 Ultra Marine Blue FR-S
I'm thinking about some XXR's and want to go staggered. Looks like 18x9.75 +20 is my only option for the 530's (rears) will that clear with no rubbing? Or will rear fenders be required to roll? Also planning on sitting her down on Sportlines, which are about 1.4" drop all around.
dun3 is offline   Reply With Quote
Old 01-17-2013, 01:45 AM   #825
Calidrifter
@Executive_chicken
Drives: Firestorm FR-S, Audi A3 E-tron
http://www.ft86club.com/forums/showp...70&postcount=1
See for yourself.
Club 4AG | Apex'i | HKS | GrimmSpeed | TRD | Beat Sonic | ENKEI | Cusco | Fujitsubo
Originally Posted by Jyn View Post
That guy, like me after BBQ Thursdays, is full of shit.
Calidrifter is offline   Reply With Quote
Old 01-17-2013, 03:41 AM   #826
dun3
dun3's Avatar
Originally Posted by Calidrifter View Post
Yeah, I saw that. Looked like he was on stock height. Or is he lowered? Just wondering if fender rolling would be required.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
