#772 | |
Did the install DIY as well. Car has been running great since last April no problems. I took my time over two days to do it and followed the instructions exactly. I did the JROC at the same time. It was literally my first time wrenching on a car other than changing LEDs and taillights. I recommend reading the manual thoroughly first and fully understanding it before beginning. Have fun with it! |
| The Following User Says Thank You to dj2020 For This Useful Post: | Aaronimoe (01-30-2016) |
#773 |
Drives: 2015 BRZ
I got a sharpie and went through the parts that were in the plastic, labelling each one by step number. Pre-assembled the tubing so I'd understand how it went together.
Helpful bumper removal: http://www.ft86club.com/forums/showthread.php?t=8788 http://www.ft86speedfactory.com/mish...stat-1390.html [ame="https://www.youtube.com/watch?v=mMdIWZLUEj0&feature=player_embedded"]SPECDTUNING INSTALLATION VIDEO: 2013 SCION FR-S LED PROJECTOR HEADLIGHTS - YouTube[/ame] http://www.ft86club.com/forums/showp...6&postcount=59 Installation shown here: http://speed.academy/scion-frs-subar...install-guide/ Good pictures of the s/c bracket here: http://www.ft86club.com/forums/showthread.php?t=52992 The oil cooler: http://www.ft86club.com/forums/showthread.php?t=40020 Also, the way the Rotrex lines went confused me. It's btm of reservoir -> filter -> passenger side of s/c Driver's side of s/c -> cooler -> top of reservoir Top of reservoir must be even with or higher than top of the s/c I also purged the crap out of the Rotrex line. I wanted to be darn sure it didn't start dry, so I did it twice, pushing air down the reservoir & through the (loose) passenger-side banjo bolt, until there was blue oil oozing out nicely. The only problem I had with the install was I forgot to put that big Styrofoam thing back when I put the bumper back (I had put it in the trunk for safe keeping), then the tubing around the MAF tube popped off a couple of times. Other than that, it went well ![]() hth -Mark |
#774 | |
How did you finally get the tube to keep from popping* off? was it just an issue with a clamp not being correctly installed? Edit* Also, I didn't know about that TSB! man maybe I should go do that before my install. I won't be getting the oil cooler either. Maybe later down the road cause I don't ever plan on tracking. Last edited by Aaronimoe; 01-31-2016 at 12:03 PM. |
#775 | |
Drives: 2015 BRZ
http://www.ft86club.com/forums/showp...postcount=3108 |
| The Following User Says Thank You to LS1M For This Useful Post: | Aaronimoe (01-31-2016) |
#776 | |
In that picture you linked, is it installed correctly or incorrectly? the clamp looks like it can be described as being in the front of the hump in that picture. |
#777 |
Drives: Neptune GR86
Think of the hump as something to help prevent the hose popping off. You want the clamp before the hump.
| The Following User Says Thank You to Andrew025 For This Useful Post: | CSG Mike (01-31-2016) |
#778 |
#779 |
Drives: 2013 BRZ Limited M/T
The tubes have ridges. Clamps go behind them to prevent slippage.
| The Following User Says Thank You to Bramick For This Useful Post: | CSG Mike (01-31-2016) |
#780 |
Drives: 2015 BRZ, 2005 STI
#781 | |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
#782 |
Senior Misanthrope
Don't forget accidentally opening up your AC system and flooding the garage with refrigerant
#783 |
Drives: 2015 Series.Blue BRZ
YOU WEREN'T EVEN THERE
Sent from my MotoE2(4G-LTE) using Tapatalk
| The Following User Says Thank You to ScionOfHorus For This Useful Post: | Bramick (02-01-2016) |
#784 |
| Tags |
| jackson racing, jrsc, rotrex, supercharger, track |
| Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 01:06 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 10:04 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 04:05 PM |
| HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 04:28 PM |
| Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 03:29 PM |
