Old 01-29-2016, 10:11 PM   #771
CSG Mike
CSG Mike's Avatar
Originally Posted by Aaronimoe View Post
Who here did a DIY install? what kind of problems did you run into (both during and after install)?
also whats the easiest/cheapest way to get a boost and oil temp gauge set up?
Any obd2 reader device. Phone app + bluetooth is popular.
Aaronimoe (01-29-2016)
Old 01-30-2016, 11:56 AM   #772
dj2020
Did the install DIY as well. Car has been running great since last April no problems. I took my time over two days to do it and followed the instructions exactly. I did the JROC at the same time. It was literally my first time wrenching on a car other than changing LEDs and taillights. I recommend reading the manual thoroughly first and fully understanding it before beginning. Have fun with it!
dj2020 is offline   Reply With Quote
The Following User Says Thank You to dj2020 For This Useful Post:
Aaronimoe (01-30-2016)
Old 01-30-2016, 05:40 PM   #773
LS1M
Drives: 2015 BRZ
I got a sharpie and went through the parts that were in the plastic, labelling each one by step number. Pre-assembled the tubing so I'd understand how it went together.
Helpful bumper removal: http://www.ft86club.com/forums/showthread.php?t=8788
http://www.ft86speedfactory.com/mish...stat-1390.html
[ame="https://www.youtube.com/watch?v=mMdIWZLUEj0&feature=player_embedded"]SPECDTUNING INSTALLATION VIDEO: 2013 SCION FR-S LED PROJECTOR HEADLIGHTS - YouTube[/ame]
http://www.ft86club.com/forums/showp...6&postcount=59
Installation shown here: http://speed.academy/scion-frs-subar...install-guide/
Good pictures of the s/c bracket here: http://www.ft86club.com/forums/showthread.php?t=52992
The oil cooler: http://www.ft86club.com/forums/showthread.php?t=40020
Also, the way the Rotrex lines went confused me. It's
btm of reservoir -> filter -> passenger side of s/c
Driver's side of s/c -> cooler -> top of reservoir
Top of reservoir must be even with or higher than top of the s/c
I also purged the crap out of the Rotrex line. I wanted to be darn sure it didn't start dry, so I did it twice, pushing air down the reservoir & through the (loose) passenger-side banjo bolt, until there was blue oil oozing out nicely.
The only problem I had with the install was I forgot to put that big Styrofoam thing back when I put the bumper back (I had put it in the trunk for safe keeping), then the tubing around the MAF tube popped off a couple of times. Other than that, it went well
hth
-Mark
LS1M is offline   Reply With Quote
The Following 2 Users Say Thank You to LS1M For This Useful Post:
Aaronimoe (01-30-2016), menikmati (01-30-2016)
Old 01-30-2016, 06:58 PM   #774
Aaronimoe
hth
-Mark
Thanks! definitely going to use a lot of this.
How did you finally get the tube to keep from popping* off? was it just an issue with a clamp not being correctly installed?
Edit*
Also, I didn't know about that TSB! man maybe I should go do that before my install.
I won't be getting the oil cooler either. Maybe later down the road cause I don't ever plan on tracking.
Aaronimoe is offline   Reply With Quote
Old 01-31-2016, 12:00 PM   #775
LS1M
Drives: 2015 BRZ
You have to put the clamp "behind" the hump
http://www.ft86club.com/forums/showp...postcount=3108
The Following User Says Thank You to LS1M For This Useful Post:
Aaronimoe (01-31-2016)
Old 01-31-2016, 02:38 PM   #776
Aaronimoe
Sorry I just have to clarify,
In that picture you linked, is it installed correctly or incorrectly? the clamp looks like it can be described as being in the front of the hump in that picture.
Old 01-31-2016, 03:51 PM   #777
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Think of the hump as something to help prevent the hose popping off. You want the clamp before the hump.
The Following User Says Thank You to Andrew025 For This Useful Post:
CSG Mike (01-31-2016)
Old 01-31-2016, 05:03 PM   #778
Aaronimoe
So in that picture in the previous link, the clamp is in the correct position?
Old 01-31-2016, 05:10 PM   #779
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
The tubes have ridges. Clamps go behind them to prevent slippage.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following User Says Thank You to Bramick For This Useful Post:
Old 01-31-2016, 06:09 PM   #780
menikmati
Drives: 2015 BRZ, 2005 STI, 2024 Type R
I think @Aaronimoe is unclear on what constitutes as "behind" or in "front" of the hump in regards to the picture.
@Bramick and @Andrew025 explained it well.
menikmati is offline   Reply With Quote
Old 02-01-2016, 02:29 AM   #781
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
The picture looks right to me. Think about which way the hose would pop off. You'd want the clamp positioned so that the hump is hitting the clamp as it tries to slide off.
Old 02-01-2016, 12:50 PM   #782
kch
Senior Misanthrope
kch's Avatar
Originally Posted by ScionOfHorus View Post
Most did I think.
Clamping hoses on properly, and priming the SC were my biggest issues.
I use and obd2 gauge for oil temp. Don't need a boost gauge because it's an SC, you can't ever over-boost.
Don't forget accidentally opening up your AC system and flooding the garage with refrigerant
Old 02-01-2016, 01:28 PM   #783
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
YOU WEREN'T EVEN THERE
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
The Following User Says Thank You to ScionOfHorus For This Useful Post:
Bramick (02-01-2016)
Old 02-12-2016, 09:35 PM   #784
Aaronimoe
Did you confuse it with something else? which part of the install was this because I can see my self doing something like that.
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
