Old 10-09-2014, 04:39 PM   #7673
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by Robftss View Post
Good to hear it arrived.
"I hope it will do the job".....it is the same as all other 50 units before you.
The website has a 2 view ~scale drawing with dimensions.
Gauge is appropriate to its function.
LMK how it goes! *Fresh batteries need a few days of DD cycling to format.
Rob.
Just pointing out that it looked larger to me in the pictures. And you left out the important part of the quote: "I hope it will do the job :P". Wherein the :P converts a concern into sarcasm.
I just thought the .5 pack wires would be the same size as the 1.0 pack wires, but I guess the current output from the .5 pack is much smaller than the full size pack. Not much of a problem, I'll just cap'em and zip tie them to the harness to keep them out of the way. I will say that I think you need a stronger glue on the .5 battery block. It may be intentional to allow for inspection and/or maintenance, and once it is taped to the batteries it won't matter, but the bottom plate to the block just fell off when I took it out of the bag. It stuck back together with little pressure, but just thought I'd point it out.
Old 10-09-2014, 07:58 PM   #7674
07jazzrs5gt86
Drives: Firestorm 86
Great job on packaging the items Rob
Can't wait til saturday for the install
Thanks rob and fenton
07jazzrs5gt86 is offline   Reply With Quote
Old 10-09-2014, 11:06 PM   #7675
Target70
Target70's Avatar
was a printed instruction pack supposed to come with the kit or do we just go to the Phantom site?
Old 10-09-2014, 11:09 PM   #7676
fenton
I don't believe it is. The most up to date instructions are on the website.
Thanks
fenton is offline   Reply With Quote
Old 10-10-2014, 02:42 AM   #7677
predator800
Drives: 2015 Scion FRS
Full throttle Electric Supercharger Build Thread
Ok believe or not I read the whole thread. Information overload. I came across it while looking for information about the Jackson racing supercharger but never made it there . I just want to make sure I'm getting my information right. The tq250 produces 205hp on 91 octane? The tq300 is still secretive but should be available this spring?
Fenton: nice work on keeping this thread going. This is the best read on cars I can afford in a long time. Being I'm from Saskatoon with family I'm Calgary, you still willing to give people rides to check out that supercharger.
Rob: great job on such an innovated product.
I'm looking at buying an frs in the spring and was just doing my home work because let's face it , stock $uc/$.
Edit: I don't mean the car $uc/$ stock just I don't like owning anything stock. Stock $u /$ is just motor sports saying in my world.
predator800 is offline   Reply With Quote
Old 10-10-2014, 03:05 AM   #7678
Target70
Target70's Avatar
researching upgrades before you own the car. you're my kind of peoples
Also fenton, I couldn't hold back so I did most of the install in my driveway. I don't have the batteries here so I will have to grab them later, but what are the "do nots" I should know about? I remember something about not turning on the system while moving? or was it don't turn it on under WOT? I would assume it's don't turn it off or on under WOT, but as there isn't really a usage guide I want to make sure I don't mess anything up.
Old 10-10-2014, 05:13 AM   #7679
raven1231
With the new switch it should turn off and on with the car so no worries really
Old 10-10-2014, 06:31 AM   #7680
Target70
Target70's Avatar
True, but I'm thinking about the out of the ordinary scenarios. Like I know I shouldn't hit it under ~2000 rpm in high gear, maybe even 2500. I think I shouldn't turn the system on/off while moving due to the DR calibration (I'm guessing on this one). I shouldn't turn the system on/off while activated or a spike may kill the controller. I just want a list of "do not do this" because I test things out by experimenting. Even if I leave it on and the relay turns it on/off by itself, I'll probably find a way to do something I shouldn't. Plus I think something like this should be sent out with the installation guide anyway. As I kinda consider myself a beta tester, I want to offer feedback or concerns that could go to making the product better.
Old 10-10-2014, 07:47 AM   #7681
WNDSRFR
Drives: FR-S,GTI
My biggest "do not" would be: do not forget to tie wrap the harness away from the exhaust manifold (header). Or it will get melted.
Old 10-10-2014, 10:10 AM   #7682
fenton
Do not go WOT below 2krpm in 4th 5th or 6. In 5th and 6th I would even say do not go WOT until above 3k. You will see what I mean when you do it one time by accident. It technically works just fine but it is soooo much stress on the engine.
Turning the system on and off while driving normally is totally fine. You don't want to turn it off or on when accelerating...especially at WOT.
The system is actually very powerful so learning how that power comes on is key to mastering it. For example.... In stock form I could do a left turn WOT and the back end would not step out unless I flicked the car on purpose. With the phantom on this thing will light the tires up all day
Old 10-10-2014, 12:38 PM   #7683
predator800
Yes. I usually build sleds and I usually have all the parts before the new sled arrives. My friends think I'm crazy because I'll chop something up before any miles are on it. This will be the first car I build. The ESC seams like it would be a nice fit in this build.
Old 10-10-2014, 01:12 PM   #7684
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Parts are on the truck to be delievered today. @DAEMANO What did you want me to add to the video? Im going to be redoing the full install so its going to be fun. I get to reinstall for the fourth time. Woot woot.
Installed Mods:
Old 10-10-2014, 01:28 PM   #7685
DAEMANO
Time Traveller
Originally Posted by Sojhinn View Post
Parts are on the truck to be delievered today. @DAEMANO What did you want me to add to the video? Im going to be redoing the full install so its going to be fun. I get reinstall for the fourth time. Woot woot.
Nice going!
I'm sure you have lots of this stuff, but this is what most comes to mind.
1. Captions/call-outs with arrows pointing at notables would be great.
2. Most logical order of installation (specifically where you noted about wiring the batteries in series to prevent arching).
3. Best practice for attaching the controller to the engine bay with the provided bolts and rubber grommet.
4. Best practice for attaching the compressor to the factory airbox for near flush fit and aligning it with the TB(?) to ensure proper fit and airflow.
5. Highlight (once again) securing the arm switch/voltmeter display wires well away from the overpipe (including myself I think there were 3 maybe 4 failures here).
6. ESC boot up audible indicatiors (just the correct state and fault code "beep" series (if you can re-create it for the video).
7. The process for resetting "DR Sensor" (i.e. where and when to blow).
8. Minimal uninstall for "on-road" use <cough dealer visit>
9. List of necessary tools and their dimensions (for wrenches/sockets).
10. A non vertigo-inducing shot of the throttle pedal switch mounting point.
11. You running against a stock '86 if anyone cares to volunteer
That's about it for now. I'll PM if anything else comes to mind.
Old 10-10-2014, 01:32 PM   #7686
fenton
Originally Posted by DAEMANO View Post
Nice going!
4. Best practice for aligning the compressor to ensure proper fit and airflow.
Plus one on the run with stock. You could either start or finish with the video with that. That would stop all those "this doesn't work"
I would say the start after you introduce it...."this is the performance you get"
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
