Old 10-07-2014, 09:59 AM   #7659
DAEMANO
Time Traveller
Originally Posted by WNDSRFR View Post
I don't know about 91 but I've switched back and forth between E85 and 93 a few times and I don't really feel that much of a difference. In fact I kinda prefer the 93 because E85 is so rare here and the price of gas is coming down.
The difference I've felt between CA91 and E85 is dramatic. I'd even go as far to say that if you don't feel much of a difference between the two maybe there was something not right with your setup.
Old 10-07-2014, 11:04 AM   #7660
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
I can concur on this. The car is much more beastly on e85.
Installed Mods:
Old 10-08-2014, 07:36 AM   #7661
WNDSRFR
Drives: FR-S,GTI
I don't use 91. I use 93.
Is there anyone else who has tried the 93 and e85 tunes with the ESC?
I would like to hear your opinions on the subject. I guess my butt dyno isn't as sensitive as others.
Old 10-08-2014, 10:50 AM   #7662
DAEMANO
Time Traveller
I was using CA91+Torco Acellerator boosting me to about 99-101 octane. The torco certainly made the car run smoother and locked in my IAM at 1.0 so I know I was getting max power out of my current setup. Still e85 smashed that on performance.
Old 10-08-2014, 11:16 AM   #7663
WNDSRFR
Drives: FR-S,GTI
Hmmm
I guess I'll have to do some empirical testing. Right now I am on 93. I think I'll log some time Vs. speed runs then do the same after switching back to E85. And see what the difference is. One thing that I have noticed is temperature has a large effect on power. And when I was on alcohol it was over 90 degrees everyday. After I changed back to 93 the temperature has been quite a bit cooler.
So, when I do my comparison runs I will also record ambient temp and atmospheric pressure and make sure the conditions are comparable.
Old 10-08-2014, 12:51 PM   #7664
raven1231
Hmmm
Temp plays a huge role
Old 10-08-2014, 02:45 PM   #7665
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
remember I'm still NA, and I only ran 1 tank of 93 after installing my OFH, and flashing my stage 2 tune, before jumping to E85, But by comparing my logs: 3rd gear pull from 2k rpm to ~7200 rpm, I shaved about 2 seconds off of the time on E85, BUT, IAT was ~30 degrees higher on my 93 run. I noticed about a 1.5 second quicker time on E85 vs my 93 stage 1 run with no header, but IAT was only 10 degrees higher for the 93 on that run. I can post my logs, if anyone want's an extra data set to work with.
also did you guys have to sign for your package from Rob? It is supposed to be here sometime this week (I don't know how as it is still showing it being in customs), but I need to figure out if I have to be home to get it or if they will leave it at my door.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 10-08-2014, 03:05 PM   #7666
abraxis
Drives: many
And E85 won't turn your heads orange...
abraxis is offline   Reply With Quote
Old 10-08-2014, 04:49 PM   #7667
Sojhinn
Sojhinn's Avatar
Btw- still waiting on my parts for the install video
Installed Mods:
Old 10-08-2014, 05:40 PM   #7668
raven1231
I didn't but I was an earlier adopter/ in the first batch. Not sure if it has changed.
Old 10-08-2014, 07:13 PM   #7669
Target70
Target70's Avatar
Just filled up after my first tank of 100% E85. I dropped from 26 mpg on 93 down to 20 mpg.. and I thought I was being conservative with the throttle. I'll probably be jumping back to 93, but want to hold off until after I test out the Phantom on it. I'm already having trouble starting the car in the morning due to the cold (2 to 3 attempts before It will idle without dying, and I'm in GA). I put 1 gallon of 93 in with this batch of E85, but that is a pain in the @$$ for multiple reasons. Hopefully the ESC will make enough of a difference that I don't really notice.
Old 10-09-2014, 11:58 AM   #7670
TM
TM's Avatar
Drives: DGM BRZ 6MT
Full throttle Electric Supercharger Build Thread
I've used both 93 and e85. While I can't really remember if I noticed a significant at WOT between the two, it definitely had more power at partial throttle when the ESC isn't activated. Night and day difference. The engine also felt and sounded much smoother on e85.
TM is offline   Reply With Quote
Old 10-09-2014, 03:48 PM   #7671
Target70
Target70's Avatar
Got my Phantom in today. It was well packaged and protected. The motor is smaller than I thought it would be, (I hope it will do the job :P). I'll inventory everything when I get off work tonight, but probably won't be able to install until this weekend. The .5 pack wires are a much smaller gauge than I expected so I will not use them for anything. I plan to hook up the system with a single dump pack for the first few weeks to make sure everything is working properly, before I modify/upgrade with any extra batteries. It will have to be slightly different than the normal instillation due to my configuration. I'm looking forward to this weekend and hooking everything up.
Old 10-09-2014, 04:05 PM   #7672
Robftss
Drives: VW
Good to hear it arrived.
"I hope it will do the job".....it is the same as all other 50 units before you.
The website has a 2 view ~scale drawing with dimensions.
Gauge is appropriate to its function.
LMK how it goes! *Fresh batteries need a few days of DD cycling to format.
Rob.
Robftss is offline   Reply With Quote
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
