#743 | |
Drives: '13 DGM BRZ Limited
#744 |
Drives: Neptune GR86
#745 |
Drives: Toyota 86 GTS
Don't worry, no key
![]() This is what happens when you flash with no pants.
#746 |
Thanks. . found the link about running that map on a stock car. . personally I still wouldn't do it, but it's his car so whatever. P0456 is an evap leak so it's most likely your gas cap. Make sure the rubber o-ring is there and that you hear the cap click when you close it. |
#747 |
Hahah, I did that once too.
#748 | |
#749 | |
your log looks ok , bit of knock arround 2000 rpm caused iam to drop to 0.98, and fuel trims look a bt high around 10% was that first tank of e85 ? with soe resdua petrol Last edited by steve99; 10-03-2014 at 06:14 PM. |
#750 | |
I have been running E85 for awhile now, I flashed to V2.06 a few weeks ago. When I was running V2.0 Beta I never had the light pop on. The light only pops on when I start car...never when im driving. Thank you!
ScionFrsFan
#751 | |
there was no changes between v2 beta and non beta car may have just deveped a fault |
The Following User Says Thank You to steve99 For This Useful Post: | ScionFrsFan (10-04-2014) |
#752 |
is better than you
Drives: 2013 raven FRS
updated to 2.0, installed the new xml files and reflashed my car, but whenever i plug in the oft i cant view the live data on the OFT. It just stays on connecting to cars ecu. Anyone got an idea?
#753 | |
you need to download the new template file from the oft downloads page and manually apply it as per instuctions on oft downloads site. also lt the oft update via internet and make sure your on open flash manager 11.1.1 as per downloads page, then all will be good. Their was a heap of oft interface updates |
#754 | |
is better than you
#755 |
Drives: Brz blue series
Where can i find the DL for CAl ZA1JD00C? Ive been looking for it for quite sometime and can't find it
#756 |
Drives: 2012 86
I have recently installed a P&L catted EL header. Running OTS Stage 1 I am getting considerable FLKC: http://www.datazap.me/u/akyp/2014110...=0&data=1-4-14
Already pulled some timing following instructions in this thread: http://www.ft86club.com/forums/showthread.php?t=61820 The only change was the header (did reset ECU prior to installation). Thoughts? Am I even using the correct map? |
OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
