Old 06-14-2013, 01:37 AM   #743
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Originally Posted by Tobz View Post
That's good to know. When he installs the inline
Amp, see if he can confirm where to connect the blue wire too so we can add these in for the future.
That's really good news!
Sent from my HTC_PN071 using Tapatalk 2
Seems to me that in USA etc the inline amp may not be required - just the adapter wired in. I will try and get a photo of where it is wired for you. I think your Oz frequencies are similar to ours.
I wonder if it is due to the range of FM frequencies we use here that the inline amp may be required - then again, don't know if it is going to work yet! Tuesday is the day.
nzer is offline   Reply With Quote
Old 06-14-2013, 03:32 PM   #744
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Got the unit woot. Now to sort out how to wire it all up, don't suppose someone has a write up of what they did?
Do only two of the three connectors on the harness line up? Mines four pins short on the largest white connector
Sent from my Nexus 4 using Tapatalk 2
Nolan
pheoxs is offline   Reply With Quote
Old 06-14-2013, 05:30 PM   #745
nzer
nzer's Avatar
Which unit?
Old 06-14-2013, 05:32 PM   #746
pheoxs
Originally Posted by nzer View Post
Which unit?
T7019A
@2forme
Is the root files for this unit the same as your first post? I'm on page 20 trying to find them
Nolan
Old 06-14-2013, 07:17 PM   #747
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by Pacific View Post
My T7019A was shipped at HK on monday and received/delivered wednesday afternoon in France.
To minimize customs it was declared "monitor" with a value of 80$.
DHL, as usual, applied what they call VAT a lumpsum without any detail or explication and without any reference to customs regulation an amount of 29€. Taking into consideration the total amount involved it was not necessary to contest this amount.
The package is perfect and the connections complete for the Toyota harness.Just prepare the wiring for the reverse camera and the brake contact.
I'm just waiting to receive the antenna harness to mount the headunit in the car. During this time I will have a look on the light to see if it remain possible to change the color.
which cable, wiring solution for the rear camera on T7019. ?
I don't understand the meanings of "brake wire" and "reverse" wire on T7019A harness.
I have a rear camera with RCA (OK) red/black 12v/ground cable: where to wire? and near RCA plug (on each side) a short wire (red):where to wire them? My rear camera comes with poor install sheet.
Maybe this..... http://www.ft86club.com/forums/showp...&postcount=111
"cameras have dual taps on their power wire -- one near the camera and another near the HU. Rydeen's intention was that you power the camera by tapping your reverse lights wire (near the camera). The second lead would be available to provide the reverse gear signal to an aftermarket HU or monitor screen. But you can simply use the lead near the HU to power the camera (and insulate the lead near the camera)."
Trap63 is offline   Reply With Quote
Old 06-14-2013, 07:38 PM   #748
Bigmaxy
Drives: Pegasus GTS86
Has anyone had a look at what is involved in changing the leds to red on the 7019?
Sent from my GT-I9505 using Tapatalk 2
Bigmaxy is offline   Reply With Quote
Old 06-14-2013, 07:41 PM   #749
Trap63
Trap63's Avatar
UHm..I open the back panel to verify DVB-T module (there isn't of course )...I saw a wide mainboard (horizontal) and a panel board. I think that the job isn't complex...on front panel.
Old 06-14-2013, 09:15 PM   #750
Tobz
Tobz's Avatar
Drives: Toyota 86 GTS
This is how I have installed my camera on the stock GPS unit. Not sure if this is the correct wire to use for the T7019A
http://www.carboncarsystems.com.au/m...20Tutorial.pdf
Tobz is offline   Reply With Quote
Old 06-14-2013, 09:30 PM   #751
nzer
nzer's Avatar
@pheoxs I rooted my device using the same files @2forme posted. The root files are in post 1 on page 1 mate. Just follow his instructions EXCEPT you need to use a micro SD card and put it into the LEFT micro SD slot as the right one has nothing in it and you'll lose the micro SD card inside the unit like I did!
To wire it in just plug the stock plugs into the back of the unit. You only really need the main power one and antenna adapter (buy separately) plugged in with the blue antenna 12V wire connected to power from the adapter too.
I have plugged in the two plugs with all the RCA plugs and iPod connection in as well but other than the iPod connector I have nothing connected to the RCAs etc but have left them plugged in for safe keeping.
The Following User Says Thank You to nzer For This Useful Post:
Trap63 (06-15-2013)
Old 06-15-2013, 02:05 AM   #752
pheoxs
Thanks! I have that rom just wanted to make sure it was the right before I flash it. Also I already lost the sd card there haha had to take it apart to get it back.
Nolan
Old 06-15-2013, 04:07 AM   #753
nzer
nzer's Avatar
You did better than me, I left mine inside!
Old 06-15-2013, 09:28 AM   #754
Skippman
Skippman's Avatar
Drives: GBS BRZ Limited
That'll void your warrenty mate!
Skippman is offline   Reply With Quote
The Following User Says Thank You to Skippman For This Useful Post:
nzer (06-15-2013)
Old 06-15-2013, 04:56 PM   #755
nzer
nzer's Avatar
LOL.
Got a friend that is an electronics whiz, @Tech, that may look at swapping out the green LEDs for me. If he does I'll make sure I get lots of photos as that will definitely void the warranty!!!
Old 06-15-2013, 10:17 PM   #756
Tobz
Tobz's Avatar
Got it installed yet? Let us know how u went!
Sent from my HTC One using Tapatalk 2
Samsung Galaxy Note SGH-I717 - 16GB - Carbon blue (Unlocked & Rooted) JPxM0Dz Canada Classifieds 2 01-20-2013 12:51 AM
chinese man sues wife for being ugly: wins wrxgoose Off-Topic Lounge [WARNING: NO POLITICS] 15 11-07-2012 11:58 AM
Counterfeit Chinese Airbags @Art_Mighty Other Vehicles & General Automotive Discussions 11 11-03-2012 04:20 AM
JDM Vs. KnockOff SIRvive Off-Topic Lounge [WARNING: NO POLITICS] 4 03-05-2012 06:32 PM
Gang of Chinese kick, yell, and drag a little caucasian boy Giccin Off-Topic Lounge [WARNING: NO POLITICS] 34 01-20-2012 11:47 PM
