Old 02-02-2017, 08:42 PM   #701
steve99
Originally Posted by Roadcone View Post
Thanks for the log file. I will try that this afternoon and see how it goes.
also, how would one go about finding these addresses for themselves?
extremely tedious and time consuming process of reverse engineering ecu code
very few people do it and im not one of them
Old 02-04-2017, 03:50 PM   #702
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
So should I just give up on the tactix since I'm not going to have time to reverse engineer this ecu? Seems like oft and ROM raider is a far more capable and supported system. Or saying screw it and just doing ecutek.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 02-04-2017, 07:05 PM   #703
Tor
Tor's Avatar
Drives: Toyota GT86
Also, I'm currently just wanting to calm down the cold start. In ECUFlash the Warm Up Enrichment table doesnt even show a tab to open for me to edit. Then again I guess if i will be flashing another tune into the car my current tune doesnt matter at all.
Don't edit with ECUFlash. Just use it for flashing and nothing else.
Tactrix and OFT are just methods of getting your tune flashed into the ECU. Doesn't matter which one you use, neither is more "capable" than the other. Again use RomRaider to edit and either ECUFlash/Tactrix or OFT to flash and log.
That would probably be the easiest and safest choice if you don't want to invest a ton of time figuring out how everything works.
Tor is offline   Reply With Quote
The Following User Says Thank You to Tor For This Useful Post:
Teseo (02-05-2017)
Old 02-04-2017, 07:05 PM   #704
steve99
Flashing will be fine its logging thats going to cause the most headaches
Old 02-04-2017, 07:39 PM   #705
Roadcone
StreetKart
If ecutek didn't have the bullshit 300 per car license fee it would be a no brainer. I don't want to invest 850 into selftuning two cars. License should be 100 or so. Not 300.
Old 02-04-2017, 09:35 PM   #706
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
You have many choices:
1. Put time into reading and figuring this stuff out. That would involve carefully reading all of this thread and all of the links in this thread. It's not that hard, but it's not simple. I managed to flash my car several times and also adjust some fueling. It's not rocket science, but it's not stupid easy.
2. Pay somebody to do it for you. They'll probably use ECUTek.
3. Leave the car as is and don't worry about it. It's probably fine. A lot of logging can be done with Torque and a bluetooth reader. No danger in frying your ECU that way.
4. Buy a backup ECU for $50 off ebay. Then play without fear.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Teseo (02-05-2017)
Old 02-05-2017, 01:38 AM   #707
steve99
just use tactrix\ecuflash and romraider to flash and edit roms no licoence fees then buy a copy of brzedit and just ise it for logging its worth e 100 to be able to log or buy a $300 ecutek cable kit one off charge and just ise it for logging will log al cars any romid no licience required, and just dont flash with it , continue to use tactrix to flash
jist dont flash calid adjisted roms as it will confuse ecutek logging and like
y brzedit
Old 02-05-2017, 01:42 AM   #708
steve99
if you have tactrix then you can also use toyota techstream to log its free
Old 02-05-2017, 05:00 AM   #709
aagun
Drives: 86
what going on here may i can help .
@steve99
can i log RAM 0xFFF80000 TO 0xFFF8FFFF fast way
aagun is offline   Reply With Quote
Old 02-05-2017, 05:33 AM   #710
aagun
Drives: 86
; some samples of logging "bitfield" values that are not whole bytes
; if you want to log more that one of these efficiently, group them by
; paramid and the OP2 will only issue a single request to get all of
; the bits within each paramid
how ???
Old 02-05-2017, 05:22 PM   #711
steve99
Originally Posted by aagun View Post
how ???
I think this is when several parameters are in one byte of data, and the individual bits or group in bits in the byte contain the information you want.
Old 02-05-2017, 05:23 PM   #712
steve99
@steve99
Those guys are after logging ram addresses for later USA roms, not sure which rom calid though
Old 03-17-2017, 06:25 PM   #713
steve99
Added Chinese ZA1JK00N rom to original post
Also warning about flashing older roms to 2017 cars causing Security system lockout and recovery proceedure
Old 03-18-2017, 01:59 AM   #714
BlaqkHavok
Drives: 2014 DGM BRZ
hello, guys im hoping this is the correct thread for this, ive read through the first 10 pages solid, and about 75% of the rest, i have a decent grasp on whats going on here, but many of the specifics are a bit confusing...
here is my problem.. i got that damn P0016 CEL/slip light code.. dealership already done there flow chart diagnostics and they replaced the OCV on that cam... code still there, and issue not fixed.. they now want my car for extended time, and will not guarantee that it will be covered.... ive been reading up on it, and my own run down, and everything has been pointing to the ECU.. but they dont want to just flash the with the updated firmware/ROM as they have "procedures" to fallow before getting to that point... and if i want to get them to do that, ima have to either pay out of pocket or spend and extended amount of time with SoA.... but before i go that route i wanted to see if there was something that i could do myself (i usually do all the work on my cars, and this was my first time trying to let the dealership handle it, being a newer car and all..) it would seem that it is quite a direct fix: a cable and an ecu off ebay... ( and some resourceful aid...
so this is where i am now... im ready to get those two items, but before i pull the trigger i want to be sure that i can do what i need to:
my car is a 2014 BRZ MT, USA... i would like to install the second hand ecu (assuming i should be looking for a 2013-2016?) and flash it with the latest OEM ROM for the car that should have the solution for the software glitch that was causing this...
so what im asking is some help with what files do i need to DL to be able to flash the replacement ECU??
im a bit confused in regards to the definitions and base file vs etc? sorry... after a bit i get lost in all the terminology... why i never got into programming...
thank you in advance to whom ever is able to help me with this
BlaqkHavok is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
