Old 10-06-2015, 01:11 AM   #57
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
Originally Posted by jsimon7777 View Post
Fiebruz sounds like a great supplier. Their coilovers have "32 levels of dampening". It really wets my appetite for a pair.
What did you expect from function form coilovers... lol
Cartman is offline   Reply With Quote
Old 10-06-2015, 01:21 AM   #58
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I expect they're better than Penskes.
Old 10-06-2015, 01:29 AM   #59
Knshro13
Drives: 10 series FRS
wow.
Knshro13 is offline   Reply With Quote
Old 10-06-2015, 01:33 AM   #60
Cartman
Cartman's Avatar
I think they are, their N/A track build has ohlins though... and holds the record for fastest N/A FR-S at 13.32
Old 10-06-2015, 10:38 AM   #61
dallenj
Drives: Grey FR-S
Originally Posted by spitfire481 View Post
They are still untested. The trans shop we deal with installed a set for another shop but they had fitment issues that had to be worked out. Guessing that's why they are on back order, Par is still sorting that out. Biggest downfall is that if you break it, you're screwed. That's why we didn't get them for testing. Our guy is working on a set from another company, a helical cut set. Timeframe is unknown. I plan on running 9's, we are doing a pretty nasty auto swap in my car for the task. The manual just won't cut it for what I want my car to do
Keep me informed about that gearset when tyey get through testing
dallenj is offline   Reply With Quote
Old 10-06-2015, 10:59 AM   #62
dallenj
Drives: Grey FR-S
Anyone one here know where I can get some extra heads for this car. I have an engine block I will start to put together, but I dont know where to find heads other than a junk yard or a blown engine.
Old 10-06-2015, 01:19 PM   #63
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
also, what are you using or plan on using for fuel?
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 10-06-2015, 02:16 PM   #64
dallenj
Drives: Grey FR-S
I was planing on using some e85 but my tuner advised against that since I was going to using nitrous so I plan on going straight up race fuel
Old 10-06-2015, 04:04 PM   #65
EAGLE5
Dismember
EAGLE5's Avatar
Nothing wrong with mixing nitrous and e85.
Old 10-06-2015, 04:24 PM   #66
evomike
Drives: frs
Originally Posted by dallenj View Post
Thanks for the info but I have been looking at other Clutch setups like a twin disk but this is my street car right now. Should be picking up a new car when the engine comes out of this one. And I was uncertain what I was going to do with the trany. I saw that fbm has workeed on a supra trany conversion for this engine and they offer a twin disk.
a twin disc will hold more power and feel like a stick clutch on the street, you clearly have no idea what it takes to build a car like this. stop while youre ahead and get a hellcat.
evomike is offline   Reply With Quote
Old 10-06-2015, 04:43 PM   #67
spitfire481
Drives: 2JZ FRS
the fx725 twin disk feels far from stock on these cars. i put 10k miles on one. on/off with no slip. even with the fluid control valve it was tough
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
FRS Justin (10-07-2015)
Old 10-06-2015, 06:33 PM   #68
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
My end goal is 9 seconds or under, but my real goal is to have the fastest 86 in the states with the fa20 engine still in it.
This is what internet marketing hype has done to a generation of would-be tuners.
More power to you, I'll cheer if you succeed, but nothing on that parts list is going to get you anywhere close to either goal.
You have a lot more work, learning, and research to do. Orders of magnitude more than this thread is going to give you.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
EAGLE5 (10-06-2015)
Old 10-06-2015, 06:42 PM   #69
dallenj
Drives: Grey FR-S
You might want to pay attention about everything that is said at this point with this being my only car a single disk is what I will go with when I pick up another car tgis will become stickly a race car. The only reason why I started the build on this car my daily driver is my current race car went down in flames. And im not sure if I will keep this transmission so why would I spend an extra grand on something I wont use very much at all.
Old 10-06-2015, 07:02 PM   #70
dallenj
Drives: Grey FR-S
Thanks for the support, but I have my whole team helping me out on this and they know a lot more then I do. This is my first stage of this build and I know it will involve a lot and not everything is on tgis list just most of the parts. I was thinking that I could get there with the supercharger plus nitrous, but after all the feed back ill probably go turbo.
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 10:41 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 11:14 PM
My BRZ build brztj Mid-Atlantic 3 09-08-2012 06:52 PM
