Old 05-22-2016, 11:21 AM   #57
makesdrivingfunagain
Originally Posted by Ben_G View Post
So what if I don't want bigger brakes, only lighter weight? Are there non-BBK kits that use OEM size (or close to OEM size) two piece discs? Would this even be something viable for DD street only use? Potential issues with heat in stop and go driving?
I was interested in a replacement rotor that is the stock size for weight loss and not needing to purchase an entireBBK kit. Let me know if you find one. I couldn't.
makesdrivingfunagain is offline   Reply With Quote
Old 06-01-2016, 12:18 PM   #58
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
What about the DBA5000 rotors?
They're stock sized and 2 pieces.
Might not be much of a weight saving.
mrderp is offline   Reply With Quote
Old 06-03-2016, 12:28 AM   #59
Will look into it, thx
Old 11-21-2016, 10:56 AM   #60
radroach
Drives: car
I have questions about replacing my OEM brakes pads front/rear with new OEM pad kits from parts.subaru.com. Just noob questions, I will try to order these parts soon.
Ok first question, there's two different OEM pad kits for rear disk brakes, different parts numbers; is there any difference between the two?
http://parts.subaru.com/p/Subaru_201...6696CA000.html
http://parts.subaru.com/p/Subaru_201...6696AG051.html
Second question, so I need a seal kit?
http://parts.subaru.com/p/Subaru_201...6297FE000.html
Thanks!
Old 11-21-2016, 11:29 AM   #61
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
Thanks!
No you don't need a seal kit unless you see damage to your seals when you take the pads out.
If all you need is to replace your brake pads from wear then just get the pads separately. You don't need a kit with all the other clips and such because you can reuse your existing ones. See if any people on the forum have some that they don't want anymore as there are a lot of people that have upgraded their pads to a better pad or have bought a big brake kit. That's how I have a couple extra sets of OEM pads.
If you haven't replaced your brake fluid in over 2 years then you should do that as well. Here's a link on how to do it.
http://www.ft86club.com/forums/showthread.php?t=24614
stockysnail is offline   Reply With Quote
Old 11-23-2016, 05:59 AM   #62
JGalp
Drives: 2015 CWP BRZ Limited
for DD and spirited street driving should i just go OEM pads? or winmax W1..W2..? which one between the two. the 20 dollar difference doesnt matter i just want whats better for my applications. i will be doing the brake fluid as well. perhaps a grimmspeed brace
JGalp is offline   Reply With Quote
Old 11-23-2016, 10:20 AM   #63
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Depending on how much spirited driving you do vs DD, OEM may suffice. W1 would be a slight upgrade, with better fade resistance compared to stock, while the W2s will be more performance oriented, coming with all the draw backs such as increased dust and noise.
Since it's a relatively light car, I've been doing OK with W1s for DD, occasional spirited driving and a couple of track days a year.
Old 11-23-2016, 11:13 AM   #64
JGalp
No track days for me, I haven't even done a canyon run or anything, I'm literally a stoplight to stoplight warrior, I'll get on it sometimes, if there's a street I like and I think is relatively safe I'll go fast into a corner stuff like that, but nothing crazy where I'm constantly on the brakes going downhill or whatever,
Old 12-09-2016, 07:21 PM   #65
rkaywhodat
Drives: 2017 Toyota 86 Halo
I have an 86 as my DD and have everything stock currently, this upcoming summer I plan to do may be one track day and may be some drifting on a skid pad. My future plan is a few days like this per summer.
I planned to upgrade my brake pads to Project Mu HC+800 pads and use DOT 4 brake fluid as I believe this should be suitable for daily driving in the summer with a few days of drifting and may be a track day or two.
My question is should I switch back to the stock pads during the winter months? would the cross-over/hybrid pads be bad during the winter months?
Sent from my D5803 using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 07-13-2017, 11:34 AM   #66
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
CERAMIC BRAKE PADS for BRZ Brembos (Performance Package)
Here are the PADS your need for Ceramic upgrade on your Yellow or Performance Package BRZ
007BRZ is offline   Reply With Quote
Old 07-29-2017, 01:31 AM   #67
NLS8520
Drives: N/A
Expanding on that post about the Performance Package Brembo brakes, what hybrid street/track pads fit as of now?
NLS8520 is offline   Reply With Quote
Old 07-29-2017, 03:54 PM   #68
stockysnail
Just the tip
Check the pads cold temperature rating. If it's not low enough compared to the weather, then I would switch them. Pads that are in-between stock and racing are compromising on both ends, not good for cold and not great for extreme. Ideally you'd have a set of oem pads with rotors and another set of racing pads and rotors. I say rotors as well because the material is different that rubs off from the pads which effect braking sometimes significantly. Our cars are very easy to swap so it shouldn't be much of an issue, just a little time and a little money.
Old 08-23-2017, 09:19 PM   #69
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Is there a list of track pads available for the 17 BRZ with performance pack?
airindia33 is offline   Reply With Quote
Old 08-24-2017, 03:36 PM   #70
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
Depending on the application, we can help supply you with the correct brake pads for your usage. Let us know!
CounterSpace Garage is offline   Reply With Quote
brake, discs, lines, pads, rotors
R1 Concepts Brakes upgrade carlossanchez89 Brakes, Suspension, Chassis 1 01-13-2014 08:28 PM
Brakes for Turbo Upgrade? wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 08-29-2013 06:49 PM
HELP with understanding Brakes upgrade path bear89103 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 07-17-2013 07:08 PM
[StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) WTF Australia Classifieds 12 08-14-2012 03:10 AM
[StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) WTF Australia Classifieds 0 07-11-2012 11:27 AM
