#43 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
i have zero issues, even on track.
i don't have much credibility, because i don't have that much seat time and and not a pro however a few pro drivers took my car out for multiple heats and came back telling me how well balanced it is. every time i drive a stock brz/frs i hate the pedal. feel like a marshmallow, mine is nice and firm these are my mods: 05 Sti brembos (swapped bleeders) dba 4000 slotted rotors (front) Stop tech street performance pads SS lines superblue fluid (i know its illegal, arrest me) grimmspeed MSB |
#44 | |
Snow Don't Hurt!
![]() I know there are plenty of people that run just front BBK, but Jive was the only person I could think of that tracked his AND daily drove his. My bad, dawg. |
#45 |
Drives: Attitude
I drive on a 4 lane wide track twice a day... wheel to wheel racing!
#46 |
Drives: Subaru BRZ with Delicious Innovate
I did a little more research about only upgrading the front calipers.
Sti piston sizes are 40mm and 46mm area=2918.5mm^2 Sti effective rotor diameter = 268mm Brz piston size is 42.8mm and 42.8mm area = 2877.44mm^2 Brz effective rotor diameter = 247mm So if the piston area is more on the sti then the brake force is going to be more. And if the ED is larger you get more brake torque. So given that how does the bias move backward if you only change the front calipers?!?!?! I have done it but I am running a higher friction pad in the rear and stock on the front right now. The bias did move back. I am getting matching pads soon so I will report back but I don't understand based on the numbers how the bias is supposed to move back. I could have done somethin wrong so any help is appreciated. EDIT: I can't find the post that said the bias would go back but I remember it coming from a reputable source.
#47 |
Drives: Blue BRZ
So what if I don't want bigger brakes, only lighter weight? Are there non-BBK kits that use OEM size (or close to OEM size) two piece discs? Would this even be something viable for DD street only use? Potential issues with heat in stop and go driving?
#48 |
Drives: 1998 Audi A4 Quattro Sport 30v
Thanks for the great guide!
I'll be ordering your 4-piston black front and rear AP Racing BBKs at some point along the build.
#49 |
Drives: Attitude
Most bigger brakes ARE lighter weight.
#50 | |
Senior Addict
Drives: 86 GT
Look at it the other way round. Say your car came from the factory with brembo brakes all round. Now if you installed the stock calipers you currently have, then your bias will move rearwards due to the larger pistons. |
#51 |
Drives: 2013 Subaru BRZ Limited (WRB)
This is one of the most helpful posts I've come across on this site... and trust me, there are a lot of helpful posts!! I just ordered the following based on the "Spirited Street Driving" category: DBA 4000 T3 slotted rotors (front and rear), Hawk HPS pads, and stainless steel lines plus high performance fluid. Install set for Monday!
#52 |
Drives: FT-86
Ive asked this a couple of times but with no luck... any idea if the AP Racing Sprint kit will work as intended on a base model (solid smaller rotors, WRX calipers on the rear)? Ive just came back from my first track day with my new turbo set up and the brakes couldnt hold very well after 3-4 hot laps (Ferodo DS2500 pads front/stock pads rear, stainless lines, Pentosin brake fluid), so i really need a BBK, but i dont know anyone that runs this kit on the base model 86. Thanks! @JRitt
#53 |
Site Moderator
Drives: Stuff
This is the technical forum. No advertising products directly.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#54 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#55 |
Drives: 2014 GT86
About the only non positive thing about APR Sprint kit is that it's not made to live well through winter road salts .. but it wasn't it's main purpose anyway. Anything else is positive indeed, as even high price is more then offset by way lower price of wearables.
#56 |
Drives: 2012 BRZ Premium WRB 6MT
I did a video version of my brake upgrade guide...
[ame="https://www.youtube.com/watch?v=E2MznXX4vGc"]Know Brakes 5: High Performance Brake Upgrade Guide - YouTube[/ame] How to Plan Now for Future Brake Needs [ame="https://www.youtube.com/watch?v=kwWqFecWZPc"]Know Brakes 7: How to Plan Now for Future Brake Needs - YouTube[/ame] Last edited by JRitt; 04-13-2016 at 10:04 AM. |
| Tags |
| brake, discs, lines, pads, rotors |
| R1 Concepts Brakes upgrade | carlossanchez89 | Brakes, Suspension, Chassis | 1 | 01-13-2014 08:28 PM |
| Brakes for Turbo Upgrade? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 39 | 08-29-2013 06:49 PM |
| HELP with understanding Brakes upgrade path | bear89103 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 21 | 07-17-2013 07:08 PM |
| [StreetFX] 86 GT HID upgrade kit with DIY GUIDE! (including parking lights) | WTF | Australia Classifieds | 12 | 08-14-2012 03:10 AM |
| [StreetFX] BRIGHT Boot/Trunk LED light upgrade & DIY step by step guide (GT and GTS) | WTF | Australia Classifieds | 0 | 07-11-2012 11:27 AM |
