Old 01-09-2015, 12:38 AM   #57
AZbrz89
Drives: 14 BRZ Crystal Black Silica Limited
After reading the specs on rhe radium dual catch cans the kit comes with a check valve. Hmmm thanks for the pics earlier
AZbrz89 is offline   Reply With Quote
Old 01-09-2015, 09:26 AM   #58
Rosticles
Drives: 1966 Mustang, 2013 FR-S
Where does it say it has a check valve? On the website it refers to the operation of the PCV valve, but that won't cut it for forced induction.
Rosticles is offline   Reply With Quote
Old 01-09-2015, 09:28 AM   #59
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
check valve behind pcv
My radium catch cans did not come with any kind of check valves. I ordered from @FT-86 SpeedFactory
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 01-09-2015, 09:41 AM   #60
AZbrz89
Originally Posted by CK_Bladesmith View Post
My radium catch cans did not come with any kind of check valves. I ordered from @ft86speedfactory
Oh ok
You're right! Thought it was the same thing just different terminology lol
Old 01-10-2015, 07:14 AM   #61
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by alexand3r View Post
I have a Saikou Michi set, which has a 3/8" connection for the PCV line and a 1/2" that goes to the manifold (which is also takes 1/2" ID).
Which saikou michi catch can did you get? The universal or the FRS specific one? Do you know what's the difference between those two types?
Fizz is offline   Reply With Quote
Old 01-10-2015, 02:02 PM   #62
alexand3r
Custom User Title
alexand3r's Avatar
Drives: Spaceship
I got the FRS/BRZ specific.
The differences are that the cans come with mounting hardware to attach to the strut bar and the inlet and outlet on the cans are rotated to work without serious bends in the hoses.
Also, the inlet is 3/8" and the outlet is 1/2" on the PCV can in order to correctly match our setup.
alexand3r is offline   Reply With Quote
Old 09-07-2016, 05:15 PM   #63
DHitHim
Drives: 2015 CWP Limited BRZ
Originally Posted by AZbrz89 View Post
It says on radium website 1/2" pcv hose boomba here I come lol
Did you ever get the boomba installed with the radium kit? Did you leave the factory PCV on the block?
DHitHim is offline   Reply With Quote
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 06:38 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 12:06 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 01:47 AM
FS: Synchronic Diverter Valve Kit FReSh_86 Engine, Exhaust, Bolt-Ons 0 11-26-2013 02:21 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 09:42 PM
