Old 12-16-2014, 11:58 PM   #1
myioz86
Drives: gt-86 2013
check valve behind pcv
Might be a good idea for all the people that are running boost to put a check valve behind the pcv valve and the crank case.last night i took the hose off and checked how easy it is for boost to leak out this inlet. there is no resistance at all and i could blow and suck air through this opening.should only be able to push air through but not come back.in my mind this means boost can leak out and into crank caseThanks to JAMESM who brought this to my attention with one of his old threads I am going to put a check valve in today and do a test drive to see the difference in boost pressure with and without valve. Might even put one on the brake booster line as i dont think it is a good idea for pressure to be going into booster then when braking, booster has to go back the other way when it is under vacume. Dieaframe is flexing one way then the other.please correct me if i am wrong
myioz86 is offline   Reply With Quote
Old 12-18-2014, 08:03 PM   #2
Rosticles
Drives: 1966 Mustang, 2013 FR-S
The PCV valve will keep your crank case from accepting manifold air. When there is pressure in the manifold it closes, just like a check valve.
Rosticles is offline   Reply With Quote
The Following User Says Thank You to Rosticles For This Useful Post:
Fast_Freddy (01-02-2015)
Old 12-18-2014, 09:16 PM   #3
kbogarto
Drives: 2013 BRZ limited WRB
I thought the brake booster line already had a check valve in it?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 12-19-2014, 10:47 AM   #4
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
The brake booster definitely has a check valve in it, but I am still of the opinion that our PCV or Positive Crankcase Ventilation hose off the back of the manifold has nothing in it to prevent pressurizing the crankcase with boost.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
kbogarto (12-19-2014), protpibe (01-03-2015)
Old 12-19-2014, 10:59 AM   #5
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
@King Tut how does the PCV hose connect to the intake manifold? if it attaches to a threaded hose barb fitting you can probably find an OEM PCV valve off of something else to thread in there.
seems odd that they would do that, though, nearly all the N/A cars I've seen still have a one-way PCV valve of some sort.
1jz salvaged brz build thread brought to you by visconti tuning --> Pipe dreams and poor life choices
SomeoneWhoIsntMe is offline   Reply With Quote
Old 12-19-2014, 04:05 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
There is a fitting that screws into the block/crankcase and then there is a molded rubber hose that goes from that fitting to the plastic fitting on the back of the intake manifold. Nobody has shown proof that there is any kind of check valve or one way valve on that fitting that screws into the block. There definitely isn't one in the hose.
The Following User Says Thank You to King Tut For This Useful Post:
Fizz (12-19-2014)
Old 12-19-2014, 04:09 PM   #7
DAEMANO
Time Traveller
Subbed
Old 12-19-2014, 05:25 PM   #8
SomeoneWhoIsntMe
@King Tut normally there isn't any check valve on the block, just on the intake manifold.
how are people routing their PCV hoses such that it pressurizes the crankcase?
Old 12-19-2014, 08:45 PM   #9
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@King Tut when running an oil catch can for the rear PCV, does it matter if the check valve goes before or after the occ?
Would you also place a check valve on the hose that runs from crankcase vent (under the AC compressor) to the intake pipe? Mine's a sprintex setup.
Fizz is offline   Reply With Quote
Old 12-21-2014, 07:09 PM   #10
King Tut
NASA SpecE30 Racer
King Tut's Avatar
That depends on whether your catch can is setup to withstand boost. I wouldn't want to chance it, so I would place the check valve between the catch can and the intake manifold.
The intake pipe never sees boost, so no need to worry about a check valve on that hose.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
airrick (07-26-2020), CK_Bladesmith (12-21-2014), Fizz (12-21-2014)
Old 12-21-2014, 10:51 PM   #11
myioz86
Drives: gt-86 2013
since i have found out there is no check valve in the manifold and have since put one in there the boost on my car has gone up about 1.5pounds and is pulling even harder than before.now all i have to do is build a 3" mid pipe with high flow cat and see if i can get some more "boost" out of this thing "ye haa".
The Following User Says Thank You to myioz86 For This Useful Post:
kbogarto (12-22-2014)
Old 12-22-2014, 02:09 AM   #12
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
What size check valve did you use?
Tye300 is offline   Reply With Quote
Old 12-22-2014, 02:41 AM   #13
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
+1, details please
Old 12-22-2014, 05:36 AM   #14
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
This works fine: http://www.usplastic.com/catalog/item.aspx?sku=64175
PCV valve leaking? jamesm Forced Induction 24 12-25-2014 07:38 PM
Fumoto valve in the winter? Muskokan Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 02-25-2014 01:06 PM
Exhaust Cut Off Valve beagoodruslan Engine, Exhaust, Transmission 2 01-01-2014 02:47 AM
FS: Synchronic Diverter Valve Kit FReSh_86 Engine, Exhaust, Bolt-Ons 0 11-26-2013 03:21 PM
Name that valve cover!!!! FA20???? ESBjiujitsu Engine, Exhaust, Transmission 3 06-05-2012 10:42 PM
