Old 12-21-2015, 12:34 AM   #57
sastexan
Drives: '13 FR-S Ultramarine manual
According to their website, American Muscle has the CDC version back in stock. There is also a GB going on on the Intec. Besides the fact the tape on the CDC version goes all the way around and the Intec is only on the top, any other differences between the two? Pros / cons to either design?
'13 FR-S - Ultramarine manual
(GONE) '98.5 Contour SVT - modded (and threw rod with buyer)
'01 Camry 5S-FE (wife's old car)
'11 Odyssey EX-L - familymobile and hauler - food-encrusted carpets and other appropriate features
sastexan is offline   Reply With Quote
Old 08-14-2016, 04:36 PM   #58
Cole
Not a troll
Cole's Avatar
Going to add my opinion to this, rather than start a new thread.
Back in December or January, or maybe even February (honestly can't remember), I bought the Intec high mount brake light. While it is nice to have a "built-for" option for the twins, I found it lacked a well thought out design. To start with, the light is heavy, and only attaches from the rear. While it looked good, with no visible tape on the rear window, it would constantly fall down. I tried different types of tape and nothing seemed to hold it. The last straw was when it fell down the last time, the piece that goes into the headliner grommet snapped off. Basically leaving me with a $150 paperweight, because now for sure, it would never stay on.
Enter the CDC light. While it isn't a perfect fit, it's super lightweight and the tape on all 4 sides is a big plus for me. I have absolute confidence in this piece actually staying attached to the window, much unlike the Intec one.
Install was super easy, because I finally found a use for the useless piece of junk the Intec light was, and used the connector from it so that I didn't have to cut up the harness on my stock light, or actually hard wire it into the cars harness. Worst part about it was routing the wire, but all said and done, including all disassembly time, splicing time, etc, i finished in under 40 minutes. It may not be perfectly centred at the moment, but I may go back and actually measure everything out and do it right, but for the time being, still very pleased with how it turned out. If I do end up fixing it, I'll probably get a heat gun and try to mould it a bit better to the back window, but again, for a $50 dollar solution, absolutely overjoyed with how it came out.
10/10, would recommend to a friend.
The Following 5 Users Say Thank You to Cole For This Useful Post:
8R6 (08-15-2016), BabaYaga (08-14-2016), Ben_G (02-22-2017), brandonblt2 (07-18-2018), Ultramaroon (08-14-2016)
Old 08-14-2016, 08:16 PM   #59
Ultramaroon
not playing cards
Ultramaroon's Avatar
That looks really good.
Cole (08-14-2016)
Old 08-14-2016, 10:26 PM   #60
notout86
Drives: GTS 86 auto
Basically I simply got the light module out of the spaceship, made a snug enclosure for it, covered in satin-black sprayed fabric and pushed it into the space where the shelf meets the glass.
Compared to the OE spaceship, effectively, with no reflection in the glass above, and tucked back further into the crack, it hardly obscures any view .... around a fifth of the original.
Satin-black paint on black velvet seems less reflective than matte-black and plain black velvet alone fades lighter to gray.
GTS86 Auto (Australia)
notout86 is offline   Reply With Quote
Old 08-15-2016, 09:25 PM   #61
White64Goat
and the picture(s) are where??
Old 08-15-2016, 10:16 PM   #62
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
My Intec brake light fell off as soon as the real summer heat began. The plastic tab that is retained by the OEM push pin is not rigid enough to hold the light tight against the glass.
My solution - a 3/8" bolt (black with a low profile head) will thread into the OEM hole normally occupied by the push pin. This enabled me to use a thin, black, metal support to hold the brake light housing tightly to the glass, and the support and bolt are almost no more obvious than the original install that failed.
geezerbrzeezer is offline   Reply With Quote
The Following User Says Thank You to geezerbrzeezer For This Useful Post:
Cockatoo (08-17-2016)
Old 08-16-2016, 04:33 AM   #63
churchx
churchx's Avatar
Drives: 2014 GT86
On a side tracking note my Wheelhaus's CF brake light keeps strong since the day it was installed. If there was any slight drawback, due no window heater there condensation in winter is very slow to clear. Any hints how to fix that?
Old 08-17-2016, 03:28 PM   #64
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
PIC?
Cockatoo is offline   Reply With Quote
Old 08-17-2016, 05:56 PM   #65
geezerbrzeezer
Geezer
Originally Posted by Cockatoo View Post
PIC?
Will do.
MemphisR (11-23-2016)
Old 11-21-2016, 11:43 PM   #66
tracerit
Drives: '13 SSM BRZ Limited 6MT
I have the CDC "Mustang" brake light too, installed during summer and it held up extremely well during the socal heat however I just found out some of the LEDs are out! It looks pretty bad since it's not just one side, it's in the middle.
Has anyone with rear window tint removed the brake light cover successfully without removing the tint from the rear window? Worried the 3M is too strong for its purpose here...
Also, any ideas on a replacement LED light bar or should I roll the dice on a new unit?
tracerit is offline   Reply With Quote
Old 02-19-2017, 11:34 PM   #67
HomerTaco
HomerTaco's Avatar
Drives: 14 FR-S
HomerTaco is offline   Reply With Quote
Old 02-20-2017, 02:26 PM   #68
Cockatoo
TALLY FT86
Cockatoo's Avatar
Will do.
cough cough....
Old 02-20-2017, 06:35 PM   #69
ka-titties
Drives: 2013 BRZ Limited 6MT
Pardon my ignorance, but I have two questions.
1. When removing the third light, what do y'all do to cover the hole left by the stand in the parcel shelf finisher?
2. Why bother installing another light? Has anyone actually been pulled by the authorities for missing a third brake light? I ditched mine on my other car going on two years now and never had a problem.
ka-titties is offline   Reply With Quote
Old 02-20-2017, 06:43 PM   #70
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
(2.) Because when you find that one cop who's willing to tag you for no 3rd brake light ticket, he's gonna throw the whole book at you. (exhaust, suspension) why give them any excuses at all to pull you over?
VIP BRZ is offline   Reply With Quote
What's the official solution to bypassing the VSS + e-brake sensor for videos? [Cyanide] Electronics | Audio | NAV | Infotainment 37 05-05-2015 02:51 AM
3rd brake light rattle easy fix xITSxTHExPOPEx Electronics | Audio | NAV | Infotainment 2 12-14-2014 07:14 PM
Solution for easy changes to rear camber and toe (street and track use) dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-11-2014 06:28 PM
APR Performance brake cooling solution whataboutbob Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 02-18-2013 02:33 PM
Cheap, easy brake mod! CBR600RR Cosmetic Modification (Interior/Exterior/Lighting) 4 09-19-2012 08:39 PM
