#57 |
Drives: blk;2dr;rwd;fun
Please do. Would be useful
Life is like taking a dump, sometimes it's easy and other times its hard. But it always stinks
#58 |
Sadly though I am a programmer, I possess only minimal Excel-fu.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
#59 | |
Drives: UK GT86
You might want to look through this: http://www.romraider.com/forum/viewforum.php?f=32
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | shif7i7down (04-14-2014) |
#60 |
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Vgi has actually already put together a programme to handle both open and closed loop based on the numerous spreadsheets out - I've test driven it, works perfectly and lightening fast. Excel is a dog for doing these kind of number crunching exercises - especially if you're generating logs with the OP2 which will be large.
See here: http://www.romraider.com/forum/viewt...p?f=32&t=10481 |
| The Following User Says Thank You to Td-d For This Useful Post: | Turdinator (04-14-2014) |
#61 |
Drives: UK GT86
I'm testing it out too, needs some wrinkles sorting but I like it. Nice to ser tools being developed. I just wish I could programme to help out.
.: Stealth 86 :.
#62 | |
Drives: 2013 BRZ Premium 6MT
got it to work by installing 64 bit java, but now when i open rom raider it says requires 32 bit java and some features may be unavailable. doh!
2013 Subaru BRZ Premium 6MT -STOCK!
#63 | |
Drives: frs
And yes, thanks to Kodename47's suggestions and spreadsheets I will be making some changes to make it more user friendly (especially for ecutek folks) and adding new views. PS you don't need 64bit java, you just need v1.6+ java Last edited by vgi; 04-15-2014 at 08:33 PM. |
#64 | |
Drives: FR-S Whiteout
BTW how do you get the AFR% error from the logs? Specifically from an OFT log. Last edited by solidONE; 04-15-2014 at 11:30 PM. |
#65 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | solidONE (04-16-2014) |
#66 | |
I also converted the 7 pulls into dynographs It seems I lost the few ponies I gained with the messed up maf scale, from about 196HPS back down to about 189HPS... Not sure what to make of it. I'm still hitting all the additional KC ignition advance I added from before. Log of the pulls: http://www.datazap.me/u/solidone/e85...g=0&data=1-5-6 |
#67 |
Drives: UK GT86
Do you have excel? An easy way to get the RR copy to work is to copy it into excel, move the MAFv row to the right one cell and then input [Table2D] into the 1st cell. Then you can copy that into RR. As ECUtek uses a vertical table, that makes it slightly more awkward again and I've asked this to be looked at. Maybe @vgi can add a RomRaider copy button to do that automatically?
I wouldn't add the LTFT to the % error, you want the output AFR to be corrected 1st. Although the end difference would be minimal, it's just not quite as precise. Again, this has been raised
.: Stealth 86 :.
#68 | |
#69 | |
Drives: frs
Also, in Usage tab I believe I describe how the 'Smoothing' view works. The curve you see in the 'Smoothing' view is NOT a MAF curve, it's the smoothing slope curve. To see the smoothed curve (after you have applied let's say default 3 degree) you need to tick off 'smoothing' checkbox which will bring you back to results view and tick on 'corrected' and 'smoothed' checkboxes - then you will see raw corrected maf curve vs smoothed maf curve. |
#70 |
Drives: frs
| Best Break-in Procedure | xantonin | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 198 | 02-11-2015 04:40 PM |
| Visual Basic and SQL | Trashed675 | Off-Topic Lounge [WARNING: NO POLITICS] | 10 | 06-10-2013 12:18 PM |
| dyno numbers based on break in procedure. | EZWood | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 25 | 06-09-2013 08:32 PM |
| Fr-s Break in procedure. | Ontariofrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 03-14-2013 07:14 PM |
| Winter storage procedure | wbradley | DIY (Do-It-Yourself) Guides | 20 | 10-31-2012 12:49 AM |
