Old 04-08-2014, 08:08 PM   #57
onzippy
Drives: 2014 FRS
Originally Posted by Sportsguy83 View Post
Your boost gauge will show you being at ~6 psi.
You can also check it with an ELM327 OBD2 bluetooth adapter and an Adroid phoen with the app Torque
I found the ECU would read up to 5.2 psi with the OEM MAP sensor and stage 1 tune. No higher. My vacuum/boost gauge was reading closer to 7 psi because the wastegate preload on the 6psi actuator was set high.
After changing to 3barMAP sensor and stage 2 tune the ECU matched the boost gauge.
just fyi before anyone thinks they're a psi or two low.
onzippy is offline   Reply With Quote
Old 04-08-2014, 08:21 PM   #58
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes, that is correct. I initially thought stock WG spring was 5 psi, that is why I said it was ok.
Also, I recommend a boost gauge independent of the ECU sensors, (aka P3 gauge which IS dependent on the stock sensors)
The Following User Says Thank You to Sportsguy83 For This Useful Post:
onzippy (04-08-2014)
Old 04-08-2014, 08:35 PM   #59
onzippy
Drives: 2014 FRS
(aka P3 gauge)
Thanks.. I didn't know what that was so I searched for it. It's neat.
p3cars
The Following User Says Thank You to onzippy For This Useful Post:
Sportsguy83 (04-08-2014)
Old 04-08-2014, 09:02 PM   #60
Sportsguy83
Drives: Limited BRZ
p3cars
But to be sure, what I meant is the P3 gauge is dependent on the stock ECU sensors.... Although it allows two other inputs into it 0-5 V.
Old 04-08-2014, 09:36 PM   #61
Astroboy
Astroboy's Avatar
Drives: None
Ok so I never got anything that connects these two pipes basically which I circled in red. Is nothing included in the stage 1 that connects these two? Is it nothing to worry about? I really need a serious answer please.
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 04-08-2014, 10:17 PM   #62
onzippy
Drives: 2014 FRS
You're in need of a blow off valve (BOV) my friend. It does not come with AVO kit but it says that in the kit description. Although, they don't tell you what to do with the open holes in the tubes.
It did get a little silly but your thread is being well supported and I don't think anyone wants you to blow anything up.
The Following 2 Users Say Thank You to onzippy For This Useful Post:
Astroboy (04-08-2014), Sportsguy83 (04-08-2014)
Old 04-08-2014, 10:23 PM   #63
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Originally Posted by Astroboy View Post
Attachment 73655
I have the 50/50 AVO bov sitting at home. I ended up going with the GFB 50/50 anything within a 32mm or 33mm bov will fit.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following User Says Thank You to DesertFrs For This Useful Post:
Astroboy (04-09-2014)
Old 04-08-2014, 10:29 PM   #64
Sportsguy83
Drives: Limited BRZ
Attachment 73655
Yea, we laughed a bit, but it was clear everyone was serious about the need for a BOV
Old 04-09-2014, 10:54 AM   #65
Astroboy
Astroboy's Avatar
Drives: None
Are you willing to sell it
Old 04-09-2014, 12:00 PM   #66
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
SRS answer:
I believe you can just purchase one of the OEM type Bosch BPVs off eBay for around $30. Or go to your local hardware store and find some plugs and hose clamps to seal it up. You can run without a BOV or BPV like the Greddy kit, but I wouldn't recommend it.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
Astroboy (04-09-2014), SkAsphalt (04-09-2014), Sportsguy83 (04-09-2014)
Old 04-09-2014, 06:41 PM   #67
Astroboy
Astroboy's Avatar
Drives: None
SRS answer:
I already purchased a valve at a local turbo store, man the things he was telling me. Anyways, now all I need is a tune....
Old 04-09-2014, 06:41 PM   #68
protpibe
protpibe's Avatar
You dont have the base tune from avo?
Sent from my HTC One using Tapatalk
Old 04-09-2014, 06:43 PM   #69
Astroboy
Astroboy's Avatar
Drives: None
Any recommendations on a good flash tune? I have a full catless header back exhaust and a perin filter to go along with it
Old 04-09-2014, 06:44 PM   #70
Astroboy
Astroboy's Avatar
Drives: None
Need help installing my avo turbo kit
No, maybe because I paid a lot less than the base price... I have an ecutek cable and a dongle but not a map
Installing a Turbo Kit + other mods chiefshayan Forced Induction 21 01-22-2014 11:58 PM
Installing a hood for the fr-s? Frs32907 Cosmetic Modification (Interior/Exterior/Lighting) 11 08-16-2013 12:06 PM
installing harness andrew5826 Cosmetic Modification (Interior/Exterior/Lighting) 16 07-25-2013 11:41 PM
need help installing this chenshuo Cosmetic Modification (Interior/Exterior/Lighting) 6 07-14-2013 02:17 PM
tips for installing amp and sub brichard0625 Electronics | Audio | NAV | Infotainment 4 05-19-2013 08:25 AM
